Question about Panasonic PT-53WX52 53" Rear Projection Television
Cc on I recently moved and since then the TV has the Closed Captions on and the normal way to shut it off does not work. I have tried the normal setting to reset the tv to no avail.
  • msgolddocter Sep 27, 2007
    thanks for mentioning the box. We disconnected the cable from the box and went straight into the TV and it no longer has the closed captions on the screen. I am calling our cable company to see if they have a setting in the box that can be changed. I will let you know for sure later on.
  • msgolddocter Sep 28, 2007
    The cable provider had 2 different cable company technicians that couldn't get it turned off. After you sent your message about the box, I called for support and the lady on the phone walked me through fixing the problem. thanks very much for your help
    Genius:
  • 1,694 Answers
The "normal way to shut it off" is a little vague to me-- ---Have you tried selecting CC1,CC2,CC3,or TEXT1,2,or3? Take your time selecting caption on functions and thus you will discover how to de-activate cc.I am guessing that since you moved,you can't locate your owners manual??--Last thought-is your source box cc on??
Posted on Sep 26, 2007
SOURCE:
How do you remove closed captioning? I have a 4yr old 50" plasma tv. Today the captioning just popped up and I can't figure out how to get rid of it
Hi
1* Use the CAPTION button repeatedly to select Caption Off, EZ Mute, or On.
* EZ Mute shows the selected captions option (if available on program) when the TV sound is muted.
2* Press the ENTER button to save.
Caption Tips
* Not all TV broadcasts include closed caption signals.
* Sometimes TV stations broadcast four different caption signals
on the same channel. By selecting CC 1 to CC 2, you
can choose which signal you view. CC 1 is usually the signal
with the captions, while Another mode might show demonstration
or programming information.
* Your TV might not receive caption signals normally in the following
situations.
OK.
Jul 13, 2011 | LG Televison & Video
How do i remove closed caption on tv - can't get menu option on remote to work - thanks.
What is the TV source? Could the captions be coming from that source? If it is, try disabling them from the Menu for the set top box (cable, satellite, DVD).
There is a menu button on the TV that will let you access the OSD if the Child Lock is not enabled.. Then the same directions apply Set > Closed Caption (Off, CC-1, CC-2, CC-Mute). If you can't access the menu directly, then the control board may be bad. Try shopjimmy.com for used parts with minimal wear (sets that were broken in shipping) or another supplier. You will need to open the TV and get the part number of the current board.
I hope this helps.
(the set-top box issue is one I have dealt with. A neighbor with an older TV needed to use the captions from the satellite receiver set to single mode to get captions for the visiting relative. This meant that both sets watched the captions until they were turned off. The main TV still showed the captions if they remembered to reset the receiver to Dual mode.)
Nov 11, 2010 | Philips Magnavox 27MS343S 27" TV
How do you get closed caption on
manual below.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man Turning On Captions Pressing the CC button displays caption options: ? CC on: Displays captions. ? CC off: Turns off captions. ? CC mute: Displays captions when the Mute button is pressed. To assign your preferences for captions, see “Using the Closed Caption Menu” on page 33.
Mar 17, 2010 | HP PL4260N 42 in. Plasma HDTV
19lv506 tv DISPLAYS CLOSED CAPTION WHICH I CAN NOT SHUT OFF
Press MENU in the TV mode. Press ▲ or ▼ to
select “Setup”, then press ▶ or ENTER
Press ▲ or ▼ to select “Closed Caption”,
then press or ENTER.
The Closed Caption menu will appear
Press ▲ or ▼ to select “CC Setting”, then
press ◀ or ▶ to select “On”.
On: Captions will be displayed on the screen.
Off: Captions will not be displayed on the screen.
Press EXIT/CANCEL to return to the normal
screen
I hope this helps. Thanks for using fixya. Please take a moment to rate this responce.
Nov 28, 2009 | Toshiba Televison & Video
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
Cannot turn CC off.
Features preferences
Caption service
This allows you to select the Closed Captions service levels of analog
broadcasting to be displayed.
Closed Captioning allows you to read the voice content of television
programs on the TV screen. Designed to help the hearing impaired, this
feature uses on-screen ‘text boxes’ to show dialogue and conversations
while the TV program is in progress. Captions will appear on the screen
during captioned broadcasts.
& Select Captions service.
é Press the cursor right.
“ Select the desired Caption service:
• CC 1, 2, 3 or 4
Dialogue (and descriptions) for the action on the captioned TV program
shows on screen.
Usually CC 1 is the most used. CC 2 may be used for alternate languages
if they are being transmitted.
• T 1, 2, 3 or 4
Often used for channel guide, schedules, bulletin board information for
Closed Captions programs, news, weather informations or stock market
reports.
Not all Caption services are necessarily being used by a TV channel during
the transmission of a Closed Caption program.
Features menu
& Select Features in the TV Settings menu.
é Press the cursor right to enter the Features menu.
“ Select the menu items with the cursor up/down and adjust the settings
with the cursor left/right.
Closed captions
This displays the transmitted CC- or CS-text on the screen according to
your chosen CC or CS service in the Setup, Features preferences menu,
This text can either be permanently displayed (assuming that the
service is available in the broadcast) or only when mute is active.
& Press the cursor right after having selected Closed captions.
é Select On, Off or On during mute.
Oct 28, 2009 | Televison & Video
Closed captions go on and off sporadically
if the comcast box is not hd then the control is with your tv/remote.
If the comcast box is hd, then you can control it from the comcast remote. To do this press cable, then power and in 2 seconds press menu to get to the hidden hd setup menu, scroll down to closed captions and set it to enabled or disabled then press power twice to get back to you rtv
Nov 26, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Closed Captions
Form your remote on normal signal, go to menu and video options. find closed caption, select CC and tun off text. That should keep it off at all times
Jul 04, 2008 | Insignia 37" LCD Flat-Panel HDTV
New Toshiba 37" flat screen always displays Closed Captions. Feature is turned off with TV remote, feature not available on Cable remote. Toshiba says it is Cable company problem, Mediacom cable can...
I've had this problem for a bit, it seems that there are two ways to turn off the closed captions.
1:Menu--->Preferences--->CC and Digital Audio Selectors. This displays the menu on the bottom of the screen with the choices of Closed Caption formats and digital audio. This is not the correct menu to be in. This turns off the CC as long as the TV is not turned off or the input is not changed. This is a temporarily either turns the CC on or off.
The Solution:
2:Menu--->Setup--->TV Settings--->Closed Captions Settings Displays a menu in the center of the screen, with the options of Turning the Closed Captions on and off, the Analog CC Mode and Digital CC settings. You must turn the Closed Captions off in this menu or the changes to CC are temporary.
For the record:
1. I'm aware I'm 2 years late on this, but I just want others to be able to solve this issue on their Toshiba. Don't worry, my Toshiba is the same age as yours
2. I've lost faith in Tech Support ages ago. I'm sorry that they were that incompetent.
3. Its ridiculous that there are two entirely different menus to alter the closed captions. Took me forever to figure this out.
Hope this helps you and others.
Jun 17, 2008 | Televison & Video
Closed captions
Closed Caption may only come on when you have the television muted.
Mar 10, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Panasonic PT-53WX52 53" Rear Projection Television Logo
85 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
