Question about Sharp R-1481B Microwave Oven
Iberna oven ,when i switch on the oven it chips the fuse box out
  • 2,113 Answers
First of all check the inside of the cooking area for chips in the paint and burn marks. If there are none then you may repair this unit. Open it up and check the many thermal overloads for open circuit. Then check for burned wires and repair any if found. Then replace the fuse if blown. Then change the magnetron and possibly the capacitor. Also verify that the door closes properly and that the circuit board has no burned components or burned circuit traces. Sometimes the relays stick and need replacing but that would not cause the breaker to trip.
Posted on Oct 16, 2013
Won't turn on. Shows no power to it but outlet fine,
Check input power supply by tester if its conform its OK then check the oven control box .try to check any abnormalities there .
Jul 19, 2016 | Bosch 500 HMB5050 Microwave Oven
My Neff microwave has lost all power. It tripped the main switch at my fuse box. I have re-set the switch but still no power. Any ideas. Is there a fuse in the microwave and if so where is it?
There are two or more fuses on microwaves, but when they cut the power feed it is for something, if you bridge them you will find that your oven doesn't work properly, it will make weird noises and produce a power low in your home. If you want to check it, the main fuse use to be inside a plasitc tube with two wires on it's edges, one conected to a big condensator, and another one to the inner circuit.
Feb 19, 2015 | Neff Microwave Ovens
How do I take the oven out of its trim to check the fuse?
There are screws to take the cover off, look closely, or find it online.
Be very careful, there is a large capacitor in there that can do you some harm.
Dec 17, 2014 | GE Microwave Ovens
Where is the fuse box?
If no power fuse behind panel but may be thermal switch behind top vent remove and you can see it 2 black wires the spade may need to be tighten.This is the fire safety thermal. Test for 110 volt across to test.
Sep 30, 2014 | Samsung SMH1816S Microwave Oven
Why does ge microwave blows fuse when door is opened?
Inspect the door switches and the wiring in the light bulb circuit. If the problem is a door switch, it will probably be visibly broken, or there will be burn marks on it. It's also possible that the door switch bracket is bent or broken and allows the terminals to short to the oven frame. Check the lamp socket - if it is cracked or burned, it should be replaced.
Also look for signs of arcing or burn marks on the controller board, especially near the relays (usually black plastic boxes about 1" x 1' x 3/4' mounted near the wire terminals or wire harness connector).
As a general note, it is rare for a fuse to fail by itself. If you find a blown fuse, look for a cause before replacing it. This may prevent wasting another fuse.
Jul 01, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
My wife slammed the door and now the microwave does not work. it popped the fuse box and also cut the power to the stove. i flipped the switch in the fuse box and the stove came back on but not the...
You can try to take the unit down and open the cage. Look at the door safety switches and see if they also popped out of place. She might have permanently damaged the door. But don't panic just try what I just explained. Turn off all power first at the breakers.
Jan 05, 2011 | KitchenAid KHMS155L Microwave Oven
My frigidaire GLMV169 manufactured in 2005 and purchased in 2006 stopped working. There is no power. The clock, buttons - everything. Tried changing the outlet and flipping fuse switch and still...
Hello there:
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Nov 19, 2010 | Frigidaire GLMV169 Microwave Oven
Blown fuse
Check your door switches or your turntable motor, these could also cause the fuse box to trip.
Mar 25, 2009 | Sharp Microwave Ovens
Has no power
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
thanks
Mar 18, 2009 | Panasonic NN-SN657SMicrowave Oven
Sharp R-1481B Microwave Oven Logo
29 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
