Question about Samsung SyncMaster 793DF (Silver, Black) (Black, Silver) 17 in.CRT Conventional Monitor
Picture settings - Samsung SyncMaster 793DF (Silver, Black) (Black, Silver) 17 in.CRT Conventional Monitor
Settings for taking pictures
What kind of picture do you want to take? What do you want that picture to say to the viewer?
There are a lot of different settings because there are a lot of different types of pictures. You don't want the same settings for a landscape picture as for a portrait picture. You probably wouldn't want the same settings for a portrait of a young girl as for a portrait of her grandfather.
If you're not comfortable choosing the settings yourself, set the camera to the appropriate scene mode. For taking pictures of people use the Portrait mode, for taking pictures of where you are on vacation use the Landscape mode, and so on.
If you want to learn more, your local library probably has some introductory photography books that tell you how the various settings such as aperture and shutter speed affect your pictures.
Apr 01, 2013 | Canon PowerShot A520 Digital Camera
Sony kdl55nx720 picture settings
Your are the one that knowing the best settings for your TV..To adjust the picture make it sure that all colors are appear like RGB red,green,blue on your screen to easily set the best picture,,..
Dec 28, 2011 | Sony Televison & Video
Hey there just have simple question: Is it possible to lock setting for the different modes? I have found that a little brighter for movies and games works for me but I think that it keeps switching back...
Hello
Just enter to its picture and sound settings by menu option, and do the picture setting as you interested in.
1 Press MENU on the remote control.
2 Use Up, Down, Forward, Reverse buttons to select [ Setup] > [ Picture].
3 Use Up, Down, Forward, Reverse buttons to select one of the picture settings, and press OK
to enter the setting.
4 Adjust the picture quality.
The following picture settings can be confi gured. Depending on
the format of the picture source, some picture settings are not
available
You must set [Home] in [ Location] Otherwise, the settings you adjusted will not be memorized after you
turn off the unit.
You can set the location of your TV to [Home] or [Retail store].
Choosing [Home] gives you full fl exibility to change predefi ned settings for
picture and sound.
1 Press MENU on the remote control and then use Up, Down, Forward, Reverse buttons to
select [Setup] > [Installation] > [Preferences] > [Location].
2 Select [Home] and then press OK to confi rm your choice.
3 Press MENU to exit.
Mar 23, 2011 | Philips 55PFL7705D 55" LCD TV
I just need to adjust the resolution on this TV. NO ONE at RCA could seem to help me. Thank you.
hi,
did u mean to adjust the picture setting then go for the following
1 press menu on the remote
2. using down arrow select picture quality and press ok. available options in picture quality and its use is listed below. you can use it according to your preference.
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
Sharpness Adjusts the crispness of edges in the picture.
When exiting this menu, the Save Personal Picture Preset choice list will
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
reduction.
Dec 21, 2010 | RCA G36705 36" TV
How doi reset the picture after replacing the bulb and housing
It is not required to set the Picture after replacing the Lamp and Housing. To change the Picture Settings press the MENU button on the Remote, highlight PICTURE and press OK. There you'll get the option to select Picture Preset Mode, Picture Settings, Screen Format, Advanced Picture and Screen Adjust mode. You can customize the settings by selecting the each Picture Menu options.
Click here to download the manual of the TV. View page # 39 for the instructions to change the Picture Menu.
Good Luck!
Thanks for using FixYa
Dec 01, 2010 | RCA M50WH185 Television
My Sony Bravia has no colour, and the black and white is so dark you can't see the picture. It is less than 1 year old model # KDL-46S5100
If the picture has no color or appear as black and white only, please reset the picture setting. To reset picture setting please follow the items below:
  1. Press MENU button on your remote.
  2. Press arrowtb.png to select setting.jpgSettings, then press ok.png.
  3. Press arrowtb.png to select picturemenu.jpgPicture Menu, then press ok.png.
  4. Press arrowtb.png to select Reset, then press ok.png to reset all the Picture Settings except Picture Mode and Display Mode to the factory settings.
If this does not not work, then change the picture board in your TV.
Please rate my solution.
Good luck.
Jun 27, 2010 | Televison & Video
Camera still possessed
There is something wrong with the settings of the camera.
When it is on setting or view mode is fine. It is not supposed to take pictures.
Go thru the Menu and pick the way you want your pictures, size and all those details, switch them take pictures and keep switching the settings until you get it right.
My camera was taking 3 pictures at the time, and it was because of the setting was set to do that. Don't be afraid of changing the setting for pictures, you can always change and try different things, digital pictures can be erased right away. So you can try as much as you want.
Try all options in the setting for taking a picture, change a setting, try to take a picture and see what happens. Then try on another setting and so on.
Artgirl
Jul 08, 2008 | Nikon Coolpix 2100 Digital Camera
Picture settings
The settings is on the remote (menu)
Dec 18, 2007 | Sylvania LC320SS8 32 in. LCD Television
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Mar 03, 2007 | Zenith B25A02Z TV
Samsung SyncMaster 793DF (Silver, Black) (Black, Silver) 17 in.CRT Conventional Monitor Logo
13 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
