Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
My john deere gx75 don't go into reverse and when i put forward gear i hear a noise like a tic tic tic...
  • 513 Answers
It sounds like the spider gears inside transaxle is worn or broken causing noise and causing reverse not to work.
Posted on Jun 10, 2014
  • 582 Answers
SOURCE: I've got a John Deere SST-18 riding mower. I've
GO ON LINE TO JOHN DEERE PARTS YOU CAN DOWN LOAD PARTS DIAGRAMS AND WIRING DIAGRAMS ALSO. CHECK THE PLUGS AN THE WIRING HARNESS AND MAKE SURE THEY ARE CLEAN. WITH A VOLT METER YOU CAN CHECK AND SEE WHAT VOLTAGE YOU ARE GETTING TO THAT RELAY. I DON'T HAVE A DIAGRAM TO LOOK AT BUT IF I CAN FIND ONE ONLINE I'LL LET YOU KNOW. HAVE YOU CHECKED FOR A SECOND RELAY
Posted on Sep 15, 2009
  • 420 Answers
SOURCE: john deere 300 garden tractor will not go forward or backwards
Make sure the neutral lever (rod) back by the right rear tire is pushed ALL the way in.
Posted on May 27, 2010
  • 3911 Answers
SOURCE: trying to change the blade belt on my john deere
Get in touch with your common sense. You have the deck out from under the mower and you have cleaned it. By chance is there a belt install guide on a sticker on the deck? This is a very common sticker. If you can get on fixya you can Google "John Deere deck belt install" with your model number. Failing all that, look at all the pulleys and the belt itself. The belt is flat on one side and v shaped on the other. Now look at all the pulleys, some have a groove and some are flat. The groove tells you the v of the belt goes in there and the flat tells you it is to take up slack or absorbs shock and the flat of the belt runs touches it. There is but one way it will go. One of the pulleys moves in an arc on a spring loaded swivel, that is your tensioner and will be the last one as you will move the tensioner to get it installed.
Posted on Aug 23, 2010
SOURCE: hydraulic reverser problem with John Deere 1010
ineed to find a hydraulic reverser for a 300D john deere backhoe
Posted on Nov 23, 2010
  • 3 Answers
SOURCE: my john deere 316 stopped moving forward and
HAVE YOU CHECKED THE TRANSMISSION/HYDRAULIC
OIL? THEY ARE THE SAME. ON SOME TRACTORS THIS
CAN BE CHECKED AT THE REAR OF THE TRACTOR JUST
BELOW THE SEAT. IT COULD ALSO BE A BAD HYDRAULIC
PUMP.
Posted on Jan 02, 2011
My john Deere 100 series .... Gear stuck in reverse.... And will not start because it is stuck in reverse!
sit on the mower and push the clutch in
start moving the mower by rocking it forward and backward while trying to put it in neutral,don't worry about your neighbors thinking their is something wrong with you while you are doing this.
Oct 10, 2014 | John Deere Garden
GX75 won't key start
you will have to follow the line from the switch through the safety switches and see where the break is.use a continuity tester you will find the fault
Aug 04, 2013 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deer gx75. 9hp kawasaki. Turns over but won't
check and clean air cleaner. Check main jet for blockage.
Jun 23, 2013 | Garden
Steering not good. are gear parts available for this old mower?
Yes the steering parts are still available from John Deere. I had just repaired one myself.
Steering Shaft AM101937
Steering Gear AM36998
Bottom Bushing M47067
Jun 12, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
I've got a John Deere SST-18 riding mower. I've lost the steering when in forward, but not in reverse. Last time this happened, I had a blown diaphram. This time both the forward and reverse diaphrams are...
Sep 14, 2009 | John Deere Air Cleaner Bowl For Tractors
Gator 6x4 tranny problem
try posting the question in the forum for john deere gator and not the forum for the kids john deere gator
May 21, 2009 | Peg Perego John Deere Gator HPX
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
498 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
