Model : ELekta EAWM - 7003 Hii I face a problem while tring to start the washing machine. E6 came on screen while I power it on. Pls advice what is the problem and how I can fix it.
SOURCE: hoover vision HD 1400 AAA 8kg washing machine -
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Posted on Jul 18, 2010
  • 6277 Answers
SOURCE: We don't know how to
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and helping for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Mar 03, 2011
caroldon
  • 17129 Answers
SOURCE: my washing machine Fisher&pykel/ intuitive eco
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Aug 09, 2011
SOURCE: washing machine not draining water during washes
I have had the same problem. Someone told me to clean the pump filter. I have a front loader and the pump filter is in a little door down the front of the washing machine. You turn the thing in there counter clockwise (water may cascade out - keep bucket handy) then clean flint/soap out of the filter.
This didn't work for my washing machine however, so if anyone has any ideas (ie. how do you actually check if the hose from the washer to the sink is blocked - mine doesn't detach) would be most appreciated
Posted on Dec 09, 2011
kevin_getz
  • 1031 Answers
SOURCE: My Electrolux washing machine W4180N has faul error 6 (e6), how to fix the problem
I'm not finding anything in my literature on that code. I would contact electrolux directly.
Posted on May 30, 2012
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
My elekta washing machine model EAWM-S7003 doesn't startup. There is no display.
Check your fusebox and make sure that its all switched on
Feb 09, 2015 | Washing Machines
What does E6 mean on a baumatic bwm70
E6 on the bwm70 means that there is a water sensor level error. You can try resetting the error code to see if it comes back on by pressing and holding the the power on, start/stop button, or unplug the washer, wait 30 seconds and try again. If you still get the E6 code, your washer will need to be serviced
Jun 18, 2014 | Washing Machines
Elekta EAWM - S7003 Manual
When running the washing machine does not withdraw water
Nor in the process of drying and rinse
Sep 22, 2013 | Washing Machines
I want user manual for elekta eawm-s7003
water inlet is not closing while switchon
Apr 10, 2013 | Cell Phones
Motorola motorokr E6 screen lock unlock button not working
Hii
Did u drop ur cell phone somewhere? the chances are tht button might have lost contact to the main circuit, I would suggest u to take it to the motorola's service center and get it checked, they would check free of cost, once the problem is diagnosed they would charge u some where between 150-300Rs.
Hope this helps u.
G'Day.
Sep 11, 2009 | Motorola Mobility MOTOROKR E6
Not receiving faxes
pls. set accept all type of ring tone in setup menu
so that the fax machine detected all types fo ring tone either one ringing , or two ring, or long ring tone,
Example; tring .......tring , or tring-tring..........tring-tring, or trrring................trrring,
pls. check this
Best Rregards.
P.S.Dua
Jan 24, 2008 | Brother MFC-5840CN All-In-One InkJet...
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
