Question about Exercise & Fitness
I cannot see You Tube on my I Pad - Exercise & Fitness
    Top Expert:
  • 12,223 Answers
Reset the system and try again.God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Posted on Oct 17, 2013
Can you give me a wicreset keys for epsonL210
Is the waste pad full ?
If the waste pad is actually full and ink is about to overflow, then you need to install a waste container. You can see the waste pad by opening the access panel on the back of the printer.
Changing the waste pad requires almost complete disassembly of the printer, it is a big job. There is an easier way.
Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coathanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won't come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Now the ink will go into this container and not into the waste pad inside the printer. If it gets full, dump it.
Note: This information and a couple of photos are also available on Steve's Digicam Forum (http://stevesforums.com/forums). Goto Printers-Photo Inkjet-Epson R200-210 & R300-310 Mod
Nov 09, 2014 | Epson Stylus Photo 2100 InkJet Printer
Graphic problem
1) Laptop is dirty inside
Processor and graphics chipset are overheating
If the laptop has never been cleaned on the inside, this I deduce to be the problem.
2) Thermal Paste is used on top of the Processor, and a Thermal Pad is used on top of the graphics chipset.
If the Thermal Paste has dried up, the result will be what you are seeing.
[The top of a Processor, and the Cooling Tube metal plate; that sits on top of it; are NOT perfectly smooth.
A magnified view would detail, 'Ridges, Valleys, and Pitholes'.
When the two parts are mated together, Air Pockets are formed.
Air in this case is an Insulator, not a Conductor.
Thermal Paste fills the above imperfections, and is an Excellent conductor of heat.
A Thermal Pad is a material that is impregnated with Thermal Paste.
Therefore the Thermal Paste it is impregnated with, can also dry up.
This is a general example of the cooling system used,
http://www.ebay.com/itm/Toshiba-Satellite-A505-Graphics-Video-card-heatsink-V000190350-/140922091510?pt=LH_DefaultDomain_0&hash=item20cf9c77f6
The long curved copper tube you see, coming straight down; is one of the Cooling Tubes.
You can see another shorter version at the Top.
The Cooling Tube is a slightly flattened copper tube, sealed on both ends; and filled with Nitrogen.
Using the long example coming down, you can see it ends in a rectangular metal plate. This plate sits on top of the Processor.
Heat is absorbed from the Processor by that rectangular metal plate.
Then the heat is absorbed by the Cooling Tube.
The Cooling Tube transfers the heat up to a rectangular finned Heatsink.
This is seen at the Top/Left of the photo, although the fins cannot be readily seen.
The Heatsink absorbs the heat, then radiates it away with it's Tall, Thin fins.
Air flow from the Fan Assembly, helps carry the heat away from the Heatsink's fins.
This is a general view of the Fan Assembly,
http://www.ebay.com/itm/Laptop-CPU-Cooling-Fan-for-Toshiba-Satellite-A505-A505D-P-N-MCF-812BM05-/190731891880?pt=US_CPU_Fans_Heatsinks&hash=item2c6881b4a8
As you can see the Fan Assembly is a small multi-bladed fan, encased in a D-shaped shroud.
The Top view is shown on the Left, while the Bottom view is shown on the Right.
The flat area shown at the bottom, of the shroud; is where air comes out, and is the side that goes against the finned Heatsink
Looking back at the Cooling Tube/Heatsink, Ebay link; the Cooling Tube on the Right, and metal plate area; sits on the graphics chipset.
In-between that Cooling Tube metal plate, that sits on the Processor; is Thermal Paste.
In-between the Cooling Tube metal plate, that sits on the graphics chipset; is a small piece of Thermal Pad.
Apologizes for the long 'dissertation', but felt better to explain in detail; than just state ->
Clean laptop out on the inside, and replace Thermal Paste. Also Thermal Pad.
I can step by step guide you through cleaning the inside of the laptop, and also replacing the Thermal Paste, and Thermal Pad.
Post back in a Comment.
[You'll need;
A) No.1 Philips screwdriver, or Jewelers screwdriver equivalent
B) I suggest two computer Spudger Tools.
Average cost each is around $1.
Basic example,
http://www.amazon.com/Techni-Tool-Spudger-Alignment-Tool-Black/dp/B000PDNPYK
C) An ESD wrist strap. Average cost is $3 to $6.
General example,
http://www.radioshack.com/product/index.jsp?productId=2103245
D) Thermal Paste
General example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503
E) A small piece of Thermal Pad. Needs to be the same thickness, as what is presently being used.
General example,
http://www.ebay.com/itm/2x-Thermal-Conductive-Compound-Pad-For-Heatsink-Chip-CPU-30mmx30mmx2mm-pcs-/190814789631?pt=US_Thermal_Compounds_Supplies&hash=item2c6d729fff
F) A can of compressed air for computers.
G) Q-tips
H) A small soft brush. (Makeup brush?)
