Question about Garden
Ford 1210 tractor breaks steering column shaft
5 Suggested Answers
vwmike2001
  • 74 Answers
SOURCE: Soft steering 2007 Simplicity Prestige 27hp tractor.
have you checked your fluid level
Posted on Aug 15, 2009
  • 36 Answers
SOURCE: my ford 1210 tractor is blowing black smoke. I've
your injectors are set to rich
Posted on Jun 07, 2010
  • 150 Answers
SOURCE: John deere 68 riding mower steering column won't
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Posted on Sep 27, 2010
Testimonial: "sounds good will try to fix it thx"
  • 6468 Answers
SOURCE: How do I tighten the steering shaft to the support on a craftsman tractor 917.257643?
the plastic support cracks and needs to be replaced
Posted on May 16, 2012
93 corvette tilt steering colum rebuild
It will be the top shaft bush that locates the steering shaft in the centre of the column tube . It is normally just a push in fit . You will find reference to it in a parts break down book
Jan 26, 2014 | 1992 Chevrolet Corvette
Poulan pro pr185h42st How do I remove the steering column
Do you have the tractor operator's manual? There are parts diagrams in the back. If not, here is a typical Poulan Pro Manual It looks like you should.
1. Remove the steering wheel.
2. Remove the steering shaft extension
3. Remove the clip from the shaft down by the steering sector.
4. At this point the steering shaft may slide out the bottom of the tractor through a hole in the frame. If there is no hole you will have to remove the complete steering sector from the tractor.
Nov 01, 2013 | Garden
John deere 68 riding mower steering column won't turn wheel assembly via arced toothed plate. Wheel assembly OK and greased. Some minor play when rotating steering column with steering wheel, but appears...
Sep 27, 2010 | John Deere Garden
I have a 1988 f-350 diesel and i have lost my key and bought it without a spare how do i remove the ingnition with out a key
You don't without ruining it. I suggest you get a locksmith to make you a new key they can get in there somehow and make a key. In 1988 did Ford use a seperate key for doors? If the doors are the same or the glove box those locks are easier to remove. Also, I've never tried this with a Ford but on newer GM cars if you take the title to a dealer they can make a key from the (VIN) serial number. But, you have to have the title to prove ownership of the vehicle. I don't know if they can do that on an 88 or not. Good luck.
Feb 09, 2010 | 1988 Ford F 350
The steering column shaft in my 1954 Ford 8N tractor broke and I need info on howe to fix it.
Not sure, but if it's a 1954 model, it's not an 8N. 8N was only built thru 1952.
But sounds like you will need a new steering shaft.
www.Ford8N.com
Sep 19, 2009 | Ford 8N Tractor
The steering wheel on my toro lawn tractor is loose - teeth won't engage. It doesn't look like the teeth are broken - can I loosen the plate on the tractor that is attached to the wheels and adjust to fit...
no; you'll need a new steering shaft and a steric gear.( i just did this on mine) this will be your best result.as they wear @ the same time both need to be replaced.hope this helps
Jul 27, 2009 | Garden
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
