Question about Dell Computers & Internet
Display adapter i have studio 1555 laptop i m working while display is blinking while message display on your display adapter stoping and recover plz tell solution
    New Friend:
  • 3 Answers
You can uninstall the display driver then install the latest driver from the dell website either on Intel website.
Posted on Oct 16, 2013
  • 10 Answers
SOURCE: HOW TO CONNECT 5.1 WITH DELL STUDIO 15(1555)
Open up Control Panel and navigate to IDT Audio Control Panel.
On the right hand side, there would be an image depicting the jacks available on the 1555. Left click on the respective jacks and change them corresponding to the 5.1 outputs. 21d6042.jpg
Posted on Aug 08, 2009
  • 916 Answers
SOURCE: My Dell Studio 1555 laptop does not read the dvd drive
Microsoft Windows Vista loadTOCNode(2, 'resolution');
  1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. Collapse this imageExpand this imagesecurityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Now go to the "Did this fix the problem?" section. uparrow.gifBack to the top Microsoft Windows XP loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
Posted on Sep 07, 2009
  • 1705 Answers
SOURCE: Cd is stuck in my dell studio 1555 laptop?can you
Look closely at the bezel of the disk drive, you should see a small hole.
Straighten out a paper clip and push it, quite firmly into the hole. This is the failsafe release.
Posted on Jul 21, 2010
  • 629 Answers
SOURCE: on screen display of dell ac power adapter not
2 possible causes, faulty adapter or faulty motherboard. try to update the BIOS if applicable. If this does not work, attempt to test the adapter on another laptop to confirm if it is working, or try a confirmed working adapter with your laptop. If same issue with another adapter, or if your adapter works with another laptop, it will be a motherboard problem. If the adapter fails on another laptop or if another adapter works with your laptop, you'll need to get a new adapter. Hope this sheds some light. Feel free to rate the usefulness of the information.
Posted on Nov 04, 2010
Dell 1555 Studio laptop won't power up. After the power cord is plugged in, the LED light on the side blinks white once and orange four times. What could be causing it and how can it be remedi
have you tried a different power source or power supply ,maybe you can borrow one from a friend and try and if that don't work you might have to take it apart and see if your power cable is seated properly in the motherboard
Sep 28, 2014 | Dell Studio 1555 laptop
Light off on the charger
Either your laptop charger is dead or your laptop dc jack is loose. Try use a spare laptop ac adapter to examine it. If it will work well, that indicates you need a new charger, if it appears the same situation, you should repair your laptop dc jack. If you don't have a spare charger, just get one from the following e-shop:
Replacement Dell Studio 1555 AC Adapter 90Watt 19.5V 4.62A
Nov 04, 2012 | Dell Studio 1555 laptop
Hello this is simon. i just turn off my laptop dell studio 1555 and it was working well before shut down. when i start this another day it just not start and dont show even any light. please help me
Hello, Simon.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Sep 12, 2011 | Dell Studio 1555 laptop
Dell studio 1555 laptop will not reconize charger, charger and battery were checked on another laptop and are fine.
Thats a hardware issue of your laptop. You'll need to take it to a service centre to fix it, hope you still have your warranty left.
Cheers
May 12, 2011 | Computers & Internet
Hi,i have dell studio 1555 laptop i waana to know to about where we insert a sim in my laptop and how to conifgure for internet
actually, I know the solution partially....
and i need that solution too.
Open your battery, then you will see a sim card slot (some metallic type).
Now you know about drivers then tell me name of driver...
Apr 04, 2011 | Dell Wireless 5530 Mobile Broadband...
On screen display of dell ac power adapter not recognized......for dell studio 1555 does anybody have solution whenever i plug in my power cord into laptop ,,,,moreover battery is also not charging
Nov 04, 2010 | Dell Studio 1537 Notebook
Brand new laptop studio 1555. ie displays not responding message while on internet page with a video on it
reset IE
Open only 1 Internet Explorer (IE) window go to and choose internet options. Go to the advanced tab (far right) and look down towards the bottom it says reset. click that and click yes. Then restart IE and that should correct the problem :)
Dec 29, 2009 | Dell Studio 15 Laptop
My dell studio 1555 webcam stopped working and it says ''close other video streaming devices to start video''
1. disable all streaming files and apps first.
2. run system restore, restore the point when webcam was working fine. if fails.
3. uninstall / reinstall webcam driver. if fails.
4.
Oct 10, 2009 | Dell Studio 15 Laptop
Computers & Internet Logo
43 people viewed this question
Alun Cox
