Question about Wolff Sunquest 14SE Tanning Bed
Wolff sundash I am getting a help 2 error code. What does this mean?
I'm looking for an error code meaning that appear on my krups coffee machine the error code is "code error 02"
You will probably get some proper help if you identify the exact model. I don't expect "error 2" to mean exactly the same on every model Krups have ever made, narrow it down a bit for us please.
Mar 22, 2017 | Krups Coffee Makers & Espresso Machines
In need of a manual for a wolff sonnen braune 728 tanning bed that i purchased from craigslist, for wiring specifications
You would have to ask direct as that is very specialised. The phone number for the technical lines are at the top of the homepage.
https://www.wolfftanning.com/
Tanning Beds by Wolff Tanning
Apr 18, 2016 | Wolff Health & Beauty
Fans keep running after bed shut off
The fans will run until the temperature has been reduced. Just because you shut it off doesn't mean it gets immediately cold. It's just like the fan on a car that keeps running after the car stops.
Jan 03, 2015 | Wolff Sunvision Pro 24S Tanning Bed
My local tanning salon said they use Wolff tanning lamps. What does that mean?
Wolff tanning lamps give off UV tanning rays like the sun but only UVA and UVB rays to help tan without increasing the risk of burning. These are the type of tanning beds that most salons use.
Feb 18, 2013 | Health & Beauty
1986 sca wolff 328sl tanning bed wont stay running
Consult manufacturer. You can track that down online. You may have a over-temp switch inside the bed. If so, then either the switch is bad or the bed is getting too hot. Have a trained technician to check voltage going to bed, if voltage is wrong that can cause bed to overheat. Make sure all fans are running, replace any fan that is not running. Clean all dust out of bed with vacuum and brush while you have it open.
Dec 15, 2012 | Wolff Sunvision Pro 24S Tanning Bed
Error code
You need to list in a catagory with some possiblities of help. The section you are in is for Cars and Trucks.
Sep 20, 2012 | Cars & Trucks
SunDash Competition 226 Manual
We source all are manuals on line, so if you can't find it there we don't have it either. Sorry.
Jan 24, 2012 | Motorcycles
Peugeot 206 radio Error 2, what does this mean?
i don't know what error 2 is. It might mean that you tried too many attempts to enter the code, causing the radio to 'lock up'. When this happens, some radios 'auto clear' the error code after a fixed period of time (anywhere from 3 hours to a couple of days). Others can't be cleared without sending the radio back to the manufacture (but try simply disconnecting the battery, and reconnecting it, first)
Assuming that you can get back to the position where you can enter the code, here's how to do it. I'll use the code 4968 for my example:
Press button 1, 4 times
Press button 2, 9 times
Press button 3, 6 times
Press button 4, 8 times
Press button 6.
try leaving your ignition on for an hour or so and see if the error 2 message changes to the option where you have to input a code.
check you peugeot manuals to see if the previous owner has noted the code down if not hopefully you should have a stereo manual whihc will have the serial number on it .if not then you will have to remove the stereo and get the serial number off the back.
if you take the serial and logbook to a peugeot dealers they will beable to give you a code usually free.
let us know how you get on and please rate
May 06, 2009 | 2005 Peugeot 405
Wolff Sunquest 14SE Tanning Bed Logo
Top Wolff Health & Beauty Experts
Steve
noel
noel
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
