Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
I have a Bissell Proheat Plus that is not sucking up the water. I don't know how to fix this. Please help!
  • Bissell Master
  • 18,389 Answers
This video will help you
Posted on Oct 16, 2013
SOURCE: water suction
Here's what I did. On the top of the water bucket there is a red oval screen, remove and clean the screen and replace. Also, next to the screen is an oval opening which meets up with a black oval gasket on main unit. Inspect the gasket and replace if dry or cracking. Otherwise, if it looks good, reseat the gasket (it fits into some grooves). When you fill the bucket and put the the top on, put it in the machine and make sure it is making good contact against the gasket. This worked for me. I also found a repair manual for these units that could be helpful located at: http://www.bissell.com.au/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Posted on May 24, 2007
reddevil6
  • 1673 Answers
SOURCE: bissell 1699n proheat clear view problems
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix know. Pump is bad.
Posted on Jan 17, 2008
SOURCE: The bissell proheat turbo carpet
Bissell cleaner will not **** up water???
Posted on Sep 14, 2008
nwj2468
  • 76 Answers
SOURCE: my bissell want **** up
somewhere on the unit, there will be a round clear cap. when you find it, unscerw it and clean out the inside.
Posted on Mar 01, 2009
  • 60 Answers
SOURCE: My Bissell ProHeat steam cleaner won't spray water. The accessory
Under the plastic under the water tank (its a pain to pull apart to get to it) there is a solenoid that actuates the water between the floor and the tools. This is toast if its not spraying the floor, its simply not reacting to the signal to let it go through to the water side.
Seems to be a common problem with the Bissell Proheats. You can order a new one online for about $12 and try to get to it to replace it yourself (if you can open up the base its obvious which part it is if you just follow the hoses).
Posted on Oct 31, 2009
My machine is not sucking water up. After cleaning the floor there's no dirty water to dump out.
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Nov 21, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 12 amp turbo carpet cleaner, not sucking water, model#8910
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Apr 15, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Not sucking up water off carpet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
fgqwe
Apr 03, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Plus carpet cleaner does not **** up water
heatman101
dghdgh
Jan 04, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My bissel proheat carpet cleaner is not sucking up the water
heatman101
Oct 08, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Proheat 7901-R not doing anything--ready to scream!
heatman101
ewtywe
Mar 12, 2009 | Bissell 7901-R Clearview Proheat Plus...
Bissell proheat blowing out air instead of sucking in air
heatman101
vm,v
Feb 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
