Question about Music
Peavey 16 fx
Recording from the board to Macbook sounds distorted.
    Problem Solver:
  • 11 Answers
Are you going from the board to a 'mic' input, or a 'line input' on the Mac? you will need to attenuate the signal to a mic input. try reducing output from the board by 50% and reduce the input level on the Mac by 50%, and see if the distortion is lessened or eliminated. From there balance board output to Mac Input until you find what sounds good outta the Mac.
Posted on Oct 17, 2013
3 Suggested Answers
soundchasr
  • 8 Answers
SOURCE: Peavey sound board 2 channels not working
check for cold solder joints from the input jacks and the fader. If any look suspicious (dull or grainy) re-solder.
Posted on May 29, 2009
  • 5603 Answers
SOURCE: not recording
You likely have to format the stick from the unit before using. Also there MAY be a size limit for the useable stick.
For a flight case, it is best to find one that SPECIFICALLY mentions use for your unit. Having the supports in the right area to protect the controls is most important.
Posted on Apr 12, 2010
How do I fix channels with no sound
Mute Switch/Mute-Clip LED :
  • This switch mutes all Aux, Group and L/R sends from the corresponding channel.
  • This switch is equipped with a red LED that will illuminate when the channel is muted.
  • When the MUTE button is out,the LED functions as a Clip indicator that will illuminate at 2 dB below clipping.
  • Muting the channel does not prevent the PFL signal from being sent to the PFL/AFL mix when the PFL Switch (12) is in.
  • This switch mutes its respective Group send from the Group channel.
Go to page 11 in this link :
Peavey FX Mixer Series Operating Manual
You can also try, Restoring Factory Settings, in the Utility Menu Options.
Go to page 16 in ths link :
CAUTION:
Restoring the factory settings option resets your mixer's presets, reformatting factory presets and erasing all other user presets. (This option is handy when your venue has permanently changed and all-new presets are required.)
Once confirmed, the presets are not retrievable and will be permanently lost.
Should you select this option in error, a warning screen allows you to cancel the procedure.
Sep 05, 2015 | Peavey 32fx USB 32 Channel Mixer
High pitch feedback
you are sending the signal back on itself, hit the usb to main switch to off.
Nov 12, 2013 | Peavey PV6 Mixer
I have a TNT 115 S that is distorting when i play E string on my bass. What might be causing that?
Please add more information to improve help, does the amp just distorts in that particular note or teh entire sound is distorted? does the amp distorts at low volumes?
Sep 05, 2013 | Peavey Electronics Peavey Tour Tnt 115...
Whats the best way to include a separate efx processor to a peavey 16fx when aux 1 2 3 4 6 are being used as monitor sends and aux 5 is the main efx send
It looks like using the GROUP output to drive the external FX and then bringing that back into the EFX return is about the only thing you can do in short of putting the effects after the main outputs then it would be on everything.
May 14, 2011 | Peavey 16fx 16 Channel Mixer W/built In...
I NEED A SERVICE MANUAL FX 24 MIXER PEAVEY
I believe the manual you are looking for can be found here: http://www.manualnguide.com/manual-get/4220/
May 04, 2011 | Peavey 16FX 16 Channel Mixer
The FX portion of the board is clipping with no input signal present, there is no sound output at all. Also, none of the mute/pfl LEDs light up on channels 1-12.
There are several clipping indicators on this board. Do you mean that the small vertical display to the left of the FX selection window is maxed out from top to bottom? I will assume that you have ALL the FX inout knobs CCW for all channels AND the FX slider all the way down. Also does the FX selection knob work to change the effect number? Does the rest of the board work? WILL the effects pass sound when you send it through the effects? You say no sound, but was that just to say with no sound sent to it it still is clipping, or that it will not pass sound?
Oct 18, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Not recording the memory stick is always blank what is the dimention for peavey 32 fx mixer so i can buy flight cases
Apr 11, 2010 | Peavey 32fx USB 32 Channel Mixer
Using the USB connection to send the stereo mix to a computer
You have to insert a track into Reaper "arm" it. If you can't figure it out, I'd suggest posting in the Peavey forums.
May 14, 2009 | Peavey 32fx USB 32 Channel Mixer
Apr 29, 2009 | Peavey Pv 2600 Power Amplifier
Music Logo
57 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
