Question about Cell Phones
I have an electralog cs3311. I need another power cable due to dog ate last one. Could you please email me and tell me how to go by getting another one.. Thanks my Email is - dae882007@gmail.com
Harman kardon soundsticks ii Hi my dog chewed and ate the DC power plug power, luckerly for the dog it was not the AC end. Now I have had my dogs teeth removed I want to fix the sound system. I can find...
https://www.shutterstock.com/image-photo/muzzle-17780320?src=W0JhB6uuAnfBtLF2bzYYqg-1-42
There should be an international standard number with the plug.
example IEC 60906-3:1994
Search on your plugs number and it will tell you all about the plug that you have.
Usually
https://en.wikipedia.org/wiki/Coaxial_power_connector
The outside on the plug is negative and the inside of the plug is positive on most DC plugs .
With a continuity device like a multimeter you could work out which pin connects to the outside of the plug sleeve that inserts into the device. Being negative .
Jul 14, 2017 | Harman Kardon SoundSticks II Computer...
I have a Digital Stream 15-150 converter box. It works very well, but the dog ate the remote control! Would a universal remote serve as a good substitute? I have been to the Digital Stream site, and did...
The 15-150 is not listed in the user manual. It tells you to use your universal remote guide. It says to try codes for a satellite or cable box. I used an older RCA remote (rcu300t) and found the correct code to use it. I used the Hitachi satellite box code 084. It works like a charm.
Apr 14, 2011 | Televison & Video
Dog eat the disc
I'm guessing your trying to say the dog ate the disc that came with your Retractable Ethernet Cable? You're fine. It's just an ethernet cable, you can use them without the disc.
Mar 21, 2010 | Micro Innovations (CPQ06EPC) 6ft Auto...
My dog ate my power cord on my bosch 1200 classixx washer, can it be replaced??
Yes, it is a quite straight forward job to replace the cable.
Remove the top cover and follow the cable in, you will then see what is required .
Alternatively, if you do not want to do this, you could join the cable with a 3 pin connector plug
Hope this helps.
Dec 15, 2009 | Hotpoint Aquarius WD63 Front Load...
Switch cables
Your welcome Fitzy. Execllent, glad the pinouts that I had you look at solved the problem.
http://www.eprom.com/home/faq/motherboard.htm
Please rate me when you get the chance, I would appreciate it.
Ben
May 23, 2009 | Computers & Internet
I need a power cord for an emerson tv
Hope the dog is well. Best to go to hardware store and buy a plug to replace yourself. Is it two wires, or three? Is it round or flat cable? Also if this is a continuos problem you might want to get a length of metal clad cable to put over the cord before you put the new plug on.
Mike
Mar 26, 2009 | Emerson EWF2704 TV
Usb cable
I pick mine up at our local dollar store. Sony wants 19.95 plus shipping and handling. I'll mail you 1(I have 6) email mewms_14904@verizon.net with ship to address.
May 08, 2008 | Sony Handycam DCR-TRV33 Mini DV Digital...
Bravetti microwave convection oven platinum pro series
there should be an online instruction manual on the net. google it.
Apr 21, 2008 | Microwave Ovens
Cell Phones Logo
49 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
