Question about Ovens
Keeps shorting out and blowing the fuses - Ovens
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 92 Answers
Stop letting mice in to your wiring!
>> check elements
Posted on Oct 18, 2013
Problem start when i turn Oven only on teka, then the fuses blown up. I can still use grill but whwn I turn to oven fuses go blow up again.
Hi! It seems it is not the heating element! It seems to be before that. Either a short circuit delivering to much current thus causing the blow. I would check the corresponding cable all the way to the circuit and the circuit elements corresponding to the oven element. The grill and oven elements being "independent" explains why grill still works. (A short circuit seems quite possible to me!)
Dec 06, 2014 | Ovens
IS IT NORMAL FOR THE FUSE TO BLOW WHEN A HEATING ELEMENT DIES IN THE FAN HEATER IN MY ELECTRRLUX COOKER?
The heating element is shorting out and causing it to blow the fuse
Aug 25, 2014 | Ovens
Main fuse blown. what are the possible causes
A fuse blows when there is higher current drain and so it is relative to a short in the system.
It is very easy to find a short with just a continuity test. so remove the power and check for the short in the circuit. remove the connections to the sections one by one and when the line is seen to open it is confirmed.
Aug 08, 2011 | Ovens
My electrolux EOD5330 fan oven tripped a fuse. ow it won't heat. The fan still works
Most likely problem is the the oven element short circuited which caused the fuse to blow. When power is restored everything generally works except for the element. If you check the element you may find a blow hole in it.
Feb 10, 2011 | Electrolux EOD5330 Ultrafan Electric...
Problem with electric oven
Either your fuse holder/breaker has a bad connection and has a voltage drop tripping your power  or  your heating element is shorting to it's outer jacket which is grounded.  Check your heating elements carefully for wear and disconnect that element and see if it trips still.
Nov 09, 2009 | Ovens
Gaggenau EB 194 Double Oven fuse blowing
from your description, it seems the little fuse is overheating sometimes, a short is a short and an immidiate fuse blower. i would use a higher amperage fuse, 30 amps. any electronic tech can replace this, doesnt have to be your Gaggenau guy, as it seems to me hes made a regular income of this
Apr 17, 2009 | Gaggenau EB294/295 Electric Double Oven
Oven not working - fuse blown
Probably the oven element has gone .Disconnect element and try again if fuse does not blow, change element.
Plz rate this solution.
Thanks
Dec 14, 2008 | Smeg Ovens
Turning on grill blows fuse on Electrolux EOG7330WN
get i an accredited electrician to check the grill element and fitting
there is a dead short in that area
Apr 23, 2017 | Electrolux EOG7330WN Gas Double Oven
Microwave oven
The high voltage capacitor is probably shorted, (large, silver, oval shaped part). typically .98mfd to 1.02mfd
Jun 03, 2008 | Ovens
Ovens Logo
41 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
