Hanns.G HannsG HQ191D - Grade A - 19" LCD Monitor Logo
A
Anonymous Posted on Oct 16, 2013
Monitor HQ191d look "adjusting" from second to second What can I do?
2helpful
My samsung P2050 monitors menu has been lockd, now i cant set up my monitor setings. Please tell me how to unlock it
On: If you press and hold the MENU button down for 5 seconds, the OSD Adjustment Lock
function is activated.
Off: If you press and hold the MENU button down for 5 seconds again, the OSD Adjustment
Lock function is disabled.
That should FixYa.
I cant adjust color control and also image and color reset becaused its locked... how can i unlocked this monitor?
Turn your monitor off. Now, turn this on but this time press and hold the swith on button+adjustment button in 10-15 seconds then release it. Your monitor is now free to adjust!
Lock on monitor adjustments don't know how to turn off the lock so we can adjust brightness and color
Follow these instructions :
  1. Turn on your Samsung monitor (if it isn't already.)
  2. Press the "AUTO" button on your Samsung monitor. This will run the automatic configuration utility. This will look at your current computer settings and adjust your monitor to best match those. This will take a few seconds. If this has calibrated the monitor to meet your needs, you are finished with the process. If it hasn't, continue to Step 3.
  3. Press the "Menu" button on your Samsung computer monitor.
  4. Use the arrows and the "Enter" button on the monitor to highlight and select various settings categories.
  5. Use the "Brightness" menu on your Samsung monitor to adjust how bright or dark you want the image.
  6. Use the "Colors" menu to adjust how prominent certain colors are displayed on your Samsung monitor.
  7. Use the "Contrast" menu to adjust the level of black on your Samsung monitor.
  8. Select "Save and Exit" to save your changes and exit the Samsung monitor's on Screen menu.
7helpful
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
1helpful
2answers
Can't adjust contrast
restore your factory settings and then try
Cant get it off autolock feature
dear you press the menu button for 5 seconds then your auto adjust option will be released and you want to lock it again then press again menu button for 5 seconds then auto adjust option will again locked.
2helpful
Want to unlock my monitor
This is the function that locks the OSD in order to keep the current states of
settings or prevent others from adjusting the current settings.
1. Lock : Hold down the menu button for more than five seconds to activate
the OSD adjustment lock function.
2. Unlock : Hold down the menu button for more than five seconds to
deactivate the OSD adjustment lock function.
Though the OSD adjustment lock function is activated, you can still
adjust the brightness and contrast, and adjust MagicBright ( )
using the Direct button.
Found at: http://www.retrevo.com/support/Samsung-713BM-PLUS-Monitors-manual/id/2994ag905/t/2/
Hope this helps and please remeber to give me a rating, thanks!
OpenSource13
I have a monitor that was given to me.
OSD Lock Settings
You have the option of using the OSD Lock feature to prevent current image
adjustments from being changed.
• OSD Lock: Press and hold [1] and [J]
for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
• OSD Unlock: Press and hold [1] and [J]
again for 10 seconds.
Monitor
On the monitor there should be an auto adjust button. Press that and it will adjust to your windows desktop.
Top Hanns.G Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Hanns.G Computer and Internet Expert? Answer questions, earn points and help others
