Question about Savin GENUINE RICOH FUSER UNIT (402451) for SAVIN CLP22 YIELDS 100000 PAGES
Black will not print on a savin clp22 - Savin GENUINE RICOH FUSER UNIT (402451) for SAVIN CLP22 YIELDS 100000 PAGES
  • 108 Answers
Please make sure that the toner tape is pulled from the cartridge or try a new black toner cartridge.
Posted on Oct 16, 2013
How do i reset a fusing unit counter on a CLP22
Hi. First of all did you have a code to tell you to replace the unit? I would like you to put the old unit back in and see if it lets you restart your printer. If it comes back up you have a problem with the new fuser you received. Take a few seconds to compare the unit and make sure all looks the same. If it's a remanufactured some times little things like tabs and the such get bent or broken. It should reset the counter when you set the new one was replaced. Hope this helped. I do get a little wordy at times
Feb 04, 2015 | Savin GENUINE RICOH FUSER UNIT (402451)...
Black streaks at bottom of page after printing
Okay Grehner, I suggest you to perform a complete alignment and cleaning/maintenance-service for this printer.ASAP...this will help you out with this particular problem during printing.
Blessings.
Gladmar.
Mar 18, 2014 | Savin Office Equipment & Supplies
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
Savin c2824 wont print pdf files
If its showing drivers for a different machine then the first step should always be to completely remove and reinstall the drivers for the correct unit.
Mar 02, 2012 | Savin Office Equipment & Supplies
Does the savin 9122 have ahardive
It may be an optional Hard drive. print the Printer configuration list and see if its listed. UT>printer feautures> config list
Nov 02, 2011 | Savin 2070DP Black and White Copier
I have a savin c4040 and when we want to copy a sheet 8 1/2" by 11" it automaticlly prints on a 11" by 17" how do i fix that?
try to ensure that paper standard in copier has congruent with your computer for more detailes call us
Dec 30, 2010 | Savin 2545DP Black and White Copier
Printing very light
it is possible the td sensor was left disconnected.If that is the case the dev will be shot to pieces by now. £££
Apr 19, 2010 | Savin 2575 Black and White Copier
Savin CLP22 black only is running out of toner on the cartridge. Toner supply is good but it is not getting to the cartridge. If I take out the cartridge, it will work for a while. Shaking the toner supply...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 02, 2010 | Office Equipment & Supplies
Cable
Standard Interfaces of the printer are:
USB 2.0, and 10/100 BaseTX Ethernet.
You can buy an ethernet cable to connect the printer on a network or a USB cable to connect the printer directly to your PC.
Good luck and please rate me, thanks.
Jan 05, 2009 | Savin 9935DP Laser Printer
Savin GENUINE RICOH FUSER UNIT (402451) for SAVIN CLP22 YIELDS 100000 PAGES Logo
62 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
