Question about Watches
Set time on a Skechers STTMR-007 watch - Watches
Where can i buy a strap for my skechers watch?
Check this place out they have both the watches and the bands.
http://www.lazada.com.ph/catalog/?q=sketcher%20watch%20band
Apr 28, 2017 | Watches
How do you set a womens sketchers sr6007 analog-digital watch?
I think you mean SKECHERS. Try Googling (SKECHERS)(sr6007)(manual) without parens.
Aug 29, 2016 | Watches
Cannot change analogue time, do you pull out the crown?
mcdevito75 here, I would figure you do, pull out the stem to se the anolog time.
Jun 28, 2010 | Nike Triax Swift Adx Wc0035 007 Watch for...
Need instruction manuel for elgin fg010-007 sports watch
The movement in this Elgin is made by Citizen. After you change the battery, you need to reset the hands so that the watch functions properly. Select chronograph function with lower-right button. Then pull-out the same button. Push the upper left button to select the UTC, hour, and minute hands. Then use lower-left and upper-right buttons to make sure everything is aligned to 12:00 position. After setting the hands to 12:00, push in lower right button. Now you can set the time by selecting the SET using the lower right button. Pull out the same button and choose your time zone to set.
Feb 28, 2009 | Elgin Watches
Left hand side winder
The crown on the left side is HELIUM VALVE and is designed for compensating and keeping the right air pressure inside watch case if it is used for diving purposes.
If you will try to set something using this crown, nothing will happen, as it has special springs, gaskets and bars built into it, but has no any connection with watch movement.
Do not forget to rate, please.
Jan 29, 2009 | Omega Seamaster James Bond 007 2220.80...
What is the function of the winder on left hand side please
Watches Logo
89 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
