Question about Samsung Computers & Internet
Delete button keys not working laptop
The delete key (on number pad) on samsung rv510 is suddenly not working. Was fine, then got stuck and deleted everything, now won't work at all. Key is not getting physically stuck - still travels up and down fine. Presume is a mechanical problem?
    Scholar:
  • 141 Answers
Unlikely, good diagnosis though. You don't have much option there: Try a keyboard attached to it to see if that same key on the external keyboard works. If yes it means you will neeed to replace your laptop keyboard.
If it doesn't try to uninstall the keyboard driver and restart. keep your spare usb keyboard just in case, reinstall the driver from samsung support and download website if necessary.
Cheers
Posted on Oct 16, 2013
Pyrhyc
  • 2028 Answers
SOURCE: Toshiba Laptop "Enter" and touch pad not working
This screen should have a 30 second count down, then start Windows normally. If yours doesn't do this, then she may have keyed the automated recovery and interrupter it causing an operating system error or glitch. If this is the case you will need to run a system repair with your recovery or operating system disc. If it does start Windows after the count down, then run a system restore. One of these will take care of your problem. Also, there is no locking command for the touch pad or enter key.
Posted on Aug 01, 2008
rockitman187
  • 2559 Answers
SOURCE: The function key is stuck on my Dell laptop
Just press the funtion key and the Numberlock key
FN + NmLk (Usually on the same key as delete)
Please rate this a fixya
Posted on Feb 08, 2009
SOURCE: keboard stopped working on eee pc laptop some
hi
your keyboard not working
may your keyboard in dust problem firstly u clean your keys
Posted on Feb 27, 2009
  • 4 Answers
SOURCE: ASUS keyboard delete key won't work
are you sure that the key is seated properly on the board? This can easily be fixed by popping it off and checking to see if the 1, or 2, plastic like springs are connect to the key and the board.
Posted on Mar 12, 2009
  • 629 Answers
SOURCE: laptop key repeats or doesn't work at all
what you can try to do is to test an external monitor. If it works fine, try to check for any stuck key on the keyboard and any foreign objects. If all is well, you can request a replacement keyboard from dell if your system is still within warranty.
Posted on Apr 10, 2009
Number pad on hp wireless keyboard not working it was working but all of a sudden it stopped all other keys are working fine
it has a battery , replace it.or you pushed the num lock key.or the keyboard is bad.
does not working mean
key dead, or use wrong key letter actions.
eg, del does not delete, it makes a DOT,
if yes, that is normal.
no PC stated
no OS stated.
so in generic form we can add
wrong driver loaded to that wrong OS.
or virus.
next time post what PC you have, of 1000s made.
1982 to now on Laptop alone.
May 14, 2017 | HP Computers & Internet
Lifebook. Why can't I type on login page?
1. Press the Fn key a few times, it may be stuck.
2. Press the Fn key + the number lock key, your keyboard may be set as a number pad.
3. If you have access to a USB keyboard (e.g. from a desktop) then plug that in and see if it works.
Oct 30, 2015 | Fujitsu Computers & Internet
# six key and delete buttons not working
If you mean the keys are depressed and won't spring back up, then maybe just temporary stuck. I have kept hitting a key many times, hard and it freed up. If that doesn't help then buy a keyboard on EBAY.COM
Jul 20, 2014 | Toshiba Satellite Computers & Internet
I have a MSI CX480.Its keybord not working properly.When i type letters i,o,p,l,k,j,m, numbers are coming.Also my delete key is not working. The main problem is when i turn on the computer, it...
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
Nov 27, 2012 | Computers & Internet
My labtop carnot start Windows 7 and i have no renovere cd. How kan i start it?
During the boot process you will see on the screen to press a certain key usually delete or the F2b key to enter setup
depending on your which bios you have it will differ
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Mar 30, 2012 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
Delete key on laptop not functioning
Hook an external keyboard to the laptop, if okay! replace the laptop keyboard, if no change! there is a device drive issue, do a system restore of your computer back to an earlier time before this happened.
Mar 11, 2012 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
HI I am just new on laptop and.....
You can either right click on the bottom taskbar and click on properties
and add the volume to the taskbar, or you can go to start, control panel,
sound, and turn up the volume.
It depends on what you are using to send email, outlook express
or a email like yahoo,hotmail. live google, if you use one of these
you do it with these site.
The touch pad has two buttons, it can do everything a mouse does.
The touch pad just moves the mouse, the left and right button is the same as mouse buttons.
Feb 08, 2010 | Acer NSK8458AN Keyboard
Need to delete a name and phone number from the phone book. No delete key on key pad
Not sure if this is the same phone, but when I enter a number/letter, the "Mute" button serves as a backspace/delete function. So what I did was go to Menu>Directory>Review, scroll to the contact I wanted to delete, and press "Mute", which asks me to confirm to delete the contact. Hope this helps.
Jul 08, 2009 | Vtech DECT 6.0 Digital Cordless Phone
Laptop halts as it turns on!
hi mushahid3,
I hape your labtop is ok every thing
but labtop can not load os and cannot open bios
You go to the bios setting can not press "del" you press F2 and delete key ok than you go to bios and chack hardware setting
ok thanking you
Apr 29, 2009 | Computers & Internet
Speaker key and deleting voice mails
you hit the speaker button on the left side of the phone and the pad shows up...
Apr 22, 2008 | LG Prada KE850 Cellular Phone
Computers & Internet Logo
131 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
