Question about Health & Beauty
HOW DO YOU TAKE THE SEAT OFF. - Health & Beauty
The lever for turning the seat pull it up at the same time lift seat off simple
Posted on Oct 19, 2013
Seat won't move forward, cant get to the rear bolts to remove seat because seat is back as far as it can go is there any way to move the seat manually
You must remove the seat from the power seat transmission then remove the drive motor from the seat transmission, move the seat to the desired position and reinstall the motor to lock it in place. The seat transmission is bolted to the seat mounting bracket/rails.
Feb 01, 2017 | Seat Cars & Trucks
Seat heater comes on by itself in 2004 yukon denali
Heated Seat Components
The heated seat system consists of the following components:
• Driver and passenger heated seat switches
• Driver and passenger seat back heater elements
• Driver and passenger seat cushion heater elements
• Driver and passenger seat back temperature sensors
• Driver seat module
• Driver door module
• Passenger door module
When there are modules involved in the operation of any componet that's acting up , the module's electronic's could be the culprit ! But without testing who's to say what the problem could be !
I would have it check for DTC'S
DTC B2425 or B2430
The driver and passenger seat heaters are controlled by the driver seat module. Power is supplied to the driver seat cushion and back heater elements through individual voltage supply circuits. Power is supplied to the passenger seat cushion and back heater elements through a common voltage supply circuit. All of the driver and passenger seat heater elements are grounded by the driver seat module through individual low side drive control circuits. The heater element control circuits are pulse width modulated to ground by the driver seat module in order to control the seat temperatures by regulating the current flow through the heater elements.
DTC B2435 or B2440
The driver seat module relies on inputs from thermistors installed in the driver and passenger seat backs to control heated seat temperatures. The thermistors are 2-wire sensors supplied with a 5-volt referenced signal circuit and low reference circuit from the driver seat module. Resistance through the thermistors varies with temperature causing the heated seat sensor signal circuit voltage levels to decrease as the seat back temperatures rise.
Install a scan tool.
Start the engine.
Turn the heated seat ON.
With a scan tool, observe the Heated Seat Sensor parameter in the data list for the driver seat module.
Does the scan tool indicate that the heated seat sensor parameter is within the specified range?
0.078-4.94 V
Dec 08, 2016 | GMC Yukon Denali Cars & Trucks
Seat removal on 2009 harley softail deluxe
To install slide the retention nut over the tapered end of a cable tie strap so
that the larger O.D. of the nut rests on cable tie strap eyelet, then from the bottom of the rear fender feed the cable tie strap up through the fender hole, with the tab on the retention nut seated in the notch in the fender hole pull up on the cable tie strap to locate the nut snug up against the underside of the rear fender and then from the side opposite the tab i.e. from the rear of the fender slide the retention washer onto the nut which will lock it in place.
The FXST/FXSTB seat attaches with a single thumbscrew on the seat bracket. When installing a seat insert the tang at the front of the seat into the channel in the frame and install the single rear thumbscrew which Harley- Davidson has a special tool for which I have never even seen, pn HD-47190.
The FXSTC seat attaches with two fasteners through the sissy bar. When installing the seat the tang at the front of the seat is inserted into the channel in the frame and the two rear fasteners go through the and get tightened to 60-80 in-lbs (6.8-9.0Nm).
The FXCW/FXCWC Solo Seat is attached with 2 locating pins that for removal must be removed from their grommets by lifting the rear of the seat, then the seat is pulled to the rear to disengage the tongue from the frame. To install the seat put it on the frame, slide the seat forward until the tongue locks into the bracket, push the seat forward to align the two locating pins with their grommets and then push the seat down to engage the locating pins.
The FXCWC rider Seat is removed by tipping the seat up and towards the fuel tank, the two fasteners are removed and the seat is then taken off the bike. Do the reverse to install the seat and tighten the fasteners to 90-110 in-lbs (10.2-12.4 Nm).
The FXCWC Passenger Seat Support is removed by tipping the rider seat up and towards thefuel tank removing the two screws and washers from one pillion support, removing the pillion support and the rear seat pillion, then removing the remaining pillion support. To install it install one pillion support but do not tighten its fasteners, install the wave washer and bushing on each pillion support, install the pillion and the second pillion support and tighten all of the fasteners to an initial torque of 30-35 ft-lbs (40.7-47.5 Nm), then loosen the fasteners and then final tighten them to 38-42 ft-lbs(51.5-56.9 Nm), check the rider seat operation and then lower the rider seat into position and engage the locating pins into their
grommets.
