Question about Dryers
Kenmore 970 Our front load dryer will not start and it displays PAU. Model c8804/8805. Pls assist. Thank you
  • Eva De Castro
    Eva De Castro Oct 16, 2013
    Thank you guys for all your expertise! The drum was indeed stuck. We rotated the drum while pressing the Start button and the idler button (?) and it started running. Does that mean the belt needs replacement? Which part do we have to replace? thanks all.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Do you have the customer user manual indicating what the Error PAU mean? I do not have my Error code log at hand as i read your post sorry. Provide as much info to get others to help you.
Most Error codes will lock out you machine, for safety reasons..so it wont start.
Posted on Oct 17, 2013
kachbibi1
  • 979 Answers
SOURCE: Kenmore Dryer Model 970-C82062-10
The bearing or spindle the drum rotates on is probably bad or worn out. You can get to the back and turn it by hand and feel it when you turn it. You can tell if it is metal rubbing. If so, you can replace it.
Posted on Jan 25, 2009
TheMobilian
  • 8220 Answers
SOURCE: Squeaking Kenmore Stackable Dryer
Your rear drum bearing has worn through the plastic and is now hitting the metal support underneath it,
soon it will act like a guillotine and slice of the ball, the drum will fall backwards into the heating element and short to ground causing the fuse to blow the heater element to burn intwo and the whole thang will be dead in the water.
Posted on Mar 07, 2009
  • 120 Answers
SOURCE: Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Posted on Jun 04, 2009
  • 146 Answers
SOURCE: kenmore dryer 417.84072300
Check you circuit breaker. Even if it doesn't look tripped reset it anyhow. This is a power interrupt code.
Posted on Dec 22, 2007
  • 177 Answers
SOURCE: Thermal fuse change on Kemore 970.c85042-00
First you need to know your dryer over heated and the thermal fuse tripped for a reason.
You will need to replace the thermal fuse, thermal fuses are there to protect the dryer. When you have the dryer apart clean all the venting and vacuum out the dryer. Look online for a parts supplier in your area, you will need your model and serial number to order the thermal fuse they are about ten dollars.
how long is the venting, does it exceed 20 feet, how many elbows. Make sure the outside hood is clean
Posted on May 08, 2008
How to fix a Kenmore dryer model 417.8112 with error code pau
Is your washer still full of water? You may have something in the drain motor, that would also cause the error code 41 issue. I'd first check for an obstruction in the drain motor itself. Its very easy to get access to the drain motor. Lots of times I see these get clogged with stuff ...
Jul 27, 2014 | Kenmore Dryers
Runs for little while then stops and has the code PAU on the display. I tried unplugging the cord, I reset the circuit breaker. Still the same and now it won't even start.
Try taking the control board out and check for burned off traces. Solder back those points and it should work again. Just did it to mine and now it runs again. Still flashes PAU though.
Jul 07, 2011 | Kenmore 84072 Electric Dryer
My Kenmore front loading dryer, 970-C85192-00 starts drying with a load squeaking noise. Once it warms up it stops. Could it be a belt?
usually this is a drum roller replace both very inenspensive and u can order parts directly threw sears.com recheck model number get off appliance data tag on appliance
Jan 28, 2011 | Dryers
Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Softener dispenser
if softner has discharged it's probably working ok some water left behind is normal
Jun 18, 2008 | Kenmore 44921 Front Load Washer
Dryers Logo
78 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
