Question about Belling Ovens
Remove fan motor
I have a working Belling Synergie under counter single oven with a very loud fan. It almost sounds as though it is taking off as it starts quietly & builds to a loud whooshing sound. Any ideas?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Have more children (I cant even hear myself think)
>> design problem, not going to fix it with new parts..... ear plugs?
Posted on Oct 18, 2013
  • 18 Answers
SOURCE: Belling Synergie fan oven.
the elemet has burned out round the fan
Posted on Jul 12, 2007
SOURCE: belling synergie. oven
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Posted on Aug 19, 2008
SOURCE: can't get my belling oven to work
Press & hold both the 'Cook Time' and 'Stop Time' buttons together and, while holding both of them down, press either the + or - button (this is the way to set the time of day). Release all buttons simultaneously. This should enable the cooking functions to operate.
Posted on Apr 27, 2009
barkencoa
  • 3463 Answers
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
barkencoa
  • 3463 Answers
SOURCE: How do I remove the oven element on our Belling
It all depends on whether the scew heads are flat, or have slots for a screwdriver.
If no slots , then you are going to have to access the heater from the rear of the outer rear cover of the oven.
If the screws can be undone from inside, then simply unscrew them, and pull the element out towards you.
Hope this helps.
Posted on Dec 27, 2009
Replaced element on belling synergie on 2 occasions in the past 6 months. What could be the reason for them blowing?
fan on in oven but not heating up just after the power tripped think because of oven this is not the first time this has happened can you help please
yours shane
Mar 10, 2011 | Belling XOU174 Electric Single Oven
Belling synergie oven grill comes on oven fan comes on all lights are working but no heat in the oven temp 200 setting on the oven symbol all plugs have been checked.
I suspect tha the oven element is faulty.
To access it, you will find it located at the rear of the oven compartment behind a removeable cover.
Hope this helps you.
Dec 13, 2009 | Belling Ovens
Fan oven option not functioning on main oven, its a Belling synergie multifunction oven, about 5 years old
On my Belling it was the oven multi function switch that was faulty. I replaced it - carefully (lots of coloured wires) and it works fine now. Hope this helps
Oct 24, 2009 | Belling XOU590 Electric Double Oven
How do I find the model number on belling synergie oven?
I have the same problem. I have inherited a Belling Synergie multifunction double oven. The Model No is worn out - yet there is a specification 492SS which isn't. I am going to purchase the element with this number and hope this works.
Mar 23, 2009 | Belling XOU174 Electric Single Oven
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Belling synergie oven - main oven won't come on.
hi
check the timmer clock is not in auto mode as this will stop the oven from turning on. if clock ok then fault could poss be the thermostat
hope this helps you
regards dan
Mar 03, 2009 | Belling XOU174 Electric Single Oven
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Belling Synergie
NEED NEW FAN OVEN ELEMENT THAT CAN BE FOUND HERE
You need Element code AB20 on link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
element is located on back wall of oven you need to pull oven oven to remove the element element is held by two nuts from back and i screw from front
Dec 22, 2006 | Belling XOU270 / XOU271 Electric Single...
Dec 05, 2006 | Belling XOU174 Electric Single Oven
Ovens Logo
95 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