To remove the FLSTN/FLSTF/FLST/FLSTC seat remove the passenger seat and seat mounting fasteners. When installing the seat insert the tang at the front of the seat into the channel in the frame and install the seat mounting nuts, then install the passenger seat.
To remove the FLSTSB seat remove the screw from the seat hinge at the front of the seat, raise the rear of the seat only slightly during removal or installation because pivoting the rear of the seat up too high can cause the nose of the seat to damage the leather trim panel on the fuel tank., to disengage the springs from the seat spring mounting pins and remove the seat. To install the FLSTB seat align the seat hinge with the mounting bracket on the frame, insert the screw into the seat hinge from the right side of the motorcycle and tighten it to 14-16 ft-lbs (19.0-21.7Nm), align the bushings on the seat springs with the mounting pins and push the rear of the seat down to engage the seat spring mounting pins. The seat position may be adjusted forward or rearward for rider comfort by removing the seat, removing the nut on the seat hinge, removing the bolts from the seat spring support bracket, (the seat hinge and seat spring support bracket must be installed in the same position in either a forward or a rearward configuration for the seat to fit properly on the motorcycle). To position seat forward install the hinge with the front tab in the slot, install the seat spring support bracket with the springs toward the rear of the seat. AND to position the seat rearward install the hinge with the rear tab in the slot and install the seat spring support bracket with the springs toward the front of the seat., THEN install the nut on the seat hinge and tighten it to 20-25 ft-lbs (27.1-33.9 Nm), install the screws for the seat spring support bracket and tighten them to 15-20 ft-lbs (20.3-27.1 Nm) and then install the seat.
May 18, 2014 | 2005 Harley Davidson XL 1200 R Sportster
Take the seat off
  • Open tool box, at rear of seat, with key and unhook or unbolt the seat from inside tool box.
  • Pull lever on right or left side, up under the seat. It can also be at the rear of the seat, right or left side, again up under the seat. Lift seat off up and to the rear. Sometimes it's hooked on both sides with a rod or cable connecting both sides. These can break. Make sure both are unhooking.
  • Same as above only you use a key.
  • Remove the two bolts on either side at the rear of the seat. Pull seat to rear.
  • Nuts or bolts, at the rear and below seat, under the rear fender Remove bolts holding down the rear seat . Remove seat and then remove two bolts, at the rear, holding the front seat on.
  • Unlock lever on side of seat. Seat then pivots on two hinges to open. Can open to the right or left. Might have no lock.
  • Push button on side. Left side, I haven't found a push button on the right side... yet ! Can be locked or unlocked with a key.
  • Pull lever at front of seat, right or left side. Seat lifts up with the hinge at the rear.
  • Pull lever at rear of seat, right or left side. Seat lifts up with hinge at front.
  • Pull lever at front of seat, right or left, and whole seat comes off. Seat has pegs underneath that fit into rubber grommets on the frame.
  • Dec 10, 2013 | Motorcycles
    Handlebars are bent
    Instructions
    YZF600R (1994 - 2007)
    Insert the ignition key into the seat lock, located on the left side of the tail fairing above the left passenger foot peg. Twist the key clockwise to release the seat lock mechanism.
    Grasp the rear portion of the seat and lift it off of the motorcycle's subframe. Pull the front of the seat away from the gas tank until the tab under the front of the seat is free of the subframe.
    Hold the seat over the subframe to reinstall it. Hook the seat's tab under the cross-member below the base of the gas tank.
    Push the seat forward slightly, then lower the rear of the seat onto the motorcycle's subframe.
    5
    Push down on the rear of the seat until the seat lock mechanism clicks into place. Remove the ignition key from the seat lock.
    YZF-R6 (1998 - Present)
    6
    Insert the ignition key into the seat lock on the left side of the tail fairing. 2006 and newer R6 models place the seat lock under the tail fairing, near the left rear foot peg. Twist the key clockwise to release the seat lock mechanism.
    7
    Grasp the rear of the passenger seat and lift it up slightly. Pull the seat toward the rear of the motorcycle until the hooks under the front of the seat are free of the tabs built into the subframe under the tail fairing.
    8
    Pull the rear corners of the rider's seat up to reveal both mounting bolts. Unscrew the bolts with a 5 mm Allen wrench. Lift the rear of the seat up, then pull it away from the gas tank until the tabs under the front of the seat are free of the cross-member below the base of the gas tank.
