Question about Garden
Why does my 2004 polaris predator 500 bogs out in 5 th gear ?
  • 62 Answers
If it runs fine in all other gears, its probably something either in the petcock not allowing the fuel to flow fast enough or a clogged inline filter if it has one, or the float level is too low inside the carburetor.
Posted on Oct 28, 2013
3 Suggested Answers
  • 83 Answers
SOURCE: 2004 polaris predator 500 3 new batterys dying can't charge them
I hope you got this problem fixed, just happened to my predator, it was indeed the voltage regulator. I picked up a service manual that includes part numbers and installation procedures from www.promanuals.net for 15 bucks.
Posted on Sep 26, 2009
SOURCE: have a 05 polaris predator
i have a 1996 indy 500 trail and it is locked up cant turn the cluch and the rope is jamed. any sugestions
Posted on Jan 05, 2011
I have a 2003 Predator 500 put all new electrical parts on it there is no kill switch on it and it's not getting spark
Hi, Chris and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or ignition / electronic module
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
predator 500 no spark Polaris ATV Forum
ATV Connection
03 Predator no spark Polaris Pro Riders
https://www.tradebit.com/filedetail.php/278862898-2003-atv-polaris-predator-500-workshop-service
Apr 18, 2016 | Motorcycles
How do you put a Polaris Predator 500 in reverse
1. Place the transmission in first gear
2. Rotate the lockout switch forward to unlock reverse gear
3. Shift into reverse gear
When you shift back out of reverse gear, the lockout switch will reengage automatically to prevent accidental shifting into reverse
Mar 15, 2015 | Polaris 2006 Predator 500
Why is my 2004 polaris predator 500 shutting of while riding it
First be sure to check oil level if you haven't. Many have a low level shut off switch. If the level of oil gets below a certain point it can shut off. Just a thought.
Oct 17, 2014 | Polaris 2004 Predator 500
Why is my 2004 polaris predator shutting of while riding it
Thats not much info but ck the fuel supply and or coil.
Can i put a flyweel from a 2003 polaris predator on a 2005 polaris predator? i recently bought an 03 and i have an 05 and i am wanting to make one complete bike out of the two
If you have a 2005 ATV A05GJ50AA PREDATOR 500 and a 2003 same size..then YES, the flywheel is part# 30878055 and WILL fit in either model
if you have a both PREDATOR 50 or 90 the the flywheel is the same as well for either year.. part#...0450525
Hope this helps
Good luck
Thanks
Please rate FIXYA
May 21, 2011 | Polaris ATV
Have a 05 polaris predator 500, riding and it locked up now can't get out of gear..
Oct 26, 2010 | Polaris ATV
Mar 21, 2009 | Polaris ATV
Will not start. no power to lights, starter. Battery fully charged. ATV is a 2006 polaris Predator 500.
NOT SURE IF THIS WILL HELP BUT I HAVE A 2004 POLARIS PREDATOR 500 AND IT HAD THE SAME PROBLEM! IT TURNS OUT THAT IT WAS A RELAY BOX LOCATED ON THE BATTERY TRAY.
Mar 06, 2009 | Polaris ATV
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
