Question about Bushnell Trail Sentry 11-9200 Digital Camera
The camera comes on works on the screen but will not take picture it even says snap on the screen but will not put it on the card
Brand new camera, unable to take any pictures. Internal memory is full. Even when we put a mmory card in place, still thinks internal memory is full. Why doesn't the camera use the memory stick to save...
If you used the internal memory even once, the memory card will not work until you get rid of whatever is in the internal memory. Do this...with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, your card should work properly.
Dec 28, 2010 | Kodak Cameras
Unrecognized File Format comes on screen instead of picture.
Sounds like you're pulling out the card without using the "safely remove hardware" function. This corrupts the card. If your pics are safely on the computer, format the card in the camera to erase it and get it working properly again.
Apr 06, 2010 | Kodak EasyShare C653 Digital Camera
After taking a picture lines appear on screen
This problem is of firmware of the memory card, it has corrupt and needs replacement because it can't be repair. To confirm this, put the memory card out from camera and take snaps which will store on built-in memory of the camera and then shift it to the computer.
Thanks.
Nov 26, 2009 | Fuji FinePix F610 Digital Camera
Camera will not take pictures
Check the Lens switch for A/M (auto/Manual focus), also check the front bottom right of camera, there is a switch, set it to AF also. Hope that helps
May 28, 2009 | Nikon D80 Digital Camera
SNAPPING A PICTURE SOMETIMES FREEZES THE CAMERA AND I HAVE TO REM
1). Download all you pictures on the memory card onto your computer and format the memory card. This will enhance the performance. Its possible too much pictures are there on you memory card and therefore the camera performace drop and hangs.
2). Clean the battery terminals as well as the terminals on your battery and fully it charge it.
Try the above and let me know if the problem still persists.
Mar 03, 2009 | Polaroid CTA-01031S Digital Camera
Snap Shot Pixtreme 3.1 M camera corrupts SD cards
If you just put the card straight into the card reader, not forgetting to set write-protect, you should eliminate this problem.
Aug 04, 2017 | Snap Sights SS 1.3 Digital Camera
Not taking pictures
The sensor sounds bad. The communication seems to have a too long of a delay. Meaning it is not snapping the shot as soon as the sensor goes off.
Jun 10, 2008 | Bushnell Trail Scout 11-9500c Digital...
Camera frozen
You can get the card sorted by taking to a process station and getting them put on a disk. Or a friend with a card reader on their computer. As for the camera - were you on the coast? Damp and salt air are camera Killers. Take battery out Put camera in a large snap shut poly back with a spoonful of rice or salt tied in a cloth with it andsnap it shut and put in a warm place for a couple of days. This will help dry out the cercuits- it may work If it does not - then contact Nikon support - dont mention the seaside - see what gives.
Sep 16, 2007 | Nikon Coolpix 4600 Digital Camera
Camera takes pictures continuously
it is normal on the camera. just avoid pressing the snap button at the upper part near the zoom control.
Nov 05, 2006 | Canon ZR200 Mini DV Digital Camcorder
Bushnell Trail Sentry 11-9200 Digital Camera Logo
Top Bushnell Cameras Experts
Johnny Massengill
Johnny Massengill
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
