Question about Singer White Speedylock 1634
Change bulb on 1600 - Singer White Speedylock 1634
Change bulb on 6085 PFAFF
Looks like you bulb is a bayonet style. Push up and rotate the old bulb to remove. Install the new bulb the same way--push up & rotate to lock in place.
Note: there is also a bulb remover tool
Pfaff Varimatic 6085 Parts
PFAFF fashion Owner Manual Changing The Light Bulb
Apr 07, 2017 | PfaFF Sewing Machines
Tip
Speedylock 1600 video
My wife picked up one at a thrift store for $20.00. She gave me the job of looking into a manuel for it. I think that the original video that came with it can be found on youtube at...
https://www.youtube.com/channel/UCSo_kB9pRB6uPgVOp9wHtWg
A copy of the manual can be found at
http://www.hammerwall.com/Manuals/White/Description/1600/White%20SpeedyLock%20Differential%20Sewing%20Machine%20Manual/754_SL%201600%20x/
A review for it can be found at
http://www.sewinginsight.com/other-brands/white-speedylock-model-1600-review/
on Jan 15, 2015 | White Sewing Speedylock 1600 Mechanical...
How does one change the bulb on an elna 6003 sewing machine
Hopefully you have a manual that shows how to replace the bulb. Online Elna manuals have a fee.
Perhaps something here will help:
Change bulb elna 6003q
How do you change light on elna 6003 sewing machine
Watch Me For Minute Elna Lightbult Change
Jun 06, 2016 | Elna Sewing Machines
Change a light bulb in Bernina 1008 sewing machinge
If you still have original Acessories there should have been a grey or brown cone shaped rubber gripper that could be slid up on bulb to assist in turning it If not remove the side cover, then back cover to access the bulb. Some 1008's have push in bulb others screw in so be careful not to break bulb as you remove it
push in bulbs must be pushe in and rotated 45 degrees counter clockwise to remove. Of course screw in bulbs just rotated counter clockwise to remove
Aug 23, 2014 | Bernina Sewing Machines
My top looper does not go all the way to the left needle stitch. It is only picked up by the right needle stitch. I'm not sure what to do. I have re-threaded and adjusted tension with no change. It's a...
Hi, you have to set the timing for your top looper. Mechanical aptitude is required to set the timing since its a very sensitive and critical. I can probably help you look for me at www.sewingmachineryrepair.com
Jan 25, 2010 | White Sewing Speedylock 1600 Mechanical...
Replacement lightbulb, model 1500, 12v6W
Here is the toll free number to White. 1-800-331-3164 or go to www.whitesewing.com. Perhaps you can order the part. I have a Sears Kenmore sewing machine. My light bulb went out after 35 years. Can you believe it?? I finally found the bulb at a local sewing machine center however, they wanted $9.00 per bulb.. Walmart, Target, Joanns etc., did not have the bulb. I called the sears part center and obtained the bulb there. The cost was $4.00 for a pack of 2. After all the hunting I did, the S&H was well worth it. Good luck and I hope this helps you.
Nov 17, 2008 | White Sewing Speedylock 1600 Mechanical...
How do I dis engage the cutter
What does your manual say?
If the 1634 is anything like the 1600 I don't think you can disengage it. I have the book for the 1600 and there is nothing mentioned about disengaging -- only changing the blades. Some models are like that. You might join the White serger group and ask the members there..
http://groups.yahoo.com/group/white_model_sergers
Someone may have an answer or a way around it.
Otherwise, all I can suggest is to call or go to a Joann's or a Husqvarna Viking sewing machine dealer and ask them. Alternatively, a sew and vac repair shop may be able to assist.
Oct 30, 2008 | Singer White Speedylock 1634
Singer White Speedylock 1634 Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
