Question about Exercise & Fitness
Dynamix treadmill instructions
Every time I plug in my dynamix treadmill It switch off the mains switch, which means that it turns off the lights in the house and then I have to turn mains back on again
    Top Expert:
  • 12,223 Answers
You have a short circuit. Call to some electrician for to fix it the problem.
God bless you
Posted on Oct 17, 2013
Testimonial: "I have called an electrician and the electrician said its not the electric in the house that's the problem, it's the treadmill that's the problem."
ziraffa
  • 827 Answers
SOURCE: the treadmill keeps stopping Freespirit Model 12230520.0
Hey there,
If your treadmill has an optical speed sensor and hasn't been cleaned for a while, dust, dirt or lint may be obstructing the infared eye of the speed sensor. Try cleaning the treadmill.
Or maybe you need to replace the upper display, although, you may have a loose wiring harness that would cause the same problems. Open the motor case and verify the wiring harness is plugged into the lower board snugly. Also, remove the upper console and verify the harness is plugged into the back of the console snugly as well.
Definitely, inspect the components and try and isolate the source of the problem yourself first, before contacting a dealer for parts, as they can cost a fortune..
Good Luck!
Chris (ziraffa)
Posted on Dec 26, 2008
  • 64 Answers
SOURCE: Won't turn on at all.
If you have no lights, check the main harness that cary power to the console. Check connection at both ends.
PS Always check outlet to make ssure you have 120 volts.
Posted on Jul 27, 2009
maxtreadmill
  • 832 Answers
SOURCE: will not power on
The lower board has a serious short and what possible happen is that the treadmill breaker fried and open up will properly need replacing also.
Posted on May 06, 2010
maxtreadmill
  • 832 Answers
SOURCE: my dynamix treadmill the red power light comes on
I suggest checking your power plug then check or reset the circuit breaker or fuse holder on the treadmill next to the cord if that ok and the unit is still dead. Unplug unit the remove motor shroud and if you own a multi meter start checking the AC all the way to the lower board and see where the Ac is missing.
If the Voltage is good to the board then check DC Out put going the console wire harness should have 5v or 12v DC depending on model if missing then replace lower board, if present, then check the continuity of wire harness if bad replace harness. If good upper console needs to be replaced
Posted on Jun 01, 2010
dayminner
  • 159 Answers
SOURCE: I have a Rebock ACD1 Treadmill. It lights up when
By hearing from you that it lights up, is indicating that there is nothing wrong with the board, it is something to do with the motor. It is good that you have used a power surge protected outlet, but I have researched that this is still a problem with some people's treadmills.
So, as you can see this isn't going to be an easy fix without actually looking inside of it. So my suggestion would be to take it to qualified appliance specialist, call around until you get the cheapest price, and he should be able to either resoder or order a part and install it for you. If the treadmill has a warranty you can call up the manufacturer, and describe the issue to them and maybe they might be able to give you some extra steps, but it sounds like you have tried all the regular ones.
Good Luck :)
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Posted on Jun 18, 2011
DYNAMIX T3000C TREADMILL INSTRUCTIONS
Try Googling (DYNAMIX)(T3000C)(manual) without parens.
Jun 30, 2017 | Exercise & Fitness
We have a dynamix treadmill with a two slot safety key does anyone know how to by pass the key as we have lost it or where we can buy a replacement one
First make sure treadmill is disconnected from any power source. Most saftey keys just break the circuit by the plastic key between two contacts. You should be able to insert a piece of plastic into the slot on the control panel and bypass the saftey switch. Then reconnect the treadmill to power and try.
Sep 21, 2014 | Exercise & Fitness
My A42T wo't finish loading the Ifit software. which means the treadmill won't start. The software is stuck in a loop. How can I reset it or get out of this so I can use it? Thank you.
Turn it off from Machine build switch, then turn it of from mains, then unplug it from mains, wait for some time and then Plug it to mains, switch on from mains and switch on local machine switch. If the process above fails, you should contact the Dealer or Authorized Service Center.
Apr 26, 2014 | Epic A42T Platinum Treadmill
I have got a dynamix kp329 treadmill when I stand on it,it keeps stoping,is there anybody who can fix the dynamix,i cannot find anywhere that can fix them.
see the video and lube the deck belt,This happen because the system protect the electronic system. By lack of lube and maintenance. YOU must lube too the rollers bearing front +back, Test the drive belt motor, and replace the belt if necessary.
However if the problem persist, is TIME to replace the deck belt.
God bless you
Jul 31, 2013 | Exercise & Fitness
Dynamix instruction manual
go please to www.fitness.manualsonline.com or www. iconservice.com
God bless you
Jun 30, 2012 | Exercise & Fitness
Dynamix kp329 treadmill manual
were can i get a manual for the DYNAMIX KP329 MANUAL
May 20, 2012 | Exercise & Fitness
Exercise & Fitness Logo
353 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
