Question about Hunter 52" Ceiling Fan With Light And Remote Control
How to attach and wire my controller for my remote control
    Genius:
  • Hunter Master
  • 1,617 Answers
What model do you have? If it is an add-on remote, then follow instructions here:
1) Black on end of receiver to black in ceiling.
2) white ( next to black ) to white in ceiling.
3)Other White to white in fan.
4) Black to black in fan.
5)Red or black w/ white stripe to blue or black w/ white stripe.
Posted on Oct 17, 2013
Error code "ch12 for LG PQRCUSA0
Connect the remote controller cable to
the wired remote controller installation board as shown in the right picture. 12V SIG GND Red wire Yellow wire Black wire 12V SIG GND 4. After fixing the
top part of the remote controller to the installation board as shown in beside picture, press the bottom part to assemble the controller to it's board. When
disassembling the remote controller from the installation board, use the driver as shown in the right picture and insert it into the hole with the arrow. And
when you pull the driver in the front direction, the remote controller will be separated. Wall Side Wall Side ENGLISH Red Yellow Black Remote Controller
Cable ?The remote controller cable is connected as factory default. Wall Side Wall Side 2. After fixing the cable to the guide slot, attach the wired remote
controller installation board at the desired location.
Mar 02, 2015 | LG Heating & Cooling
Where can I get a wiring schematic for a F588?
The blue wire is the light wire. Since this is a remote control fan, it is either connected to the blue wire to the receiver or to the black house wire if you do not have a remote receiver.
Sep 06, 2013 | Minka Dryers
Paddle fan wiring diagram
see the diagram attached: God bless you
Jul 22, 2012 | Universal Remote Control Hampton Bay...
My sky remote control does not work with a secondhand skyplus box. what is wrong
1) retight the spring contacts batteries with pliers for good contact
2) clean the contacts batteries with contact cleaner
3) resolder the wires contact batterires
4) open the r.control for clean the contacts for dirty, corrrosion, oxide, test with continuity, remember they send infrared signal to the microcontroller receiver.
5) if you can do it, go to the repair shop TV for fix it.
God bless you
Jul 16, 2012 | Televison & Video
The battery attachment for the 9V battery broke. One of the clips that attaches to the battery broke off when I was trying to take the battery out to replace it. Is there a way to add a new 9V battery...
if you are a bit handy, you can by replacement 9v packs/adapters that you can solder or wire nut on. Depending on what type of remote you have, it might be more economical to by a new one. the packs are ready available on eBay.
May 03, 2010 | Hunter 27185 Remote Control
1990 cutlass ceira how do you replace drivers door side mirror
Outside Mirrors REMOVAL & INSTALLATION Standard
  1. Remove the door trim panel and detach the inner panel water deflector. With the glass in the down position, pull out the front portion of the glass run weatherstrip. Fig. 1: Unfasten the attaching nuts from the mirror base studs, then remove the mirror 8c45877.gif
  1. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler, then rotate retainer rearward.
  2. Remove the noise control patch to gain access to the screw at the belt, then remove the screw.
  3. Remove the filler attaching screws at the top front of the window frame, then remove the mirror and filler from the door.
  4. Remove the attaching nuts from the mirror base studs, then remove the mirror. To install:
  5. Be sure that the mirror gasket is aligned.
  6. Replace the mirror and filler on the door. Install the filler attaching screws at the top front of the window frame. Attach the nuts to the mirror studs and tighten.
  7. Install the screw at the belt, then insert the noise control patch.
  8. Insert the retainer, then install the attaching bolts and screws to the front glass run channel lower retainer to filler.
  9. Replace the front portion of the glass run weatherstrip, insert the inner panel water deflector, then reinstall the door trim panel.
Manual Remote
  1. Remove the mirror remote control escutcheons and door trim panel. Detach the inner panel water deflector. NOTE: Right side remote mirror may require detaching part of the instrument panel.
  2. With the glass in the down position, pull out the front portion of the glass run weatherstrip.
  3. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler and rotate retainer rearward.
  4. Remove the noise control patch to gain access to the 0.3 in. (7mm) screw at the belt and remove the screw.
  5. Remove the filler attaching screws at the top front of the window frame.
  6. Remove the mirror base with mirror and cable assembly from the door.
  7. Remove the mirror to filler attaching nuts and remove the mirror and cable from filler. To install:
  8. Be sure cable is routed around front glass run channel retainer and installed to clip.
  9. Install and connect the cable to the filler.
  10. Attach the filler nuts to the mirror, then tighten to 72 inch lbs. (8 Nm).
  11. Install the mirror base with the mirror and cable assembly to the door.
  12. Insert the filler attaching screws to the top of the window frame, then install the screw to the belt.
  13. Secure the noise control patch.
  14. Attach the bolts and screws to the front of the glass run channel lower retainer and filler.
  15. Install the glass run weatherstrip.
  16. Attach the inner panel water deflector, door trim panel and mirror remote control escutcheon.
Electric Remote
  1. Disconnect the negative battery cable.
  2. Remove the mirror remote control escutcheons and door trim panel. Detach the inner panel water deflector and the electrical connector for the mirror. NOTE: Right side remote mirror may require detaching part of the instrument panel.
  3. With the glass in the down position, pull out the front portion of the glass run weatherstrip.
  4. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler and rotate retainer rearward.
  5. Remove the noise control patch to gain access to the 0.3 in. (7mm) screw at the belt and remove the screw.
  6. Remove the filler attaching screws at the top front of the window frame.
  7. Remove the mirror base with mirror and electric connector from the door.
  8. Remove the mirror to filler attaching nuts and remove the mirror and electric wire from filler.
  9. To install, reverse Steps 1 through 6. Be sure electric wire is routed around front glass run channel retainer and installed to the clip. Tighten the nuts to 72 inch lbs. (8 Nm).
  10. Connect the negative battery cable, then reset the clock, radio and any other accessories if required.
Aug 25, 2009 | 1990 Oldsmobile Cutlass Ciera
Ceiling fan remotes
If you know where the remote receiver is located on the fan (probably in the canopy or the compartment where a light kit would attach), you may want to see if you can find the wire antenna that is hanging off of it. If possible, run that wire outside the canopy so it is exposed, this might give you a better response.
Dec 23, 2008 | Hunter 52" Ceiling Fan With Light And...
Multiple tv sets
With the multiple TV's what you are looking to do is called "IR routing" There is not exactly a "pre-packaged" solution.
Try one of these companies I think all of them can handle this:
http://www.crestron.com/
http://www.universalremote.com/
http://www.amx.com/
http://www.rticorp.com/
I would have it professionally installed. You can find a professional in your area using the locater on the websites.
Hope that helps!
Nov 20, 2007 | Apple WIRED REMOTE 4 ZEN MICRO Remote...
Dryers Logo
109 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
