Cannon laser class 3170
How to program laser class 3170 to print confirmation page
    Master:
  • 359 Answers
You will have to connect to the printer on your PC and go to control panel>printers and go to the properties of the printer and find the "Print Test Page" location, it is usually in the quality menu.
Posted on Oct 16, 2013
Nitrotrike
  • 589 Answers
SOURCE: printing confirmation page after completed fax
If you have the operators manual (it may be in the back compartment of the machine), look in the index for "fax parameters", then "fax reports".
Posted on Jan 10, 2008
SOURCE: confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Posted on Aug 01, 2008
POCBM
  • 121 Answers
SOURCE: Printed confirmation on faxes sent form HP Laser Jet Fax M1522nf
To get confirmation page do this:
1. On the control panel, press Setup ( ).
2. Use the arrow buttons to select Reports, and then press OK.
3. Use the arrow buttons to select Fax Reports, and then press OK.
4. Use the arrow buttons to select Fax Confirmation, and then press OK.
5. Use the arrow buttons to select the option for when you want the fax error reports to be printed.
6. Press OK to save the selection.
To iclude first page with report:
4. Use the arrow buttons to select Include 1st page, and then press OK.
5. Use the arrow buttons to select On, and then press OK to confirm the selection.
Posted on Mar 25, 2009
ermiaby
  • 54 Answers
SOURCE: System error E000
E000 Fuser thermistor, heater thermal fuse E001 Fuser thermistor, or triac E002 Fuser thermistor, thermal fuse or triac E003 Fuser thermistor, heater, thermal fuse or triac E004 Triac or fuser won't shut off E007 Fuser film is off center or not driving properly. Might be able to reset in service mode 4-407 E010 Main motor drive problem E030 Counter E041 Paper deck motor, clutch or sensor E064 Composite power supply or main motor board E202 Scan problem. Motor sensor E210 Lens drive problem E220 Exposure lamp E240 Main board or composite power supply E260 Main board, power supply cooling fan or composite power supply E261 Composite power supply or fluctuating power E400 ADF communication to machine E401 ADF pickup motor or sensor E402 ADF belt motor drive E403 ADF feed motor or slip sensor E404 ADF exit motor E411 ADF document detect, or registration sensor or edge sensor E500 Sorter communication problem E510 Sorter drive problem E530 Stapler guide b
Posted on Jan 17, 2010
  • 26 Answers
SOURCE: How do I print a confirmation page for this fax
1. First You need to press the additional functions button on the front.
2. Select Report Settings button
3. Select Printer button under the Print List menu
4. Press either PCL button or PS button to print the appropriate config page.
5. Press Configuration Page button
6. Select Yes button to confirm printing of config page.
Posted on Feb 19, 2010
Cannon ir2200
you will need a colour ink cartridge or when pressing print before you confirm press properties. Then make sure if the gray scale printing is ticked if it is untick the button and press print and the it should print in colour.
Feb 07, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Feb 19, 2010 | Canon LaserCLASS Fax 710 Printer
I need to set the speed dial on my canon laser class 3170.
If you have the operators guide, that information is on pages 4-1 thru
4-14.......if you don't have the guides, I do...but I can't link you to them.
Jul 29, 2009 | Canon Office Equipment & Supplies
I do not have a disc for canon laser class 3170 and I need the printer to work
You don’t specify which operating system you have on your computer;therefore I give you this page, to select the driver to your OS.
If you incounter problems with the "new" PCL6 driver, then try the "older" PCL5.
plz let me know how it goes.
Regards
/Teis
Jan 08, 2009 | Canon LaserCLASS 3170 All-In-One Printer
Confirmation page for fax on canon5070
Press Menu-press arrow untill you getreport settings,select TX report and set it to "on"
Nov 24, 2008 | Canon Laser Class 310 Fax
Confirmation page from days earlier
check the device for an activity log option. you may need to check the user manual for this.
Mar 06, 2008 | Brother IntelliFAX 4100e All-In-One Laser...
Laser class 3170 canon fax machine
The manufacturer puts many of its manuals online.
Start at http://www.canon.com and click your country.
Click Support.
Enter '8500' and do a search.
Download the PDF files.
Nov 09, 2007 | Canon Laser Class 8500 Printer
Canon Laser Class 3170 - Change Display Number
Here is the manual
http://www.procopyoffice.com/Manuals/LC3170/LASER%20CLASS%203170%20Series%20Users%20Guide.pdf
Oct 30, 2007 | Canon Laser Class 8500 Printer
35 people viewed this question
k24674