I) Tweezers
Apr 12, 2013 | Toshiba Satellite A505-S6970 Notebook
Putting on a new touch pad
see the next video: Use the common sense and carefully unplug the power cord and turn off the c. breaker.God bless you
Sep 16, 2012 | Microwave Ovens
How do I remove and clean the waste ink pad on my Epson R200...where is it ? and do I have to remove the ink cartridges before I do it ? If so do they reset themselves afterwards? Thanks, Pauline
1. Press and hold "Stop", "Maintenance", and"Power" buttons for about 10 seconds. A message will comeon the screen saying counter is reset and to turn the printer off. TheR200 and others don't have a screen so just wait until the 10 seconds isup. 2. Turn the printer off, unplug the power cord. Wait about 1minute and power the printer back up. The counter will bereset. That's all there is to the reset procedure. 3. The waste padis actually full and ink is about to overflow, then you need to install a wastecontainer. You can see the waste pad by opening the access panel onthe back of the printer. Changing thewaste pad requires almost complete disassembly of the printer, it is a bigjob. There is an easier way. Open the access panel on the rear of theprinter (remove screw) and look inside carefully with a flashlight. You will see a tube (down and to your left) coming from the cleaning pumpand it will have an open end on it. This is the tube that delivers ink tothe waste pad. Use a piece of coat hanger wire or equivalent, and fish out thispiece of tube. Bring it to the outside of the printer, thru the accesspanel. Find yourself a suitable container (Tupperware or a plastic cup or jar)that is not too tall. Put the tube into this container and secure thetube and container so they won't come apart or lose connection if the printeris moved. If you wish you can make a hole or notch in the access panel cover soit can be replaced. Now the ink will go into this container and not into thewaste pad inside the printer. If it gets full, dump it.csts_0.jpg
May 18, 2011 | Epson Stylus Photo R300 InkJet Printer
Parts inside your printer are at the end of their service life r300 epson
Thewaste ink pad inside the printer is fully loaded with waste ink.You need to reset the waste ink pad chip. To dothis you mast 1. Press and hold "Stop", "Maintenance", and"Power" buttons for about 10 seconds. A message will comeon the screen saying counter is reset and to turn the printer off. TheR200 and others don't have a screen so just wait until the 10 seconds isup. 2. Turn the printer off, unplug the power cord. Wait about 1minute and power the printer back up. The counter will bereset. That's all there is to the reset procedure. 3. The waste padis actually full and ink is about to overflow, then you need to install a wastecontainer. Open the access panel on the rear of theprinter (remove screw) You will see a tube (down and to your left) coming from the cleaning pumpand it will have an open end on it. This is the tube that delivers ink tothe waste pad. Use a piece of coat hanger wire or equivalent, and fish out thispiece of tube. Bring it to the outside of the printer, thru the accesspanel. Find yourself a suitable container (Tupperware or a plastic cup or jar)that is not too tall. Put the tube into this container and secure thetube and container so they won't come apart or lose connection if the printeris moved. If you wish you can make a hole or notch in the access panel cover soit can be replaced. Now the ink will go into this container and not into thewaste pad inside the printer. If it gets full, dump it.csts_1.jpg
May 14, 2011 | Epson Stylus Photo R300 InkJet Printer
Genaral error
Probably the waste ink tank is full.Follow this procedure:
1. Press and hold "Stop", "Maintenance", and "Power" buttons for about 10 seconds. A message will come on the screen saying counter is reset and to turn the printer off.
2. Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That's all there is to the reset procedure.
If the waste pad is actually full and ink is about to overflow, then you need to install a waste container.You can see the waste pad by opening the access panel on the back of the printer. Changing the waste pad requires almost complete disassembly of the printer, it is a big job. There is an easier way. Open the access panel on the rear of the printer (remove screw) and look inside carefully with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad. Use a piece of coathanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel. Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won't come apart or lose connection if the printer is moved. If you wish you can make a hole or notch in the access panel cover so it can be replaced. Now the ink will go into this container and not into the waste pad inside the printer. If it gets full, dump it.
Oct 15, 2009 | Epson Stylus Photo R300 InkJet Printer
Wet carpet
Your drain tube for the air conditioning is plugged up, and instead of draining on the ground, it's leaking on the carpet. You need to go under the car and locate the tube (it's on the passenger side, in front of and below where the front passengers feet would be. You will need a long thin wire to clean out the blockage.
Aug 25, 2009 | 2006 Dodge Stratus
Clean "Waste Ink Cartridge" Epson R300
Had the same problem. (its a work around without removing the waste ink pad)
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won’t come apart or lose connection if the printer is moved.
Jan 08, 2009 | Epson Stylus Photo R300 InkJet Printer
It has been awhile since i removed my water pad and forgot how to route water line in pad
I've got a 560A, but if it's similar:  The pad sits in a plastic frame with the drain hole and "funnel" at the bottom.  At the top of the frame, there's a plastic piece that sits at the top of the pad; it snaps into the frame and the frame snaps into the humidifier housing.  The water tube from the solenoid slides into this plastic piece so that the water is directed to the top of the pad.
Dec 10, 2008 | Aprilaire 550 Humidifier
How to change waste pad??
hello!
try this and check if it will work:
1. Press and hold "Stop", "Maintenance", and "Power" buttons for about 10 seconds. A message will come on the screen saying counter is reset and to turn the printer off. The R200 and others don't have a screen so just wait until the 10 seconds is up. 2. Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That's all there is to the reset procedure. Is the waste pad full ? If the waste pad is actually full and ink is about to overflow, then you need to install a waste container. You can see the waste pad by opening the access panel on the back of the printer. Changing the waste pad requires almost complete disassembly of the printer, it is a big job. There is an easier way. Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad. Use a piece of coathanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel. Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won't come apart or lose connection if the printer is moved. If you wish you can make a hole or notch in the access panel cover so it can be replaced. Now the ink will go into this container and not into the waste pad inside the printer. If it gets full, dump it.
May 06, 2008 | Epson Stylus Photo R220 InkJet Printer
Exercise & Fitness Logo
32 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
