Question about Goodman CLQ36AR49 Air Conditioner
Endenpure heater #1500 elete only heats for 2 min and stops.
    Habit-Forming:
  • 156 Answers
Does the fan turn on, or do you just hear the burner fire up and then shut down?
Posted on Oct 18, 2013
Heat pure 1500 shuts down and displays 90.
over heating its self, it could be a blocked and not getting the right air flow or the sensor for the heat control is on its way out. check the filter if this model has one remove all dust from the intake, check that the fan is working, if the motor has been making any buzzing or funny sounds this can be the problem too. buzzing is the starter motor humming or clicking the motor is failing.
Mar 23, 2014 | Advanced Tech Infrared Heat Pure 1500 -...
My iHeater shuts off
Our heater cuts off after 2 mins or less and it shoe 90 on the temps diplay. Had it for a couple of years. It's been vacuum and clean and still the same results. I don't have the schematic or the owners manual..
Jan 17, 2014 | IHeater 1500 Advanced Infrared Heater...
The fan is operating on my Model 1500 V portable heater but no heat is coming out. Is there a way to replace the heating element? We are in the Scottsdale, AZ area if you have a service company that...
Most of these heaters are not worth the price of repairing.You will spend more on labor then a new heater will cost. One thing you can try is to shut switch off on the heater and turn the thermostat to high then unplug unit for 10 mins. Plug back in and turn on. Some of these heaters will reset by doing this.It may not help but it costs nothing to try. Hope this helps you. Thanks
Jan 03, 2011 | Del-Rain 1500-V 1500 Watt Ceramic Heater
HOW DO i GET my new refrig to stop rollng forward. It is a kenmore elete trio
make sure the floor is level and not slanted toward the front u can take the lil kickplate off of the front and put something in front of the wheels to stop it
Mar 01, 2010 | Refrigerators
No heat. Changed the thermostat and flushed the radiator, had heat, now two weeks later no heat. Might be the heater core, yes/no, is it difficult to change? Just wanting to know.Where can I find...
I'ld say yes, heater core. But before swapping it out try this. There are two hoses that lead to your heater core. Disconnect them and add two longer hoses to it. Run one down to a bucket on the floor. The other flush with high water pressure, then there is this acid you can add. WARNING, I DID SAY ACID. It will eat your skin and if you leave in your heater core too long it will eat you core too! After say 2-3 mins flush with high water pressure again. On second flush I'ld flush for a good 10 15 mins to make sure it's all out. Reconnect factory hoses and refill system.
Jan 27, 2010 | 1999 Chevrolet Silverado 1500
The heat pump starts runs 2 min. stops restarts 7 min. later. When it stops after the short run it rumbles to a stop.
sounds like it could be low on charge and if it is a scroll compressor they are known for a noise on shutdown
Dec 19, 2009 | Heating & Cooling
I have a heater core leak on my 2000 chevy silverado V6, is there an easy fix?
You can bypass the heater core, you just wont have heat anymore. On the firewall of the truck, behind the engine, you will see 2 rubber heater hoses that go into the firewall. They attach to the heater core. Disconnect them and get a plastic connector, and connect the 2 hoses together with clamps to hold them down. This will stop coolant from going into the heater core, and no more leak.
Sep 26, 2009 | 2000 Chevrolet Silverado 1500
Heater in 200 gmc sierra is not workinmg
make sure antifreeze is full. run engine 10 min. verify engine is around 195 degrees. if not, try replacing thermostat. if it is running at 195, then maybe heater core problem or heater control not functioning properly
Nov 16, 2008 | 2000 GMC New Sierra 1500
Goodman CLQ36AR49 Air Conditioner Logo
43 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
