Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Installed new column shift mechanism and now my truck has no wipers, heat/ac, stereo, or power windows. I checked all the fuses and wiring connections. Any advice?
    Problem Solver:
  • 10 Answers
You are on the right track- it is a bad connection someplace, or at worst a broken wire in the harness. The other very common problem is a Bad Ground. Sounds more like you are not getting power in rather than a ground. Check the power supply.
Posted on Oct 16, 2013
  • Chevrolet Master
  • 1,327 Answers
Check in backprobe with test light ignition connector if current is from one side and the other side
I think a terminal is bend inside connector or back out
I have a 2003 caravan I have all power on acc if I start it I lose windows, radio,ac,wipers and transmission won't shift
Troubleshooting electrical issues is tricky. First things first check all your fuses. that out of the way, I would say wiring issues in the ignition switch circuits, or a faulty ignition switch.
Aug 05, 2015 | Cars & Trucks
2002 elantra no power to wipers radio head lights and heat
Please check for codes in the OBD system. Check Battery and Charging System. If no codes perform following test procedure.
Tests/Procedures: 1. Check the Black power connector in the under dash fuse box. Wiggle it with the lights on and see if they malfunction.
2. Wiggle the wiring harness from the ignition switch around the steering column with the lights on and see if they malfunction.
3. Monitor the key on battery voltage from the ignition switch at terminal 3, Red wire at the ignition switch to terminal 3 of connector I/P-E in the under dash fuse box.
4. See if the vehicle has any aftermarket accessories installed that may be tapped into that Red wire from the ignition switch to the fuse box.
Potential Causes With OEM Direct diagrams, components, TSBs, and R&R procedures
Ignition Switch
Output Speed Sensor (OSS)
Power Connector
Radio Wiring
Steering Column Wiring
Apr 07, 2015 | Hyundai Motor 2002 Elantra
Turn on AC and wipers start
loose ground wire inside the steering column. Also check for loose wires around there. If not replace your switch
May 27, 2013 | Kia Rio Cars & Trucks
Installed new wiper motor, delay board, and checked fuses on 98 monte carlo and wipers still dont work. Washer pump no working either unless i jump power to it. I checked wiring to motor and pump. Seems ok
Most likely, you can check the multi-function switch on the steering column, They generally will go out after several years of use. To replace this, you must first remove all steering column covers. Refer to A Haynes Manual if you are unsure of how to proceed with this. After that, you must remove the multi-function switch from the column, it should be secured by one or two bolts, or on some models simply a retaining clip(plastic) that mounts it to the steering column. Replace with an direct OEM replacement, or its equivalent(available at Autozone) and this should take care of the problem. After replacing the relays, fuses, and the motor, the only thing that it can be is the multi-function switch(other than faulty wiring, in which you will need an Ohm meter to detect). Any other questions feel free to ask.
Jul 01, 2011 | Chevrolet Monte Carlo Cars & Trucks
2000 Ford Taurus - Installed a new radio and used the Meta 99-5716 install kit with wiring harness. After install, radio, pwr windows, pwr locks, dome light, windshield wipers, and speedomoter have stopped...
Sounds like you have blown fuses which could have happened if you accidently short circuted something while wiring up the new stereo. Check your fuses to see if any of them are blown.
Jan 07, 2011 | 2000 Ford Taurus
First had aircondition serviced.after that the instrument fuse keeps blowing.fuse will stay working but when truck is switched on and off,thats when it will blow.Dont know if the servicen of the...
I have seen multiple trucks with similar fuse blowing problem and have found most are caused by a shorted out overdrive switch or wiring inside the steering column. Usually this is triggered by moving the shifter or something on the column though usually the shifter since thats where the overdrive switch is mounted. If the wiring is the problem after the connector in the column then you have to replace the entire shift lever since the wiring for the overdrive switch is integral to the shift lever.
Aug 16, 2010 | 2002 Ford F250 Super Duty SuperCab
Power windows turn signal and ac/heat wont work
Had the identical same problems on our Chrysler Concorde. We checked all fuses and relays nothing. Then we checked the wiring on the ignition switch mounted under the steering column it was loose. Repositioned it and everything worked perfectly again. Did not cost a thing. Hope this helps!
Sep 26, 2009 | 1994 Chrysler New Yorker
Fuse box diagram for 2002 ford taurus
The 1999 Fuse Box Diagram is as follows:
Column 1 (Top to Bottom)
Driver Window Relay
Interior Lamp Relay
Driver Unlock Relay
Battery Saver Relay
Hazard Lamps (15A)
Diagnos (10A)
Cigar (20A)
Front Wipers (30A)
Air Bag (5A)
ABS (10A)
Shift Interlock (5A)
Blank
Column 2 (Top to Bottom)
High Beams (15A)
Deck Lid Release (15A)
Mirrors/Antenna (5A)
Head Lamp Illumenation (5A)
Light Out Module (5A)
EEC Ignition Coil (20A)
Brake Lamps/ A/C (15A)
Instrument Illumenation (5A)
Column 3 (Top to Bottom)
Accessorty Delay Relay
Rear Defrost Relay
Tail Lamps (5A)
Battery Saver (10A)
Wiper and Vaps (5A)
Rear Wiper (15A)
Turn Signal (10A)
Air bag/ Alt LPS (A)
Starter Relay (10A)
Left Low Beams (10A)
Column 4 (Top to Bottom)
Switch Illumenation (5A)
Def Sw Illumenation (10A)
Stop Lamps (15A)
Radio (5A)
Radio Memory (5A)
Right Hand Power Locks (20A)
Gauges/ Warning Lamps (5A)
Radio Mute (5A)
Right Low Beam (10A)
Hope this helps.
Apr 19, 2009 | 2002 Ford Taurus
Wipers and Heather
If the fuses are ok then check your earth connections. Make sure they are clean and secure. Have you had a test meter on the wiring to these components?
Nov 27, 2008 | 1991 Ford Escort
BMW 740IL Wiper Issue
try checking for a short to power on ur 12 volt comming into motor also check for a good ground at the plug for ur wiper motor
Jun 16, 2008 | BMW 750 Cars & Trucks
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
24 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
