Question about Freezers
My amana bottom freezer drawer keeps rusting over making it difficult to open and close. i have cleaned it several times and used various lubricants which work for a little while, then rusts up again.
    Master:
  • 359 Answers
It sounds like you are having a condensation problem. Is your freezer fully sealed? Is your refrigerator turning on and off and not staying on as it is supposed to? You can tell by putting an ice cube in the freezer and seeing if it melted, or melted and got frozen again.
Posted on Oct 16, 2013
Sea Breeze
  • 4655 Answers
SOURCE: bottom drawer hard to close
Check the drawer slides on each side for cracks or a screw that has come loose. The drawer should slide in a groove on each side firmly. Hope this helps. JT
Posted on Oct 24, 2007
  • 1314 Answers
SOURCE: Rust On Bottom Of Chest Freezer
id sand it paint it with white rustolm and go from there and no it couldn't there is a layer of foam between the bottom of the outside and in side
Posted on Feb 11, 2008
docjohn174
  • 943 Answers
SOURCE: Drain freezes and glacier forms inside bottom
hi thanks for the question the drain hose leading from the freezer is clogged up remove the ice from the bottom pull fridge from wall find small drain tube clean the tube now it will drain into tray vacuum out while your there thanks the appliance doc
Posted on Sep 25, 2008
huuum
  • 750 Answers
SOURCE: Kelvinator Chest Freezer will not cool after spray painting rust spot.
Dear Landport2
Welcome to the site,
You said, you have a Kelvinator chest freezer, model number CFS101SM1W. This freezer is in excellent condition and was working ok. I notice that there was a rust spot on the bottom area so I decided to spray paint the entire inside with the appropriate appliance spray paint. After spray painting the freezer will not cool.
How old was your freezer?
This must be an ancient freezer!
And Unfortunately I was not able to tell you to leave it alone and not to turn it off!
You did not cause this!
Unfortunately it was so old that it probably was already on it's last legs.
Here is an interesting report I just read!
Repair or replace your appliances?
When to pull the plug on your old freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model ?
The answer depends mostly on the age of your ,freezer
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old freezers),
paying for a repair makes sense.
Note that freezer under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your freezer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new freezer.
Data also shows that it doesn't pay to fix a less-expensive freezer
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a freezer you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Oct 10, 2008
ryanmalin
  • 40 Answers
SOURCE: cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Posted on Oct 10, 2009
Frigidaire bottom freezer spills ice when opened and I can't shut the drawer til I fish the ice cubes out.
You might be well served with a general defrost of the unit. But before you do, make sure that the mounting screws on the ice maker are fully in. Then if so, warm the lower surface of the ice maker where cubes are ejected with a hair dryer for a minute or two (medium not high). It could be that extraneous ice is catching the cubes. What does it feel like to the hand?
Mar 02, 2018 | Frigidaire 20.3 cu. ft. Upright Freezer...
Kenmore freezer drawer frozen shut
use your wife's electric handheld hair dryer as close to the rails as you can once slightly open you can use table salt/ice melt to free the drawer or; turn up your house thermostat to about 80 degrees for the day while you are at work; the drawer should be free by the time you get home.
Nov 18, 2013 | Freezers
My ice cubes have a funny odor/taste.
Does your refrigerator have a water filter? if it has one it will be in the kickplate/grill below the freezer door. If it has one replace the filter.
Aug 17, 2011 | Whirlpool Freezers
Cannot open bottom freezer drawer. Ice in tray
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Sep 23, 2008 | Maytag Freezer MQU2057
Bottom drawer hard to close
Oct 10, 2007 | Miele 3.7 cu. ft. / 105 liter Upright...
Freezers Logo
35 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
