Question about LaCie 2TB LaCinema PlayHD Media Player 301986
My Lacie 1 tb play la cinema does nothing when connected to tv although the led is on even the remote does not work, tv just says no video signal
  • Edward Kemp
    Edward Kemp Oct 20, 2013
    It was working fine for months then suddenly the tv just says no video signal.
    New Friend:
  • 54 Answers
You must make input setting of TV match the input you are connecting device through.
Posted on Oct 19, 2013
SOURCE: LaCie 1 TB Hard drive won't boot
I lave lots and lots of experience with LaCie Drives (I have 6 of the 2TB models). Every, every, every time a drive fails or runs slowly, it is the power supply. I have now replaced 5. They run very hot (so does the drive), and fail pretty often. It looks like the voltage drops just a smidge, and access times seem to increase, i.e., the drive "runs slow". Then it won't boot at all, and the blue light keeps blinking. Fortunately LaCie has replacement power supplies in the store. Buy a couple extra. I am married to the LaCie drives now, or I would probably switch brands. I kind of guess that they know about this because I contacted the help desk, and he wasn't surprised. Maxtor has a nice drive, and the Calvary drive is $150 cheaper. A drive is a drive I guess. By the way, if anyone is listening, how about building a QUIET, COOL drive with and INTERNAL POWER SUPPLY? GOT IT? All the cords and power supply bricks make me crazy. It might be nice to see a stackable drive where the top of one drive mates to the bottom of another, carrying network info as well as power to the drive above. Hint, hint. We all are building systems with ungodly amounts of storage. Too bad the manufacturers aren't building drives with the durability we need.
Posted on Oct 04, 2008
SOURCE: my LaCie 1 TB shows that I only have 9.99 MB of
You didn't run the EXE that comes on the drive.
I made the same mistake, but did a windows format before running it, so I lost the exe.
Posted on Oct 17, 2009
leitusdotcom
  • 172 Answers
SOURCE: lacie 1 tb hard drive clicks and no recognition
Hi wes_unruh. Unfortunately that "click" , known as the click of death, can mean many things. It could be a head, System Area, scratched platters, etc. First, remove the hard drive from its casing. Then connect the hard drive internally to a computer. You might still get the click. Try a diferent angle and try many many times. Check the logic board for any signs of damage. Please DO NOT start swapping parts because there´s aligment, firmware issues and you can make things worse if you need to do Data Recovery. If you had important informacion, you need to take it to a data recovery company such as Ontrack or ADS, because they have the right equipment such as Deepstar, PCI3000 in order to fully retrieve your files. IT IS an expensive process. I hope this helps. Please do not forget to rate and provide positive feedback for our free support today. Thank you :D
Posted on May 02, 2010
Testimonial: "thanks for the help i seen similar answers but hoped that mine was possibly different or there was a way to fix it ill use the advice"
lock123
  • 6831 Answers
SOURCE: Lacie 1 TB Won't Load Up
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Posted on Dec 02, 2010
SOURCE: I have a 1TB LaCie 2Big Quadra. It has 2 500GB
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Posted on Jan 11, 2011
Connected samsung ht x720 (home cinema system 2.1) to v+ box.Cant get picture when playing a DVD.Can hear the sound tough.Thanks
You probably need to change the incoming input signal on your tv.
In other words, your audio is coming directly out from your dvd player, and going directly to the audio power amp.
Your video does the same thing, except it goes to your tv. Your tv has multiple places for "incoming" signals to hook in to it. Take a look at where you're hooking your video in - the input should be marked ... something like "Component 1" "Component 2" "HDMI 1" "HDMI 2" ... something like that.
On your remove, there will be a button that says, "Input." When you push this, you will see that your TV brings up an input selection window. Pressing the "input" button on your remote should scroll through the ports on the tv. Briefly pause on each input selection to see if it begins receiving a video signal from your DVD player.
Nov 19, 2010 | Samsung Audio Players & Recorders
Lights on nobody home
Well if it is less than 2 or 3 years old you could contact them to attempt a sawp out of the drive. Over that - replace the unit. IF you do - you might want to consider a duel disk enclosure so if a drive dies, your data does not. you can build one yourself (1 TB duel drives, Raid 1) for a total of 252 bucks, with good drives (Seagate - Barracuda) Yes I swear by the Seagate Drive. For off teh shelf they have worked very well in every application I have deployed them.
I've been burned by too many single drive failures - even when I have the data backed up it is still a royal pain.
Jan 25, 2010 | LaCie Big Disk Extreme with Triple...
How do i connect my non hdmi xbox 360 to my panasonic scbt205ebk home cinema and panasonic 42v10 plasma so that the sound comes from the home cinema system. i also have sky hd
If you use a component system (1 yellow video wire, 1 red audio wire and 1 white audio wire)
You will have to connect the audio wires to your cinema system and the video directly to your set.
The unfortunate part of this is that when you want to use your system, you will have to change the input of the TV AND the Cinema system.
The same would be true if you wanted to use the DVD connectors (YBPBR). You would connect the video to the TV and the audio to the Panasonic unit.
The system you have is meant more for just playing DVD's and not a total cinema system. This is why there are limited (extremely limited) video inputs. The system is mostly for output of sound and of a the built in DVD video.
Aug 05, 2009 | Panasonic Televison & Video
Need to down load the La Cie 1 TB user manual.  HOw do I do this?
Go to this web site: http://www.lacie.com/us/support/documents/index.htm?id=10007 and then select the manual for your model.
Jun 08, 2009 | LaCie Computers & Internet
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
VCR shows "PLAY" on machine but doesn't show on TV
If even the sound aside from the video is not reproduced on the TV, then your description "connect" indicates that the TV is not set to receive the audio/video signals from the VCR. Initially, pls try:
  • set the TV to Channel 3 (or 4); or
  • set the TV to A/V, Video 1 or Aux 1.
Additionally, you need to confirm how the VCR is hooked to the TV unit, bu a single coaxial cable or 3 cables with RCA connectors (yellow, red & white).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.Good luck and kind regards. Thank you for using FixYa.
Nov 02, 2008 | GE VG4054 VCR
JVC Tv Constant Blue screen
if you have the remote control number RM-C203 with your tv than try noise muting in your menu settings mine did the same thing i just put noise muting off and it worked for me
Aug 06, 2007 | JVC AV-27530 27" TV
LaCie 2TB LaCinema PlayHD Media Player 301986 Logo
146 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
