Question about Samsung WF337AA Front Load Washer
The machine spins so hard it feels like a rocket about to take off and we set it to medium spin
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
The FL Code indicates that the door "failed to lock". Turn the machine off and then back on again. Restart the cycle and see if it restarts without the "FL" code returning. If the error code returns, there is a problem, which needs to be diagnosed by a Samsung service person.
Posted on Oct 19, 2013
The brush bar does not spin
check brush by spinning with fingers it should only take slight pressure to rotate, if hard to rotate disassemble head and remove any carpet or hair strands
Jan 11, 2016 | Shark Rocket Self-Propelled Bagless...
What would cause a nasty metal nashing sound when machine goes from medium spin to high speed spin during spin cycle?
Hi dear,
As I know it happens to other Asko washer models as well. From 800 rpm going up to 12-14 or 1600 rpm. That sounds happens due to vibration generated from motor. I do not thing you can do much about it unless changing motor,which is costly remedy. Thanks.
Jan 09, 2016 | Asko Washing Machines
Spin problem
it seems like your brushes need replaceing or your moter is on its way out
Oct 17, 2012 | Washing Machines
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Hard drive does not operate
1, switch off computer
2. remove side (usually two screws on the back held it)
3. remove and then re-insert power cable from hdd
4. remove and re-insert data cable, from hdd as well as from m/b
5. start computer and hold your fingers on the top of the affected hdd, if you feel vibrations, this meant that driver is spinning and therefore rescue can be attempted at home.
6. research and purchase hdd recovery software, follow it's instruction and save data on another medium, be it another hdd or cd's dvd's.
if there is no spin, recovery is still possible but in specialist lab and will cost more money....
always back-up your data, second hdd is much cheaper than data recovery from existing one...
Jul 27, 2010 | Maxtor Hard Drive
My clothes are wet at end on my maytag neptune washer machine
If you are spinning them on the highest setting try to put it on medium. Sometimes the highest setting is too fast and it will bang around and not spin properly. A lower setting will work better and the clothes will still come our dryer.
Sep 14, 2009 | Maytag Neptune MAH6500A Front Load Washer
No spin or agatae
Unplug machine. Change load type to medium. Clean door sensor. Set knob to drain and spin. Plug machine back in to powr. Open and close door 10 times in 15 seconds. Pull knob to activate drain and spin.
Mar 19, 2009 | General Electric WHDSR316G Top Load Washer
Whirpool LSQ9200LQ Top Load water leaking on start of pump out
Transmission may be bad. When machinbe goes into very start of spin it should drain the water first and then machine will actually spin; tub should not be spinning. If it is, water cyclones up sides and will come out at tub cover. Only fix is to repl trans or select lower water level if I am correct in the diagnosis.
Nov 30, 2008 | Whirlpool LSQ9600L Top Load Washer
Extra Spin cycle?
(I know this is an old question, but its probably a common question for new owners - including me a couple of weeks ago...)
Power the unit back on, press the spin speed button and it will select the "drain and spin" cycle. Pressing the spin speed button again will select different spin speeds as well as just "drain".
Something you might try instead of medium spin speed is to turn on "SpinSense". To turn this on (and off), press and hold the "Stain Cycle" button for 3 seconds while any wash program is in process.
What SpinSense does is measure the imbalance by doing a very slow spin before cranking the spin speed up (and measuring how constant the very low spin speed is). If the balance is out too much, it will stop, let the clothes drop, and then try another slow spin. It will try this over and over many times until the balance is decent. Then it will let it rip. It makes a huge difference, but it can spend a lot of time getting a good balance some times.
SpinSense also seems to be able to detect if the machine is shaking terribly, shut the spin down and try again.
Our LG 2688 is on our 1st floor (wooden floor). Without SpinSense, the vibration was terrible and with it, it is tolerable.
For some reason we typically get less vibration with "Extra High" spin speed compared to "High" so that is another option you might try.
May 08, 2008 | LG WM2688H Front Load Washer
Samsung WF337AA Front Load Washer Logo
43 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
