Question about Opella Push Drain with Overflow OPELLA 90136.110
Opella push drain with overflow 90136.110 - The springs that operate the push drains rust after a year or so and the push drains become ineffective. I have been unable to find replacement spring mechanisms and so the only solution has been to buy expensive complete drain fittings just to get the replacement springs. Are the spring mechanisms available on their own?
I have a kenmore model 110 24952300 twice in last 2 years it has overflowed?
Could be that the drain is plugged by debris. Otherwise it could be that your model drain valve is faulty and not tripping properly when operating at high volume. Check the level of the tub when observing the overflow, could be that drain pressure has something to do with the overflow.
Feb 01, 2015 | Kenmore Washing Machines
How much plumbers putty do I bead around when installing a repacement?
I recommend between 1/4 to 1/2 inch bead of plumbers putty. Slightly flatten the bead on the strainer pushing a little past the outer edge then press it firmly into sink and remove any excess from below sink before installing rubber ring and lock nut tighten firmly but do not over tighten adust drain to center in hole retighten slightly if necessary and remove any excess putty from around drain. Hope this helps.
Bob
May 23, 2014 | Opella Strainer Waste Assembly OPELLA...
Washer overflow from drain pipe
If the water continues when electricity is discontinued the soleoid valve is jammed open, a fleck of rust or something, not designed to be repaired, it is easier and cheaper to replace. they are a standard part that fits 99% of all washers ~$10-20 at the local parts guy.
Usually only the cold solenoid has failed. it gets used more often.
If you are like me and only use cold water, swap the hoses on the taps, and swap the wire connectors on the solenoid valves, so the former hot is now cold, and you will get about the same number of years before you have to replace anything
Nov 27, 2012 | Maytag Washing Machines
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
Drain stuck in closed position
Generally the drains that are controlled from the
OVER-FLOW do indeed have a rod that goes down
from the face of the overflow... which lifts (opens)
the drain by lifting a hollow (typically plastic) sleeve
from in front of the outflow of the drain...
It is hollow to allow the OVERFLOW to work at all times.
The version you seem to have... WOULD have a
bellows like device that pushes on a plug lever...
More complex... but I seriously believe both may be
serviced through the OVERFLOW
(will attach a drawing below)...
OBVIOUSLY you will want to block the drain before rolling & dropping screws in, on & around the drain HOLE...
Once you see the diagram of the drain MECHANISM...
you will be able to see that jamming in a coat-hanger
was a terrible idea.
You can still most likely remove and repair the
mechanism ... (from the over-flow)
ELSE
You are looking at buying a new one and installing the entire drain from the bottom (hopefully).
Diagram of drains:
Go to Bing homepage
Carnac the Magnificent
Mar 22, 2017 | Maax Plumbing
Fuel over flows thru overflow tubes only when motor is running. motor off ignition on it stops.
Hello
Your gas tank petcock is diaphram operated.
there is a vacuum line coming off the intake, that goes straightb to the petcock.
when you turn the motor over a vacuum is created, pulling the petcock diaphram back and allowing fuel to flow to your carburetor. when you turn the motor off the vaumm is gone and the spring behind the diaphram pushes it closed and stops the fuel flow to the carbs.
Now the reason the carbs are overflowing is because the floats valves are not closing, in other words the floats are sticking.
Usually a good carb clean will cure the problem, especially for that year.
the older ones usually require new float valves/seats that are usually found in a good carb rebuild kit. You shouldn't need one.
If your really broke try tapping on the bowls of the carburetor lightly, while the engine is running, sometimes the vibration will vibrate a particle loose that may be holding open the float valve.
if it works then the fuel should stop overflowing while running.
if you know how to work on it, try this, with the engine off.
open the carburetor drain screws so that fuel will run out the carb. drain. flush out the carb.
get a container to catch the gasoline.
while fuel is flowing tap the carb bowls a few times then closed the drain screws.
clean up any spilled gasoline .
start your bike.see if they stop leaking and the floats are closing.
if it still leaks, you'll need the cleaning.
Happy Riding
Best Regards
Big Al
May 22, 2011 | 1997 Yamaha Royal Star XVZ 1300 A
Good morning! My Kohler tub drain (original equipment - about 40 years) is beginning to shred itself. It appears to be a K-7145 or related popup drain. I've been pulling the screws out of the overflow and...
I can't really put my finger on the cause, but am quite familar with screws not wating to come out of the overflow.
When you finally do get the screws out, see if you can find suitable replacement stainless steel screws.
Get some "copper rich" antisieze from a plumbing shop or auto supply store and apply a little to the threads when you reinstall them (hopefully new screws).
After 40 years, a new tub drain may also be in order, but depending on the location, that can involve a great deal of work.
Best of luck to you!
Oct 27, 2009 | Kohler Plumbing
I have a new push push drain from mac faucets, and it leaks. I have reversed the rubber gasket that goes under the sink (held on by the brass threaded ring assume that I don't use plumbers putty under the...
The order of installation starting from the top side is the flanged drain then a bead of plumber's putty, and don't skimp on the putty. On the bottom side, first the rubber gasket then the metal washer, finally the locking ring. You must use the plumber's putty between the sink\tub surface and the flange. My mom thought the same thing. She return her drain twice before she asked me why it was leaking:)
Hope this helps.
Sep 11, 2009 | Opella 2-3/8" Push-Push Drain Assembly...
Opella Push Drain with Overflow OPELLA 90136.110 Logo
85 people viewed this question
Top Opella Plumbing Experts
Paul Carew
Tom Chichester
Are you an Opella Plumbing Expert? Answer questions, earn points and help others
