Question about Xerox Office Equipment & Supplies
There is a problem with the xerographic system
Xerox workcentre 7775
Best get in touch with Xerox asap.
You probably did that already.
Good Luck.
Aug 18, 2014 | Xerox Office Equipment & Supplies
Code 09-700 xerox 4150
09-700 Toner Supplying Error RAP
The toner module has stopped supplying toner to the xerographic module.
Procedure
WARNING
Switch off the electricity to the machine. Disconnect the power cord from the customer
supply while performing tasks that do not need electricity. Electricity can cause death or
injury. Moving parts can cause injury.
1. Check that the tape seal has been removed from the xerographic module, PL 9.10 Item 1.
2. Remove the toner module, PL 9.10 Item 2. Check that the locking lever opens and closes
the toner shutter.
3. Install new components as necessary:
• Toner module, PL 9.10 Item 2.
• Xerographic module, PL 9.10 Item 1.
Jul 27, 2011 | Xerox WorkCentre 4150 Black and White...
Xerox 4150 my paper is a light shade of grey, what can it be thank you
Giacomos,
Is the paper a shade of grey with no image? or is there an image with a grey background?
If there is a image with a grey background you should try a new toner module. If that doesn't resolve the issue, clean the xerographic drum, make 10 blank copies, if the cleaning doesn't resolve the issue than install a new xerographic module.
Hope this help.
Apr 05, 2011 | Xerox WorkCentre 4150 Black and White...
Xerox copy center C35 - Replace Xerographic module
You can try this.
Press the access button, You will see a button called Enablement Code, then enter this number. *33886714351 .
Make sure you entter the * first, that is the button bottom left on the keypad.
That should allow you 5000 more pages. But it can only be done once. May or may not work on that product. But thats all I know.
Feb 23, 2010 | Xerox Office Equipment & Supplies
Xerox m 24 creasing paperon A3 prints
check the pressure of the fuser adjustment
Oct 23, 2009 | Xerox WorkCentre M-24 Color Copier
9-xxx Codes are all Xerographic problems such as toner problems, developer problems, Drum Cartridge problems, ADC (Auto Density Control) problems too.
Aug 12, 2009 | Xerox DocuColor 12 Printer
Xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Aug 09, 2008 | Office Equipment & Supplies
149 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
