Question about IBM Office Equipment & Supplies
Toner cartridge error
New toner cartridge is printing with black lines appearing halfway across the page about an inch apart.
  • 35 Answers
SOURCE: three broken horizontal lines across all printed pages
I can see a couple of possibilities here. One: The cleaning blade for the drum could be damaged and not all of the toner is being cleaned off of the drum between pages. Two: The drum could be damaged and the damaged parts of the drum are not accepting the changes generated by the laser. I don't think you have a fuser problem because if it were that, the toner would probably smear when you touch it. Typically, I would say it is the toner cartridge but you replaced it and still got the same problem. I would inspect the drum cleaning blade first. That would be the most cost effective first option. Hope this helps. Good luck.
Posted on Jun 21, 2007
  • 406 Answers
SOURCE: Black Streaks
The Black Lines are not due to to toner problem.
The Black lines ate same at the Page Location . If so the Problem may be with Drum Or Charging Unit Or fuser assembly. If the same problem continues Please take out and see the drum do not toch it . (Please Power off the Printer and disconnect all the cables. )
REgards
Rafique
Posted on Mar 12, 2008
Bubbabear64
  • 2794 Answers
SOURCE: hp 2300 new cartridge printing black lines
There good printers its just who you use to get the cartridges from. We sell some but there not refills and we have good prices if your interested.
Unlike Ghana our can be returned if they don't work.
Posted on Jun 24, 2008
SOURCE: Black line across page when printing or copying
Did you try wiping clean the glass? also wipe the strip by the scanner glass?
Posted on Jan 09, 2009
  • 5603 Answers
SOURCE: HP 4650dn Printing Small Specks of Toner
They could ALSO be on the fuser roller... Check that first.
Posted on Sep 04, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Tip
When u print if u r getting the Horizontal or vertical line then follow these...
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal black lines
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant black lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical black line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
on Aug 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
Canon LBP 2410 Lazer Colour Printer -
Printing not dark enough or varied in darkness
Faulty part
0.5”
1.5”
1.75”
2.0”
2.56”
3.16”
3.75”
Jun 07, 2008 | Canon Office Equipment & Supplies
Hi, I have this type of printer and there has been no problems..except.. i'm the new secretary and the golden drum light is on..never noticed if it was or has been always on..and the printing every 1 1/2...
Means toner cartridge is nearly to end. Just shake a little bit to distribute evenly the toner powder and be ready to purchase new toner cartridge. And is it nothing to do with the drum. Drum problem will create black shadow lines when printing.
Dec 07, 2010 | Brother HL 1440 Laser Printer
Cp2025 horizontal color lines almost 3" apart.
you have to replace toner cartridges (unfortunately).
Same problems can be occured whit CP 1025 too
the problem is - cartridge image drum failed
Jul 14, 2010 | HP Laserjet Cp2025n Printer
Black horizontal lines across pages
If they are the same distance apart every time then suspect the problem to be caused by the components in this order First the drum that is in the print or xerographic module, the charge and cleaning roller are located in that module also. So I suspect that first.its .Located above and to the right of the toner cartridge. Secondly it could be the roller on the toner cartridge, that would occur probably every 1 1/2 to 2 inches apart, the drum would cause the defect about every 3 inches. It less likely could be coming from the fuser, and if the fuser was causing that you should also have a lot of jams. There is also a transfer roller on the right hand door that could be causing it, but that would be exceptionally rare.
If the lines are random and have no consistant spacing, I would suspect the power supply then the laser.
Oct 28, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Printer Problem - Konica Minolta 7450
Horizontal lines
A horizontal line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant lines on the page and then use Table A to determine which part might be causing the problem. Table A
Faulty part
0.5”
1.5”
1.75”
2.0”
2.56”
3.16”
3.75”
Vertical line on edge of page
Sep 03, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Hey m8
  • Buxie, first off you have voided your warrenty, secondly
  • If marks repeatedly appear on the printed side of the
    page at even intervals:
    • Clean the inside of the printer. See “Cleaning the
    Inside of the Printer” on page 5.7. After cleaning
    the inside of the printer, if you still have the same
    problems, install a new toner cartridge of the
    problem color. See “Replacing Toner Cartridges” on
    page 5.3.
    • Parts of the printer may have toner on them. If the
    defects occur on the back of the page, the problem
    will likely correct itself after a few more pages.
    • The fusing assembly may be damaged. Contact a
    service representative.
  • If horizontally aligned color or black streaks or
    smears appear:
    • A toner cartridge may be installed improperly.
    Remove the toner cartridge and reinsert.
    • A toner cartridge may be defective. Install a new
    toner cartridge.
    • If the problem persists, the printer may require
    repair. Contact a service representative.
  • SXPRESS- It is normal to have to replace it after that because the starter cartridges are rated for 1500 pages but that is at only 5% page coverage and most people print alot higher coverage than that, and the replacements cover 2000 pages again @ 5% page Coverage
May 20, 2008 | Samsung CLP 300 Laser Printer
15 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
