Question about Garden
Honda mower carburetor diagram
Petrol mis.no idle run
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Cannot do...
Posted on Oct 22, 2013
  • 22 Answers
SOURCE: Oil coming out of the carburetor of my Honda Harmony 215 mower
unless the ground was a steep slope while mowing or the mower was tipped over 35 degrees or more in any direction except with the handle bars down (spark plug up is ok), it will most likley be a blown head gasket between the pushrod gallery and cylinder. remove the head and get it re-faced then assembly with new gasket. valve adjustments are 4 thou inlet and 6 thou exhaust
Posted on Jul 20, 2009
mickey813
  • 472 Answers
SOURCE: honda petrol mower starts but cuts out
SOUNDS LIKE YOU HAVE BAD GAS YOU MAY TRY CHANGING YOUR GAS
Posted on Sep 30, 2009
SOURCE: Hi, I have recently bought at auction a Honda HR194 Mower
Hey Graham:
Here is an owner's manual for your lawnmower.
sysdoc.doors.ch/HONDA/31VA5030.PDF
Enjoy!
Steve
Posted on Dec 09, 2009
SOURCE: Craftsman lawn mower running bad with Tecumseh
http://www.tecumseh-parts.com/Tecumseh-Parts/tecumseh-vector-engine-and-parts
Posted on Oct 12, 2010
SOURCE: Honda lawn mower surges at
Prev. Post is good but the prob you are having is caused by to much air to the motor. There is a **** peice of plastic gasket between the carb and motor that has a crack in it replace it and all will be better. ( sorry about spelling)
Posted on Apr 17, 2012
How do I fix My Honda hrx217 surges at idle runs ok at load.h
The carburetor has two circuits, a main power circuit and an idle circuit. When the idle circuit gets partially clogged, the governor will drop the throttle shut, the engine partially dies and the governor yanks the throttle back open till the main kicks in. If the idle circuit gets completely clogged, the engine will need the choke partially on to make up for the missing air fuel mixture, will run rich and surge horribly. The carburetor needs to be cleaned out, a can of Berryman's spray can dissolve the crud out and restore operation. 90% of this problem is caused by old contaminated gas
Jul 14, 2016 | Honda HRX217VKA Lawnmower
2008 yardman lawn mower 13.5 hp. has a high idle speed and does not slow down, need diagram for throttle control
Throttle cable should pull a SPRING, which pulls the governor, which pushes/pulls the carburetor butterfly valve.
Aug 12, 2014 | Yard Machines Garden
2006 vtx1300r runs fine but wont idle
Ethanol in the fuel will often lower a bikes idle speed. Honda gives you a simple screw to turn to raise or lower the idle speed on your motorcycle. it is part #10 on the following diagram. http://www.bikebandit.com/houseofmotorcycles/2006-honda-vtx1300r/o/m2927#sch410152 The black plastic knob is located on the left side of the engine, when you are sitting on the bike, under the carburetor. Try turning the knob 1/4 to 1/2 turn clockwise. This should open the carburetor just enough to allow the cycle to idle again.
Aug 16, 2011 | 2006 Honda VTX 1300 R
2001 Honda CG 125 Cargo will not idle
Hi, Eric19573 "ABSOLUTELY" otherwise the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float cracked, leaky or damaged.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Float bowl vent or overflow tube clogged.
9. Fuel flow to carburetor restricted.
10. Intake manifold leak.
11. The gas cap is not venting properly or fuel tank venting system blocked.
12. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
13. Needle and seat stuck closed in the float bowl.
14. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://www.pistonheads.com/gassing/topic.asp?t=1411860
Please help Honda CG125 running probs Easy fix for you clever guys
https://www.demecanicos.com/manuales/honda_cg_125.pdf
https://www.partsfish.com/page/oem-parts-for-honda
Honda CG125 Fan Owner Manual
May 07, 2011 | 2001 Honda CG 125 Cargo
I have a MTD Honda Lawnmower that is having idling trouble. It starts great, but once the chock has disengaged itself the engine surges. If I continue to hold the choke on just a little, it runs just...
Generally this indicates a "lean" condition in the carburetor and there are no adjustments. Depending on your abilities, the best fix is to remove the carburetor and clean all the metering passages/jets. In some cases you are better off just replacing the carburetor. I have seen some Honda carbs. as low as $15-$20. Hope this helps to some degree.
Mar 08, 2011 | Mtd 22" Yard Machine Push Mower
Engine runs for about 30 seconds and stops
Obstruction to fuel flow is a popular cause of this symptom. The metering passages in the carburetor are very small and it does not take much to clog or partially block them. Depending on how comfortable you feel doing the repair yourself you will need to remove the carburetor to clean the main metering jet as well as the idle jet circuit. The main jet is accessible once you remove the float bowl and the idle circuit is generally accessible by removing a phillips head screw located on the top side of the carburetor. This can vary depending on the specific Honda engine you may have. Also be sure you have fuel flow to the carburetor, if the tank vent in the cap is not working properly you can lose fuel flow to the carburetor. Hope this gets you in the right direction.
Feb 17, 2011 | Husqvarna 160 CC Honda OHC Engine 21 in
I need to drain my Honda Activa petrol tank as I need to transport it to Bangalore. How do I do this.
Shut off valve at the bottom of tank. remove fuel line from carburetor and point it into an approved fuel container. Open fuel valve and drain tank. If you have a reserve setting on your valve, turn it to that to get all the fuel out. Then, look the the bowl of your carburetor. At the bottom there is a small drain line. Above that drain line is a slotted screw. Point that drain line into a container and turn the screw left to drain the fuel out of the carburetor bowl. Retighten the screw after it drains. Place your fuel tank valve to off.
Nov 23, 2010 | 2005 Honda Activa
Honda 5hp mower idles up an down
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Sep 19, 2010 | Honda Garden
Mountfield petrol mower HP470 problem with starting -I've checked plug and petrol both ok. It has a Briggs and Stratton engine. Ideas please. Thank you. '
Sometimes you can get by with priming the carburetor a few times or spraying starting fluid into the carburetor, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Aug 01, 2010 | Briggs & Stratton Garden
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
