Question about Acer Computers & Internet
My Acer moniter (P244w) has recently begun to show different colors (red,blue, etc) print. Is it the moniter or something that I can correct on my PC?
    Problem Solver:
  • 19 Answers
This could be a result of multiple different variables. If its a CRT monitor, it could be magnetic interference that is causing it. On an LCD screen, it could be your video signal. Check the cables and make sure they are plugged in tight. Check to make sure there are no power lines or magnets around the monitor as well. Turn off any lighting in the area and see if that affects the monitor. Also you can test the monitor on a different computer to see if you get similar issues. If so, then you may need to replace the monitor or it's cable.
Posted on Oct 16, 2013
5 Suggested Answers
  • 52 Answers
SOURCE: I recently just bought s
dont yah hear some beeping in your system tower?
Posted on Jul 19, 2008
BENTECH7
  • 132 Answers
SOURCE: Correct Colors of the monitor
check the VGA chord might have a lose connection. Check the connector if the pin is complete. If you are using a video card check the video card connector. Try to test your monitor to other computer if the problem is still the same it means the monitor have an internal defect which you can ask to the supplier where you bought your monitor because as you've said it is till under the warranty so it may replace a new one by the supplier or store where you bought your monitor.
Posted on Aug 08, 2011
drifterK
  • 4924 Answers
SOURCE: Dell B110 turns on but no signal to monitor. Help.
If you have a short display of the devices and the blue screen flashes when you get to windows and shuts down ..than it is a hard disk issue ..God to bios and disable the ahci function for the hard disk bus..and let it run on ide compatible or sata as ide..This is happening when you have a hard disk on sata with ahci on ..and you do not have drivers in the system ..
But if there is no start at all ..it is a different cause and probably the video card damaged if it says no signal ..
Anyway check them all one by one ..cpu fan ..hard disk in and out ..(see if you can boot to bios ) ..and ram memory ..remove tehm and place back ..one by one to spot a potential harmed one ..
Posted on Jan 01, 2012
ozinetworks
  • 106 Answers
SOURCE: My moniter is showing no signal with 3 colored
ok your monitor is a separate issue and start by checking the blue signal lead from the back of the monitor because for some reason the monitor isn't getting any images to show
Posted on Feb 02, 2012
HP photosmart 6510 prints pictures with blue tinge
Try doing a head cleaning, maybe there is the problem, let me know.
Mar 24, 2013 | HP Photosmart 6510 Wireless e-All-in-One...
I have a moniter that the cord is cut. how do i find out what wires go where on a plug
Without having even a brand name or a schematic we can't even guess what you have. IF THE iwres have color codes it is likely if red green and blue wires are present, that they are the red green and blue lines. Search Google for: vga pinout This will bring up images of the VGA connector pinouts. Just get the shield in the correct place and you really won't damage anything by a wrong connection... it might take a while by experiment to get it to work... The color lines will likely have the return wire with a "tracer" color that might be like a red wire with white stripe which would be the return for the red... etc.
Nov 12, 2012 | Computers & Internet
My moniter is showing no signal with 3 colored stripes g on green r on red b on blue. I have a wireless logitech mouse and keyboard and the reciever is not showing the 2 green lights meaning its on. Do I...
Feb 02, 2012 | Gateway Computers & Internet
HELLO I have recently made an Blue LED writing sign, at close up its fine, but the more further i go away from it , it becomes blurry and hard to read. please help
LED's have a very specific wave length that defines the color, and blue isn't that sharp. Plus the type of LED's itself may not be of the right angle. Together this makes for looking fuzzy at a distance. A different color blue (different manufacturers have slightly different colors of blue and each are slightly different wave lengths) and/or a different angle of lens might improve the legibility of the sign.
By the way this is also true to a point about octics, your eyes for the color blue. Think of how much harder it is to read lighter blue ink print than it is to read either black or red....
May 17, 2011 | Kitchen Appliances - Others
My Acer P196hqv moniter is always offset by about 50mm when I start my computer, and I have to use the moniter controls to correct it. Very frustrating!
this is because the boot up screen and the welcome screen comprises of many differences they differ in resolution ,colour depth etc so if once the moniter is set for welcome screen it may be irregular for boot window
Mar 24, 2011 | Acer 22" X223w LCD Monitor
My acer monitor is showing only blues and yellow colors. No reds etc. I tried to adjust it on color resoliution byut didnt work
Try a different video-cable.
Try tightening the connections at each end of the cable.
Try connecting the monitor to a different desktop or laptop,
to see if the colours are correct -- it could be the video-card on your computer.
Oct 29, 2009 | Acer Computers & Internet
Print images look like a rainbow, going from blue to red to blue to red etc.
I am on my way to a couple of appts. I waill answer early afternoon, Joe
Oct 06, 2008 | Ricoh Aficio CL3500N Laser Printer
Screen color problem
Some circutes are not working properley so please go to your nearest service center otherwise call to the moniter service center
Jun 23, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
