Question about Electrical Supplies
Nikota generator GSa-M12B
What is the amperage of the 140V/240V plug
3 Suggested Answers
SOURCE: i have a nikota 3500, 6.5 hp generator where can i
caall cummins crosspoint 304-769-1012
Posted on Aug 31, 2010
  • 32 Answers
SOURCE: My Nikota 3500 watt 6.5hp OHV Engine Electric Generator all of a sudden quit running. I am getting gas and fire to the plug,but it wont start. I am lost and need help.
replace the gas with fresh and treat it with Startron additive to fight against the ethanol in gas and keep it fresh. gas goes bad in a bout a month if not treated now. you might have to take the carb bowl off and clean the carb. good luck hope this helps
Posted on Feb 23, 2015
Greetings: I have a 3500 wts 6.5 Nikota generator, turn on and off several seconds. The carburetor is fine, ignition, too. The shoot off well, I would like to give me an idea that can be
you saying it wont keep running
you have spark at the new spark plug
fuel is fresh and uncontaminated
could be
the coil or the plug lead
ok when cool ... fails when hot
the Governor setting
carby jet blockage
if a four stroke a valve adjustment might help
Oct 12, 2016 | Electrical Supplies
I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can check.
All Power America APG3535CN, 2800 Running Watts/3500 ...
www.amazon.com/...Power...Generator/.../B000U0OJ...
Amazon.com, Inc.I then call All Power and am told to give them one more day to get this worked out ....There is no styrofoam enclosure or crate to protect it, the generator is simply ...
NIKOTA 3500 WATT GENERATOR - YouTube
? 0:58
https://www.youtube.com/watch?v=NEeu9Y-0_KM
Aug 27, 2011 - Uploaded by mamasboypowersports
NIKOTA 3500 WATT GENERATOR. ... Diagnosing A GeneratorThat Has No Power Output. - Duration: 3:03. TheDIYGuyDOTnet 117,263 views.
I have a nikota 3500 watt generator and I am not getting any ...
www.fixya.com/support/t26062098-nikota_3500_watt_generator_am_not
2 hours ago - I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can ...
Generator outputs low variable voltage, ideas for troubleshooting ...
www.smokstak.com > ... > Generators & Motors General Discussion
Jan 20, 2016 | Electrical Supplies
Feb 23, 2015 | Electrical Supplies
Nikota 06041
1/4" gas line can be bought at any Auto Parts place. Any generic shutoff can be bought there too.
Dec 09, 2013 | Electrical Supplies
I have a coleman powermate maxa 5000 er Generator. Model # PM0525202. The powercord plug came loose and burnt the plug and the receptical(240). I replaced the plug and receptical and I am not getting...
If this is the model I am thinking of, there are 3 outlets. One 240V (L1, L2, Neutral and Earth ground. Some models use a 3 terminal receptacle that combines Neutral and earth.), one 120V receptacle (L1, Neut, earth) and another 120V receptacle (L2, Neut, earth).
If you verified fuse and circuit breakers are good, turn on the generator and verify you get 120V on each of the two outlets. Measuring between the narrow blades of the two 120V outlets should be 240V.
***Shut off the generator.
With a test light or ohmmeter, check continuity from the earth terminal of 120V outlets to 240V outlet. Likewise for neutral (wider blade on 120V outlet). Lastly, check continuity from Narrow blade of each outlet to the 240V outlet.
I suspect that you miswired neutral and earth. On a 4 wire PLUG, it is customary to connect earth and neutral.
Work safely so you can give feedback.
Aug 30, 2017 | Coleman Electrical Supplies
Can my 1/2 hp Jacuzzi water pump 240v be run on a generator
If your generator puts out 240 volts and has the amperage to handle the pump load, I believe it can. Your generator installer could answer that.
Dec 04, 2010 | Jacuzzi Brothers 1/2 Hp 8gpm 2 Wire...
Plug wiring diagram for 240v outlet 7000w blackmax
Probably its similar to the wiring on page 31 of this manual (pdf page 28) of this manual, reference NGK-7000HE: http://www.electricgeneratorsdirect.com/manuals/NGK%20Generator%20Honda%20engine.pdf
Dec 25, 2009 | Electrical Supplies
I have a Nikota electric generator 3500 watt 6.5 h.p. ohv - I need a part for the carburator base, where i find this parts?
I also have a NIkota 3500 generator, which had a carberator problem. I just ordered a new carb from Yilong-motor.com in China. They may be able to help you. RJL
Aug 20, 2009 | Coleman Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
