Question about Royal Dss Pro Shipping Scale
Where does the power unit plug in on scale - Royal Dss Pro Shipping Scale
How do i get aquantum ml 29032 scale manager manual?
A Scale Manager kit comprises of the following:
  • One computerised electronic water descaler
  • One 12 volt power supply, cable length 1.8m - 6?
    Optional when ordering, 5m - 16½' power supply extension lead
  • Antenna cable with red plug
  • Antenna cable with black plug
  • Five plastic cable ties (1 spare)
  • One attachable black antenna plug
  • One attachable red antenna plug
Please Note: Ensure antennae cables do not come into contact with each other
  • The gap between the coils must be in excess of 60mm - 2½" no upper limit
  • Coils require a minimum of 50mm - 2? each side of uninterrupted straight pipe
  • Direction of coils is essential - see over
  • Ideally a 125mm + (5?+) straight run of pipe is required for each antenna coil
  • Direction of Water Flow is immaterial
  • Connect red plugs to red sockets and black to black
  • Scale Manager is effective on all pipes (copper, plastic, lead, steel etc)
  • Performance is not impaired if the pipe is painted
  • The Control Unit can be fitted at any angle or plane
  • A 13-amp socket is required for the power supply
The ideal location to install Scale Manager is near the entry point of the rising main, before any junctions. The antennae coils operate independently and can be positioned on separate pipes should you not have an uninterrupted pipe run of 250mm - 10?. Should the inlet pipe T off within 125mm - 10? of the stopcock, position the coils as fig 1 overleaf. If the inlet pipe available is over 125mm - 5? but under 250mm - 10? position as fig 2 overleaf.
The antennae coils require a minimum gap between them of 50mm - 2?. It is also necessary that the coils are at least 40mm -1½" from elbows and junctions.
Dec 30, 2016 | Health & Beauty
I have a tec SL39N digital scale. When I plug it in the mumbers appear across .. 111111. 222222. 333333 etc. It goes to 9999 and then goes back to 88888and the 8's keep flashing. Help! Thank you.
Good Evening Paul, and Happy Holidays.
You can view the manual for your scale here:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwil1tu6oeTJAhUG_mMKHRbRBMkQFggdMAA&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F4%2F4249c7d6-8aca-4d71-82c7-2a6ad53f509b.pdf&usg=AFQjCNHFxSA5IvPtpNw0tHJgBjUjLNtxQg&sig2=yTmgL-Oxe95lCTHu4KY_Lg&cad=rja
It makes mention in several places about the scale displaying flashing 1111111 and flashing 8888888 displays, which fortunately appear to be signs of it turning on and saying 'ready'. Some of the display action appears to be affected by how long the gap is between when the scale is plugged in and when the power switch is turned on.
Hoping this helps!
D
Dec 18, 2015 | Health & Beauty
Avery H500/L200 Avery Weighing Scales For ForkliftTruck When scales powered on, screen displaying ''balance limit''. Scales will not function.
The zero capture is out of the 2percent tolerance so the cell is either faulty or requires zeroing. Open the unit and press the micros itch on the left of the board. The display flashes s. Press the zero key to change to flashing E. Press store to scroll to zero balance. Press semi auto tare. This captures zero without clearing the span calibration. The display will scroll around for a short period when complete press store.. Release the micro switch and scale will go thru warm up routine then display zero. Hope this helps, regs Darren.
Sep 28, 2011 | Health & Beauty
How switch the unit?
sometimes depending on the scale you have if there is not a units key you have to turn the power off, then while holding one of the other keys down, turn the power on and the units will change. if something else comes up that doesn't make sense just power the scale off and when you turn it back on it will be back in weigh mode
Mar 09, 2010 | Health & Beauty
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
Humidistat know set to on. Water pressure to
Have you checked to see if the solenoid opens and closes? You should hear a distinct click when the solenoid valve energizes. Depending on the quality of the water in your area, it's possible that the valve is scaled up....again and plugged. If the valve operates, you can usually clean it with a product called CLR which dissolves scale (lime buildup). This will require removal and disassembly of the valve. Please be sure to turn off the power before working on the unit.
Some solenoid valves are equipped with an inlet screen that could also be plugged with scale or debris.
Dec 08, 2009 | Aprilaire 550 Humidifier
Say it in English,not British
1. Turn the unit on.
2. At the same time, press and hold the "G" button and the power button.
3. While continuing to hold down the "G" button, release the power button.
4. Release the "G" button.
5. If you have done this correctly, the unit will power on. This procedure will switch back and forth between lbs. and kg.
Sep 04, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Coffe first pot is hot after that they are cold
This can be caused by scale build-up on the thermostat probe that hangs inside the tank. The scale stays hot for a long time, tricking the thermostat into believing that the water is still hot. Try pouring 1 Qt white vinigar into the unit, let it warm up completely, run a pot of clear water thhrough the machine, then turn the unit upside down over a sink (making sure it's unplugged first, and always keeping the fill hole down at all times) to let it drain out all the way. Then before you plug it back in, pour water through the machine until water comes out the sprayhead. Then plug it in, let it heat up, pour 2 pots of water through the machine & see if it heats up properly. If this doesn't cure your problem, your unit may need to be completely dismantled to de-scale the tank & thermostat probe.
Jan 20, 2009 | Bunn GR10 Coffee Maker
I have a Maytag refrig model MZD2669KEW. I am loosing power to my in the door ice and water dispencer. Power will go away, I then unplug power to the door unit for a couple of minutes. When I reconnect...
HI If the cord of the unit looks frayed, or if you see burn marks on the prongs of the plug or at the terminal screws -- on the terminal block, under the rear access panel of the unit -- the cord may be faulty. Test the cord with a VOM set to the RX1 scale
Oct 16, 2008 | Maytag Refrigerators
Samsung Syncmaster 245BW sync problem
If you are plugged into a NVIDIA graphics card, use the NVIDIA control panel scaling option to "do not scale" then set the resolution to 1920x1080. This monitor is a 16:10 aspect ratio instead of 16:9 like HD TV's, so it is necessary to turn of scaling from the software and thus give black bars.
Aug 10, 2007 | Samsung SyncMaster 245BW Monitor
Royal Dss Pro Shipping Scale Logo
Top Royal Health & Beauty Experts
Colin Stickland
Colin Stickland
Susan Poche
Susan Poche
Tammy Husk
Level 1 Expert
Are you a Royal Health and Beauty Expert? Answer questions, earn points and help others