    9
    Slide the rider's seat tabs under the frame cross-member to reinstall the seat. Lower the back of the seat onto the subframe, then screw the mounting bolts into place with a 5 mm Allen wrench.
    10
    Hook the front of the passenger seat onto the tabs built into the subframe under the tail fairing. Lower the seat onto the fairing and press down until the seat lock mechanism clicks into place. Remove the ignition key from the seat lock.
    Jan 15, 2013 | Yamaha XT 125 X Motorcycles
    How to remove back seat in 1972 buick skylark
    Remove the seat cushion retaining bolts, detach the seat cushion and remove it up and out from the vehicle.
    Remove the rear seat back retaining bolts at the bottom of the seat back. Pull up then out to disengage the upper frame from the hangers and remove seat back from the vehicle.
    Installation is the reverse of removal.
    Courtesy: Haynes GM repair Manual #38025. You can probably find a copy of it on Amazon or eBay cheap
    Jun 20, 2011 | Buick Skylark Cars & Trucks
    Remove front seat
    SECTION 501-10: Seating 1998 Escort/Tracer Workshop Manual REMOVAL AND INSTALLATION Seat —Front Removal
    NOTE: Driver side seat shown, passenger side seat similar.
    1. Slide the seat to its rearward position.
    1. Remove the front seat track to floor front bolts.
    1. Slide the seat to the forward position.
    1. Remove the front seat track to floor rear bolts.
    1. Disconnect the safety belt warning indicator switch electrical connector.
    1. Remove the front seat.
    Dec 06, 2009 | 1998 Ford Escort
    Middel seatbelt will not loosen
    I think you have to remove headrst bfore folding seat back down. You may have to unbolt seat from floor. 4 bolts.
    Rear Seat Backrest —Split Bench Removal
    NOTE: The 40% rear seat backrest must be removed before the 60% rear seat backrest.
    1. Remove the 40% rear seat backrest.
      1. Remove the nuts and bolts.
      1. Remove the backrest.
    1. Remove the 60% rear seat backrest.
      1. Remove the nut and bolt.
    Installation
    NOTE: The 60% rear seat backrest must be installed before the 40% rear seat backrest.
    1. NOTE: Do not tighten the nut and bolt at this time.
      Install the 60% rear seat backrest.
      1. Install the rear seat backrest.
      1. Install the nut and bolt.
    1. NOTE: Do not tighten the nuts and bolts at this time.
      Install the 40% rear seat backrest.
      1. Install the nuts and bolts.
    60/40% rear seat backrest
    1. Tighten the 60/40% rear seat backrest nuts and bolts in the sequence shown.
    40% Rear Seat Backrest
    1. Tighten the 40% rear seat backrest nuts and bolts in the sequence shown.
    Jun 11, 2009 | 2005 Ford Escape
    How do you remove the headrest on a 1996 ford crown victoria?
    Head Restraints Each front seat is equipped with dual-post design front seat back head restraint (611A08). The front seat back head restraint is installed as follows:
    • It travels on dual posts which have notches to engage a spring-loaded catch in the guide.
    • The front seat back spring assembly retains the front seat head rest guide rod sleeve (610A16).
    • The front seat back head restraint is adjustable from its normal position to a raised position of approximately 25 mm (1 inch).
    • Pull up on the front seat back head restraint to raise it. Pushing down will return it to its normal position.
    Removal
    1. Unscrew front seat head rest guide rod retainers (610A18).
    1. Pull up on front seat back head restraint (611A08). Compress foam in area of front seat head rest guide rod sleeves (610A16).
    1. Remove front seat back head restraint positioning springs. Pull front seat back head restraint up and out.
    Installation
    1. Slide front seat head rest guide rod retainers onto front seat back head restraint posts.
    1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves.
    1. Insert front seat back head restraint posts (notches on posts facing rearward) into front seat head rest guide rod sleeves and push down to engage positioning spring.
    1. Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves.
    1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve.
      Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint.
    Mar 01, 2009 | 1996 Ford Crown Victoria
    Removing the seat of V-Star 1100 Classic 2001?
    is this just the seat itself or the seat cover? if its the seat assembly there should be 2 bolts holding the seat down located somewhere around the rear of the seat aprox 2 inches below the seat. if your talking about the seat cover you have to remove the staples thats holding the fabric down to the seat pan.
    Jan 27, 2009 | 2001 Yamaha V Star 1100 Classic
    Health & Beauty Logo
    22 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
