Hotpoint aquarius wml730 will not start program, machine is full of water. How can i force start it?
All lights come on when power button is turned on then go off
    Problem Solver:
  • 5 Answers
It's more than likely the pump at the base of the washer . Easily solved if it is . Follow these steps .1 take the machine near to a outside door and make sure the front is over the edge . 2 at the base if the washer there will be a panel you can either remove or drop down . More on next post Hotpoint aquarius wml730 will not start program, m - 11_21_2013_2_04_46_pm.png
Posted on Nov 21, 2013
4 Suggested Answers
SOURCE: HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Posted on Feb 07, 2008
  • 3 Answers
SOURCE: hotpoint aquarius wt540 wont pump out water
Hiya Barry, I have the same machine and for the last 3 days have had the exact same problem...mini load and reduced crease as well as power light flash right when it comes to drain...?
I have scratched my head and done lots and lots of research, reckon I could design and build my own washer now lol, anyway, I fitted a new pump and ran it, thinking this is it sorted, went out and got a call from our lass...doing it again.
Right, gonna have to get me hands dirty...I removed the drain hose (Ignore the pump for a second, I'm talking about the grey hose that goes from the pump to the sink) from the sink and poked my fingers as far as they would go...debris, I then removed it from the other end (Pump) so I had a long hose in my hands, not attached to anything at either end....cleared it and again, loads of debris (Fluff, plastic etc) and put it all back together...turned the old fella back on and running a wash right now as we speak...happily spinning round at 1400rpm and throwing gallons of water down the sink...I would consider it fixed.
So I can most definately tell you that you have a blockage somewhere mate, I'd get your hands in the toolbox and pull that pipe off, doesn't require any level of experience, just the ability to put things back as you found them...
Hope that helps
Posted on Dec 01, 2008
SOURCE: control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Posted on Feb 16, 2010
Hotpoint aquarius program won't start
Try this. Unplug unit. While unplugged, hold in power button for about 10 seconds. Release plug back in. See if that has reset the control module. Works on some other makes. Can't hurt to try.
Mar 10, 2015 | Hotpoint WML540P 60cm Washer Front...
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
This works
Feb 04, 2008 | Hotpoint Washing Machines
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Hotpoint aquarius deluxe1000 WM22 Its not working........
Surely by now you've checked to see if your water inlet into the machine is good, ie turn on the taps. The machine wont start if there is no water coming in. Try the spin only function, it works??
Sep 17, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
155 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
