Question about Electrolux Vacuums
Renny starts as soon as the unit is plugged in....leave the hose off and the unit will not start until the hose is connected
  • 2 more comments
  • fggmplus Oct 21, 2013
    Obviously you are not familiar with Vaccuum Cleaner by Electrolux.....Yes It is a Renny.....
  • JoeVacs Oct 22, 2013
    I am quite familiar with Electrolux vacuum cleaners actually. I have been a vacuum cleaner repair technician for over 25 years. I have never seen one called a Renny. If you are in Europe, that could be the reason as there are different names and different models over there.
  • fggmplus Oct 22, 2013
    Did not mean that you have not worked on vacuum cleaners, but to the avid Electrolux Dealer and Repairman of Electrolux its nickname is Renny and is short for Renaissance, in addition they were manufactured in the 1990's.
    The Renaissance is the machine that started the bankrupcy of Electrolux. Most of them had defective electronics within the warranty period and put a heavy strain on the company financially.
  • 694 Answers
This is a problem that needs to be checked at an Aerus Electrolux store. They have the tech manuals to troubleshoot the specific problems with the Renny (Renaissance). There are three possible problems involving the electronics in either the hose handle or the canister.
When the problem was first noted, customers brought their vacuums in and the service managers simply replaced the hoses. That resulted in burning out the boards in either the new hose or the vacuum, increasing the cost of warranty repair/part replacement. Electrolux quickly sent out service updates letting the service personnel know to stop the practice immediately. I can't remember how long it took before we finally got the proper troubleshooting data, but yes, there were a lot of problems with many of the machines. Fortunately for the store I worked at, there weren't many.
Posted on Jan 13, 2014
Have a Dyson v6 for several months. Roller brush stops turning a soon as I start to push forward after staring trigger. Examined & cleaned roller & surrounding head & find no objects interfering.
The Dyson V6 has an electric motor in the power head. The battery is in the handle unit. So power has to get from the battery head unit down to the motor at the floor roller brush. The way they do this is to send the power around the plastic debris cup that you empty, and then into the connector for the tube and out the bottom of the tube to the roller brush motor. Your problem is probably that there is a lost contact along the way. Try plugging the roller brush directly into the head unit leaving the tube out and see if it is intermittent or if it runs fine. In that case the problem is one of the contacts associated with the down tube. If the roller brush is intermittent even when plugged directly into the head unit, then the problem may be the connection associated with the debris cup. remove the cup and make sure the contacts are clean. Hope this helps. G
Oct 26, 2016 | Dyson Vacuums
Hi! My central vacuum has worked perfectly until just a couple months ago. I went to plug the vacuum in and it didn't automatically start the suction. When I clicked the switch to the right on the...
It sounds like you may have a bad hose. Plug the hose into the wall but rotate it 90 degrees from the normal position. This will bypass the switch on the hose. If you look at the wall end of your hose, you will see a metal band around it. That metal band is split into two sections. You are trying to plug in the hose so that the separation of the two pieces of metal is not lining up at the top of your inlet. If your vacuum turns on then you have a bad hose. It is possible that you have a bad switch in the hose, but it is more likely that you have a bad hose.
If your vacuum does not turn on, then you may have a break in your low voltage wire somewhere. You can check to make sure it didn't get disconnected at the unit. If the wire is connected then try to cross the low voltage wire from the relay at the unit with a small screw driver. If the unit does not turn on you have a bad relay.
If it is the relay, AirVac does not provide them. You would need to consider buying a new unit.
Jul 17, 2011 | M&S Systems AirVac AVP1200 Platinum Series...
I have a K5.140 It has an intermitant fault, more fault than clear these days, unit is just over 1 years old, Problem is No power to motor, water pressure Good, Power Supply ON, guess there is a water...
Most likely the hose pipe has nothing to do with the problem. Most likely is a loose connection and as time goes by the connection gets looser, which causes failure rate to increase. Once until is on, the power flowing through the loose connection helps keeps it connected. Open the unit and wiggle this and that until to can isolate the actual cause of the problem. Try not to shock yourself.
Jun 11, 2011 | Karcher Vacuums
The Vaccum is not turning on when i plug the hose into the wall. The hoover system will turn on when i turn the switch on at the base and wont go off till i turn the switch off. But it will not come on...
you can test this out by taking a small metal spoon and with the bottom side of the spoon insert it into the vac outlet on the wall. you want to touch the two metal pins inside the vac outlet to test if the unit is the problem or the hose is the problem.
If the unit starts, the hose should have a 3 year warranty on it. I recommend you have your nearest beam dealer check it out.
If the unit does not start, it has a 7 or 10 year warranty, the circuitry should be replaced. Again have your nearest beam dealer check it out.
good luck
Nov 06, 2010 | Beam Industries Vacuums
Kenmore 25614/25615 Progressive bagged canister vac won't start
sounds like there was a loose connection or loose wire that came in contact with another wire. check your cord for small burn holes, also could have shorted out in the hose or the wand. If you are comfortable to disassemble the vacuum i can walk you through the troubleshooting process so we can find out what actually went bad. id start with the cord though. let me know if you have any questions or need more assistance
Jan 04, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
My Renny brush is not moving what do I do? I just had is serviced for $200 and brought it back once already, he is claiming now that it is the circuit board. I do not trust him to fix the problem, can I...
You have two circuit boards in th Renny, one is in the handle of the hose and the other is called a triac located next to the motor in the canister. There is a long and drawn out procedure in trouble shooting the problems with the Renny and if you don't know what to do, you will be in more trouble than you are now.
The best thing is to find a reputable Aerus/Electrolux dealer/shop and have them to find what the problems are.
Joe
Nov 05, 2009 | Electrolux Vacuums
Electrolux C104A does not turn on. won't start. No light on, no sound. Is there any fuse to be raplace and/or ?
The Renny is a hard machine to diagnose. You could have a broken wire in the cord or in the hose. There is a fuse wire located inside the canister that could be bad.Also, the handle circuit board2.gif could be bad or the triac (another circuit board) located inside the canister could be bad. There is no use for you to open the machine. You could do more damage than good.
Jul 06, 2009 | Electrolux Guardian Bagged Canister Vacuum
Renaissance C104A does not turn on. I plugged it in and it does not work.
The Renny is a hard machine to diagnose. You could have a broken wire in the cord or in the hose. There is a fuse wire located inside the canister that could be bad.Also, the handle circuit board could be bad or the triac (another circuit board) located inside the canister could be bad. There is no use for you to open the machine. You could do more damage than good.
NuTone CV353 Central Vac does not start when hose is plugged into
Try to plug the hose in sideways. So the top of the hose is rotated 90 degrees. If the unit turns on then there is something wrong with the hose. It might be a short or it could be a bad switch on the handle. If the unit still wont turn on I would think that maybe the low voltage wire got disconnected from the unit or there is a break in the low voltage wire somewhere along the way. Let me know if you plugging the hose in sideways works.
Feb 22, 2009 | Broan-NuTone CV353 Central Vacuum
Vacuums Logo
82 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
