Question about Canon PIXMA iP2000
I have canon ip2000 printer, the screen shows error 5B00(The waste ink tank is full). the LED flashes, 1 Green(stable about 2 sec.), then orange/green, orange/green ..... 7 times(fast about 1/2 sec. each/interval) repeatedly , the printhead carriage will not move to the left whenever the cover/door open or not , you can move the carriage to the left manually but when you close the cover it will not move to the right side parking place,except you switch off and on the printer again, sometimes the carriage will move to the extreme right position, sometimes will move to the right position above 1/4 to1/2 inch from the right extreme position, which is correct ?, otherwise the printhead will dry up and clogged ?, I tried every method from the internet but failed, now the printer is not working at all, the LED keeping flashing as above, I hope the above statement is clear and understandable, if you have any questions please let me know, Thanks !. I am using mac 10.6.8 cannot use the ipTool ?. I have cleaned the narrow plastic belt(control the carriage moving and positioning) and removed the printer driver and download the latest canon driver but the problem still there. may be the problem is at the printer's computer, corrupted ? and then how to rectified it ?. Thank you again !. JJ
  • 28 Answers
In case you haven't tried this before, here is a tip that should reset the printer.
Copied from site: http://www.cyber-ink.com/member-canon.html
To Reset ip2000 / 3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Also note that if the carriage is not moving as it should, it has nothing to do with printer drivers or your computer. It is an internal function of the printer and no external connection (usb/ethernet) should affect its operations.
Posted on Oct 26, 2013
2 Suggested Answers
  • 100 Answers
SOURCE: iR 5000i and iR 6000
1 needs a new potential control sensor and pcb. this needs to be installed by a certified tech, However it can be the laser that needs replaced. The procedure isnt fun, this is a difficult problem to resolve.
2. this just needs a new thermistor sensor for the fixing unit. that part shouldnt cost more than 15 bucks. If fixing unit is worn past its life it should be replaced.
Posted on Jan 21, 2009
Am imprimanta canon pixma MP520 Am primit mesajul ,The ink absober is full,apoi dupa cateva imprimari mi-a aparut 5B00-service required Va multumesc anticipat
Try the Waste Ink Counter Reset Manual for "Service mode"
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (LED) should be green.
4. Press and release the RESUME button, the indicator (LED) should be orange.
5. Press and release the RESUME button again, the indicator (LED) should be green.
6. Release both buttons.
Then try another 4 steps to Reset Waste Ink Tank Counter
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- Release the POWER button
STEP 4:- Press the POWER button again
Apr 27, 2011 | Canon PIXMA MP520 InkJet Printer
2 Lights flashing on printer ( green / amber warning ) - status 5B00
MP170 (5b00) Ink Tank Full Error
1,power off.
2,hold stop/reset ,hold ON/OFF
2,release stop/reset then release ON/OFF
3,wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
4,then push ON/OFF twice, quickly
5,power off and power on.
Try to do this step maybe this will help you solve your problem.
Nov 17, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Affichage WASTE INK NEAR FULL, where is the waste ink ?
The waste ink tank is inside the printer. You cannot do anything about it except reset the ink level count.
How to reset error 5B00 for Canon MP170 (Ink Tank Full Error):
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
May 10, 2010 | Canon PIXMA MP170 All-In-One InkJet...
My Canon PIXMA iP2000 photo printer Waste Ink Absorber
Hi there try see if this will work
Reset ip2000
1. Turn off printer
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 10, 2009 | Canon PIXMA iP2000 InkJet Printer
Showing waste ink near full
Could try
1 - power off.
All Best: Pineworks
Mar 17, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Waste ink tank full
You can try this
Reset ip2000
1. Turn off printer
Jan 21, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon printer error 5b00, Absorbers full.
Service mode operation procedures *
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the StoplReset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop 1 Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the StoplReset button the specified number of time(s) according to the function listed in the table below.(Each time the StoplReset button is pressed', the LED lights alternately in orange and green, starting with orange.)
4 times
Green
Waste ink counter reset
See waste ink counter reset
procedures helaw.
Aug 27, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Ink Waste Tank Almost Full on Canon i320 printer
Hi, This procedure should work.
Waste Ink Counter Reset.
Step 1 : Manual for service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
or
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
Jul 25, 2008 | Office Equipment & Supplies
Changed ink jets alarm flashing number 5800 showing
Hello Saron Girl,
its not 5800 its 5B00
7 times LED Blink Waste ink absorber full [5B00] - Ink absorber (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257)
<Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
4 times LED Green Waste ink counter resetting
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
Regards,
May 14, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Waste ink tank full..error 5B00
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Waste PAD ink Reseterfor Canon Pixma iP6320D
You need to Remove the ink Cartridge first in order for the code to take effect.
1) Closethe print head cover.
2) While pressing the Stop/Reset button, press the Power button. (Do not release the buttons. TheLED lights in green to indicate that a function is selectable.)
4) While holding the Power button, release the Stop/Reset button. (Do notrelease the Power button.)
5) While holding the Power button, press the Stop/Reset button 2 times,(Canon idle will appear)and then release the Power and Stop/Reset buttons.(Each time the Stop/Reset button is pressed, the LED lights alternately ineither orange or green, starting with 0.
6) When the LED stops blinking and lights in green, press the Stop/Resetbutton 4 times. (Each time the Stop/Reset button is pressed, the LEDlights alternately in either orange or green, starting with orange.)
7) Press the Power button 2 times. ( the '' Canon" appear twice).The LED lights in green, and the selectedfunction is performed. (When the operation completes, the printer returns tothe menu selection mode automatically.)
8) Power off then back on and test.
9) Congrats!!
Prepared By Jeffrey Vicada (EDS- Technical Engineer) Philippines
Dec 03, 2007 | Canon Pixma iP6210D InkJet Photo Printer
Computers & Internet Logo
98 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
