Question about Honeywell HT-800 Table Fan
How do I get a replacement remote control for an AIRWORKS ceiling fan/light
  • Debi MacDonald
    Debi MacDonald Oct 18, 2013
    This is a great big ceiling fan the previous owners installed over a stairwell, I dropped the remote and broke it and the fan/light does not respond to the light switches.
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 225 Answers
There are lots of fans with remotes available for under $40.00. I don't think you can find a remote for $40.00
Posted on Oct 16, 2013
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Go to web site of Air Works and find out who sells the unit in your area. Google to fond the 1 800 number.
Posted on Oct 18, 2013
How do I replace the light bulb on ceiling fan for Airworks. Can't twist it off!!!
Try putting on rubber gloves and turn the globe clockwise. The globe has a very smooth surface and is impossible to turn with bare hands because you cant get a grip on it.
You can read the whole forum below:
Replacing Ceiling Fan light bulb PhD required
Nov 16, 2016 | Dryers
I have an Airworks ceiling fan/light with remote. Worked fine for years. Now battery is being drained very quick.. in a matter of a couple of weeks! Replaced battery but it drains in a couple of weeks
Stuck button, spill on remote causing power drain or most probably you got a batch of weak batteries. Try a different brand and make sure they are alakaline.
Aug 15, 2016 | Dryers
Hunter fan 27227 remote stopped working
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... Cp9430r Fixya
Jun 22, 2014 | Hunter Ceiling Fan Light Remote Control
AIRWORKS 9 inch ALL METAL TRIPLE DRUM FAN WITH REMOTE
go to :google.com or bing.com & type in to the search box ,airworks,airworks fans or try these guesses,
www.airworks.com or www.airworks fans.com or www.airworksfans.com
and try google with all those .com's (all my guesses) in the search box
If you get to airworks website, they should have owners manuals available as a pdf adobe reader download.
download adobe reader for free from www.adobe.com
Oct 08, 2013 | Dryers
Remote control B-542
Peter, Home Depot carries replacement ceiling fan remotes.
Check the attached links,remote and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Universal Hunter Ceiling Fan Remote Control Replacement Light Fan Speed...
Hampton Bay Ceiling Fan Remote Control 70830 The Home Depot
Jan 28, 2013 | Dryers
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
I need to replace my Hampton Bay Ceiling Fan remote control. Part # G9P2BTAUC7052T. Where do I get one?
I need to replace my hampton bay remote control part #G9P2BTAUC7052T for my ceiling fan and light.Where do I get one
Jul 11, 2011 | Universal Remote Control Hampton Bay...
I have an airworks remote for my light and ceiling fan, quit working waht can i co?
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Jun 12, 2010 | Universal Remote Control Hampton Bay...
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Honeywell HT-800 Table Fan Logo
210 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
ray gallant
Danny Kuhlmann
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
