Question about HP LaserJet 9000mfp Printer
Reset nvram factory - HP LaserJet 9000mfp Printer
  • HP Master
  • 1,121 Answers
1. Turn off the product.
2. Turn on the product.
3. When the control-panel display shows that the product has begun to count the memory, press and hold the 9 key.
4. When the LED lights turn on, release the 9 key.
5. Press the 3 key, and then press the Start key.
6. Use the 3 and 9 keys to scroll through the options (skip disk-load, NVRAM init, manufacturing, and skip calibration) and then press the 6 key to select the option you want.
The product continues the power-on sequence.
Posted on Oct 17, 2013
Cannot connect to network. It show IP address 0.0.0.0
contact your service provide for assistance on how to set it up
Apr 28, 2015 | HP LaserJet P2015n Printer
How set factory default xerox 7800
Solution : Reset the Printer to the Factory Defaults (Reset NVRAM) WARNING: Only use the tool when directed to by Xerox Service. All user and system settings will be lost.
  1. Select [Printer] on the Touch Screen.
  2. Select the [Tools] tab.
  3. Select [Setup].
  4. Select [Service Tools].
  5. Select [Reset NVRAM]. A confirmation screen will be displayed.
  6. Select [Reset NVRAM] again.
Related Knowledge Bases:
Mar 05, 2014 | Xerox Printer Division Xerox Phaser...
Printer does not reset
NVRAM initialization/cold reset
NVRAM initializer sets all default variables stored in NVRAM back to factory default values or to a default ROM value, depending on the variable. It also performs a system reset.
NVRAM initializer resets the following:
! all menu settings to factory default values
! factory settings such as formatter number, page counts, factory
paper settings
To perform NVRAM initialization
1 Turn the printer off.
2 Press and hold down the GO button.
3 Turn the printer on and continue to hold the GO button for at least 20 seconds. During this process, the GO button, Attention, and Ready LEDs will each turn on.
4 Release the GO button.
5 The printer LEDs will begin cycling. The NVRAM-unit process will run until the printer is in the ready state.
Or download the service manual here ..
http://www.google.com.sa/search?site=webhp&source=hp&q=hp+laserjet+1200+printer+service+manual&oq=+HP+LaserJet+1200+Printer+service+&gs_l=hp.1.0.0j0i22i30l6.200423.206442.0.207913.10.10.0.0.0.0.763.3187.0j3j2j3j1j0j1.10.0...0.0...1c.1j2.9.hp.QNDAx6nGCA0
Apr 18, 2013 | HP LaserJet 1200 Printer
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
How can I perform an NVRAM initialization with my HP CM1015 MFP
CAUTION NVRAM initialization will erase all network settings. Before performing NVRAM
initialization, print a Network Configuration page, which contains network-setting information.
NVRAM initialization performs the following actions:
? Resets all customer-accessible menu settings via control panel and software back to the factory
default settings
? Resets the language to the value set at the factory
? Resets the default media size to cold reset media size
? Resets the symbol set to PC-8
NOTE The following steps reset the same NVRAM locations that are reset using the
Restore Defaults option in the control panel Service menu. The following process should be
used if the MFP does not come to a Ready state and an NVRAM initialization is desired.
Use the following procedure to perform an NVRAM initialization.
1. Turn off the printer.
2. Press and hold the Right arrow and Cancel buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
When the NVRAM init is complete, the printer returns to the Ready state.
Aug 02, 2011 | HP LaserJet CM1015 MFP All-In-One Printer
Whenever I print my document, it doesn't exist the document I want to print but many strange symbols appear on the printed paper, how can I solve this problem?
Cold reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM inititialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
Note If an HP Jetdirect card is installed, remove it before performing a cold reset. Otherwise, the procedure will also reset all the HP Jetdirect settings as well as the printer settings.
To perform a cold reset
3 Turn the printer on, and continue to hold the GO button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED will turn on.
Note If both the Attention and the Ready LEDs turn on before you release the GO button, you must start the procedure again with step 1.
5 The printer's LEDs will begin cycling. The cold-reset process will
run until completion, and the printer will return to the ready state.
If not work, tris this
CAUTION Only perform the following procedure if absolutely necessary.
Performing an NVRAM initialization resets some parameters that cannot be restored later.
NVRAM initialization sets all default variables stored in NVRAM back to factory default values or to a default ROM value, depending on the variable. It also performs a system reset.
NVRAM initialization resets the following:
  • all menu settings to factory default values
  • factory settings such as formatter number, page counts, and factory paper settings
3 Turn the printer on, and continue to hold the GO button for at least 20 seconds. During this process, the GO button, Attention, and Ready LEDs will each turn on.
Jul 30, 2011 | HP LaserJet 1300 Printer
How do I reset a Xerox Phaser 4500 Centreware password to factory default.. or what is the factory default password? I have on which has been changed and nobody seems to know the PW anylonger
this should restore it to default.
By default there is no username or password required to access CentreWare Internet Services. If a username and password have been configured for CentreWare Internet Services and you do not remember the username and / or password, reset the printer to factory defaults (NVRAM reset).
To reset the NVRAM, go to the front panel's Main Menu:
  1. Select Troubleshooting, then press the OK button.
  2. Select Service Tools, then press the OK button.
  3. Select Reset NVRAM, press the OK button.
  4. Select Reset NVRAM and Reset Printer NOW, then press the OK button to reset all the settings to their factory default values.
Mar 03, 2010 | Xerox Phaser 4500 Printer
Xerox phaser 8560 nvreset - how?
According to http://www.laserquipt.com/support/idx/42/615/article/-Reset-the-Printer-to-the-Factory-Defaults-NVRAM-Reset-.html (and it worked for me):
NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAMto their factory default values. The print count and the Adobe firmwareserial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM.
Pressand hold the [Up] arrow button on the Control Panel, and then press the[OK] button. This will automatically display the Service Tools menu onthe Display Screen.
  1. Press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Pressthe [Up] or [Down] arrow button on the Control Panel to select[Troubleshooting] on the Display Screen, and then press the [OK]button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
In answer to the clarification request, I suspect they have lost the admin password. Does that help you answer the question?
Jun 03, 2009 | Xerox Phaser 8560DN Laser Printer
Wont recieve fax
NVRAM init NVRAM init returns all stored parameters in NVRAM to factory default values or to a default ROM value, depending on the variable, and performs a system reset. Performing NVRAM init can cause the product to violate local telephone regulations. Reset the language and country/region after performing NVRAM init. ENWW Service-mode functions 265 NVRAM init resets the following settings and information: ● All menu settings are reset to factory default values, including fax header and company name. ● Factory settings such as formatter number, page counts, and factory paper settings are reset. ● All faxes in memory are erased. ● All speed-dials, group-dials, and phone book entries are erased. ● All localization settings, including language and country/region, are reset. To perform NVRAM init 1. Turn off the product. 2. Press and hold down the * and MENU/ENTER buttons. 3. Continue to hold down the buttons while you turn on the product. Hold the buttons through the entire power-on sequence. 4. When Permanent Storage Init. appears on the control-panel display, release the buttons. 5. When the message Language appears on the control-panel display, set the correct language and country/region. 6. Allow the product to return to Ready before using the product.
Jul 24, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 9000mfp Printer Logo
Seeker5211
Seeker5211
