Question about Sharp EL-1197PIII Calculator
I just did a long running total and wondered if there was a way to reprint this a second time, instead of having to go back and in reenter all the same info a second time. Basically I need two running totals but wanted to input the info only once. Is this do-able?
  • 68 Answers
No, just make a photocopy
Posted on Oct 16, 2013
Why does it just print once, then the second time it prints half and shows an error?
This happened to me. What I did that worked was first unplug the power cord. Open up the printer where you can access the ink cartridge. Check for any paper jam or debris. Clean that out. move the cartridge all the way to right and slide it back and forth about 5-8 times. Plug the cord back in and try to reprint again. I hope this help.
Jan 29, 2016 | Epson Impact TM-U220B Thermal Printer
NEED TO REPRINT RECEIVED FAX HP OFFICEJET 4500
Yes, You can.
Press Settings (The Wrench Button)
Navigate to "Print Report" - Press OK
Navigate to "Reprint Faxes" - Press OK
"Reprint All Faxes" - Press OK
Or Navigate to "Reprint One" - Press OK
Navigate to Date/Time Received of fax to reprint - Press OK
May 19, 2012 | Brother IntelliFax-2820 Laser Fax
My home page freezes after a few minutes of inactivity. If I have another internet site open, it will also freeze. Then when I click on my home page it is totally white. I then refresh my home page and go...
I would run a good virus or malware program, there are some very good and free ones available. Try Malwarebytes, AVG and Spybot S&D, all available free and all very good. Hope this helps.
Jan 21, 2012 | Toshiba Satellite A505-S6975 Notebook
Printer reprinting the allready printed pages
Make sure that your document that u r printing's page size is set to A4!Good luck!
Apr 05, 2010 | Canon Office Equipment & Supplies
HI,when I print , the printer do some label , after go in pause mode automatically message=" = continue = reprint" but after 1o label , the printer give a second error "out of ribbon" .Can you help me...
Hello
After many efforts I have found that in the new PX6i models, the "transfer ribbon mechanism" (the wheel that is responsible for making the ribbon roll) appears to be defective. What happens is that when rolling back in order to keep the ribbon stretched, instead of stopping at the fixed point, it continues to roll back a bit. After a few prints, this causes an "out of ribbon" error.
The solution: replace this part with a VALID part (a new one).
Pavel
Feb 08, 2010 | Intermec EasyCoder PX6i Thermal Label...
Reprinting faxes already sent
Sorry, but, no...facsimilie machines have memory, however this memory is reserved for error conditions only (ie; out of paper, out of toner, out of ink, paper jam,etc.......) Unfortunately, if all faxes that were sent, were able to be recovered, it would take over a terra bite (or Tb) hard disk drive to "remember" or save these documents.....If you need the same document(s)...I would suggest that you ask the person to fax it (them) back to you.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=337&modelid=10116
Try this site for guides and further assistance. Hope this helps.
Aug 07, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Second hand moves every 4 seconds
the battery need replacing this is what its supposed to do when batt low. if this helps please rate joe
Nov 20, 2008 | Watches
Xerox m15i blank copies prints great exposure lamp only come on during warm up then never come on again i turn off then back on. what to replace main board or scanner?
Sounds like the lamp itself is bad. You will need to replace just the scan head , not the entire scanner assembly.
First of all, try a couple of things.
Try a memory clear, but print out your phone book and dialer numbers, but here is that procedure..
1. Enter Tech Mode by pressing MENU-#-1-9-3-4. (You will see "TECH" in the display.) 2. Press "MENU" then press the Down Arrow until you get to MAINTENANCE. Press "Select." 3. Press the Right Arrow until you get to "MEMORY CLEAR." Press "Select." 4. The first option will be "CLEAR ALL MEMORY." Press "Select." NOTE: The option to do a Total Memory Clear is available ONLY in Tech Mode. If the option does not come up in MEMORY CLEAR, go back to step 1 to try reentering Tech Mode. 5. After the machine clears memory, reenter (or upload from your PWS) all System Data and Phone Book settings. (If necessary, run a System Data report and compare it to your original report to detect any changes needed.)
May 01, 2008 | Office Equipment & Supplies
Poor copy quality
If you have reprinting images like that, the fuser heat roller is work out. What happens over time is the teflon coating wears and the ink starts to stick to the roller instead of fusing properly into the page.
Once the ink starts sticking to that roller, you get reprint and it just continues to get worse.
Either the heat roll or the fuser itself will need to be replaced.
Mar 18, 2008 | Brother DCP-8040 Copier
Ghosting
No. you can not run it back through a laser printer. the toner will melt in your customers printer. Tried this, and reprinted using offset.
Mar 12, 2008 | Xante Ilumina Digital Color Press Printer
Sharp EL-1197PIII Calculator Logo
41 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
