Question about Precor 9.21 Treadmill
HRTL motherboard has burned, can you tell me where or if I can find replacements
    Top Expert:
  • Precor Master
  • 12,223 Answers
Go to www.fitnessrepairparts.com
God bless you
Posted on Oct 17, 2013
The motherboard of my ELNA 9000 burned and needs to be replaced
Hi Chrissie, I'm Julie. The technician who checked your machine is likely to be the best person to suggest if the burnt out component can be replaced, or whether a new motherboard is needed. The technician should also be able to order a new motherboard. The replacement of the component or motherboard is best left to the technician or service personnel to carry out. It's not a DIYable task.
Aug 05, 2015 | Elna Sewing Machines
I have an hp g4, my ic is burned out is there any replacement?
What you need to ask yourself is Why did the IC burn out. You may risk replacing the ic and some other fault with the motherboard burns out the new IC.
Jan 26, 2014 | HP Computers & Internet
Motherboard wont go into post wont start the screen or keyboard tried new bios battery and clearing the bios
1-turn on the PC for seconds without CPU's fan and see is it getting hot or not.
(if not, it means your cpu is burned and you should change it)
or
2- if you got more than 1 Ram memory, turn on your pc with one of them because sometimes one of the Rams had damaged or Rams are incompatible one another.or try with a Valid Ram.
if it doesn't work:
unfortunately i should tell that your Motherboard is completely burned and you should buy a new one.
However please don't forget vote.
Jan 11, 2011 | ASUS P5N73-AM Motherboard
After power on my Acer Veriton 6800 only beeps continously. No VGA Signal, no interaction possible. Motherboard is original, no modifications made. Intrusion sensor is jumpered. Can anybody help?
Either the power supply has failed, or the motherboard. Or possibly the CPU was overheated and burned itself out from cooling fan failure. Smaller possiblity is memory went bad. You should first check the memory, by removing it, blow out the sockets with can of air, then replace one at a time. Try to start PC after 1st one. then remove it and try the other one. Any change evident?
Look at the capacitors and other components on the MB , any sign of swelling, bursting or burning?A new MB will run about $100.
With out being there, it's hard to tell what is wrong.
Nov 10, 2010 | Acer Veriton 6800 PC Desktop
When the refrigerator is turned on, the compressor does not start and there is a clicking of a relay on the mother board.I have replaced the condensor fan motor as it was froze up, and now when the relay...
replace the mother board,if recently lights burned out in the unit and on some the digital read-out is also dark,the motherboard got a power surge and is defective,its in the rear side of the unit and will have a burned spot on the circuit trace,another tell-tale sign of this is if the new light bulbs are strobing and will not light fully
Feb 20, 2010 | Refrigerators
New ower supply but computer still no comming on
sounds like a burnt motherboard to me. Replace with similar MB that has same socket for processor and same slots for RAM. A decent MB will run you about $40-70 as long as it isn't a gaming system or something.
Jul 03, 2009 | Medion M3 Composer 5100 PC Desktop
Problem identifying P4G533-LA motherboard electronic component
Its a diode but where can u find it ? Before replacing this check your powersupply. The parts number will be the same as beside.
Try carefully. You have a small hope.
Feb 14, 2009 | Computers & Internet
Motherboard
what i would do is contact the manufacturer of the computer and see if they can send you one you might be able to burn one off of the internet but be carefull regards mike
Aug 20, 2008 | Intel Motherboard
Motherbord mosfet burning frequently
repair your motherboard again then have your power supply unit replaced... there may be something wrong with your power supply output voltage..
Aug 01, 2008 | ASUS P4GE-MX Motherboard
CD BURNER
Try to replace with another one?so recorded any change?if it will burn fast the let me know.
Mar 20, 2008 | Intel Motherboard
Precor 9.21 Treadmill Logo
57 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
