Question about Kenmore Refrigerators
Kenmore Model #68882 ..Freezer has been icing up since the unit was delivered in July 2013 ...3 repair people have been out ...find nothing wrong with the unit ...say things like it will be better when there is less humidity outside ...say that the door is opened too often ....say these new units use a different type of freon ...gave instructions on how to defrost (a frost free refrigerator) ...Is this a bad unit ...or is this typical of this model refrigerator?
catriver
  • 878 Answers
SOURCE: Kenmore Refrigerator 65812
camp, see if your model starts with 106.65812, Serial beginning with EP or ER. If so it may be the air tower. They had a service flash out on this line but the closest I can get to your model number is 106.65824. E-mail me at catriver1@gmail.com with the complete model and serial and I will see if I can help you. If your model doesn't start with 106, repost with the correct one. Catriver.
Posted on Jan 22, 2007
  • 1462 Answers
SOURCE: Ice build-up in freezer - Kenmore Model C978-66795-2
don't know this appliance but for guidence:
some appliances have the evaporator in a compartment at the top of the freezer and the drain comes out of the back and runs externally to the drip tray. there should be a grill in the compartment so just peer into it and see if there is ice build up.
wherabouts is the freezer ice forming?
Posted on Sep 05, 2008
SOURCE: Defrost problem on a LG Bottom Freezer Refrigerator
I had the same trouble. I found out if you have the digital display of temperature type of refrigerator adjust the freezer temperature to +5 degrees. The defrost systems uses a circuit board type. Not sure how it works. I took the back panel of and looked at the board. Did not see any manual defrost methods. I had to remove all the contents of the freezer and manually defrost. have not a problem since.
Posted on Nov 24, 2008
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
  • 245 Answers
SOURCE: Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Posted on Jun 26, 2009
How do I find out the model number of my Kenmore elite Fridge
Since the freezer is icing up there could be many different problems a blockage or a problem with the defrost or timer of the unit if u greeting unit number is should be on inside of the door or back by the condenser best bet from what I see is get a tech to fix it they will find all those numbers that u need
Dec 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Help please - my Kenmore Elite Bottom Freezer not cold - top refrigerator getting warm.
Have pressure taps installed, & check the refrigerant... these refrigerators have a critical charge (meaning not a lot of refrigerant to make them work) So whoever puts gauges on it, make sure they purge their hose while screwing the hose on to the new pressure tap so there is no loss of refrigerant & no air gets into the system. It sounds to me like it is low on refrigerant.
Dec 10, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My refrigerater is not cold. but the freezer is working fine. what can be wrong
You have a defrost problem Need model number to see who made your frig as Kenmore makes nothing.
Nov 26, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore bottom freezer refrigerator warming up
Hi
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Regards
Berry
Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Our Kenmore Refigerator was purchased July 1992. Model # 363-9524720 Serial # L220-16905. Problem: Refigerator runs but freezer section does not freeze and ice cubes are not forming. Food storage area does...
As a start, try cleaning the coils and fan under the refrigerator.
You would not believe how many refrigerators and freezers I've worked on which required nothing but a good coil cleaning. The dirtier these coils get, the less efficient the unit becomes until it reaches a point that it almost appears as if the refrigerant unit is not working at all when all it really needs is a good cleaning.
While you're under there, be sure the fan is running to pull air over the coils to cool and condense the freon inside them.
Sep 11, 2009 | Refrigerators
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
LG LRFD25850 French Door, Fix or Repair Daily
You are expereincing poor service. The techs that are working on your unit do not know what they are doing. There is no problem that can't be resolved on appliances. My suggestion to you is to find a really good LG tech in your area to repair this problem. There are only so many things that can cause these problems.
Jul 24, 2008 | LG LRFD25850 French Door Refrigerator
Refrigerators Logo
23 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
