Question about Saniflo Sanibest Grinder Pump Only 013
I need the replacement rubber concertina tubing that links a Sanibest Macerator to the actual toilet.
Where can I by replacement for the concertina rubber tubing that links a toilet to the Sanibest macerator
You should be able to purchase this at any local hardware store.
Lowes, Menards , or Home Depot. They may have to order it but I am sure that if you take the old parts they can make you a replacement if they do not have the direct replacement hose there.
Oct 16, 2013 | Saniflo Sanibest Grinder Pump Only 013
Is sanibest energy efficent
Not any more than any other 1.6 gallon flush tiolet.
Feb 11, 2011 | Saniflo SaniBest-Elongated SaniBest...
My sanibest is just humming. I am assuming that the motor is clogged with something disgusting. I have a toilet, sink, and bathtub going into the sanibest. Unit stopped working as soon as tub was draining...
Bail out as much as you can through the toilet bowl. Unfortunately this is a messy job regardless and you will still need newspaper on hand.
If you lower the water level below that of the rubber gasket connecting it to the toilet though, you will be able to undo the jubilee clip holding this and slide the unit away from the toilet, hopefully without spilling much waste water.
If you can dislodge the blockage from this angle, great. If not, you might also have to take the lid off by depressing the plastic clips on each side and accessing the chamber from the top.
Oct 17, 2010 | Saniflo Sanibest macerator with multiple...
How do you take the lid of a Saniflo macerator?
its blocked dont put paper or towles in it sorry to say its amessy job discont fromtoilet inlet have a bucket and mop handy
Oct 11, 2009 | Saniflo Sanibest macerator with multiple...
How to unclog the macerator - Saniflo TurboFlush P
First unplug the unit from the GFI, remove all the piping attached to the pump, remove the pump completely out the back of the toilet. Pry open the lid with a flat head screw driver, remove 2 screws in front of the pump and the motor and pressure chamber can be pulled out the top as one piece. Inspect the blades (on top of motor) also inspect the impeller which is at the bottom of the motor, you must turn the black pump cover plate counter clock wise to unlock it and inside there you will find the impeller. Also check the drain pipe for obstructions.
Aug 15, 2009 | Saniflo 013/005/007 Sanibest Toilet with...
Can a saniflo 003 toilet be installed with only the 005 tank, or does it need a macerator?
depends on how you use the unit. the macerator chews up paper and other unmentionables.I would suggest you use it as one unit.
Jul 12, 2009 | Saniflo Sanibest macerator with multiple...
Sanibest toilet is LOUD when flushed
Shut down the power and pull the pump from the unit and give it a exam. There might be something as simple as a item that was flushed down the toilet (pencil, pens, combs, etc.) or just a hair clump. Check that the float is free to track fully up and down. Good Luck!
May 17, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Saniflo Sanibest Grinder Pump Only 013 Logo
76 people viewed this question
Top Saniflo Plumbing Experts
jasbo
jasbo
Gil Shultz
Vernon Taylor
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
