Question about Ricoh Caplio R7 Digital Camera
Poor color pics n poor focus - Ricoh Caplio R7 Digital Camera
    Master:
  • 359 Answers
Are you sure the camera quality is not supposed to be like that? Have you gone through any of the settings on the camera or try setting the picture quality to auto?
Posted on Oct 16, 2013
Blue colors no magic focus stop at blue colors
Check the resistor in front and back of Convergence ICs. STK392-110s. the ICs might need to be replaced also. Look for poor solder connections also.
Oct 01, 2012 | Hitachi 46F500 46" Rear Projection...
Picture color is pinkish and out of focus
there might be a problem with ur monitor.
Step 1 - check these pics on sumone else's comp or open sum other jpegs just to check
Step 2 - If the pics are fine on sum other comp then ur monitor needs attention
Otherwise
use Adobe photoshop
adjustments ----> color balance to get rid of pink tint
Apr 05, 2010 | Canon PowerShot A95 Digital Camera
Poor focus
Little known fix it.
Gentle but firmly hold camera one hand, with camera running, hold lens and gentle turn left or right watching pic on screen.
turn till you get a reasonably clear picture.
Found out by accident?
Nov 11, 2009 | Computers & Internet
Sony kp 57hw40 Convergence Problem The screen looks distorted, Letters or words on the screen are bowed.(I can see double but the screen is stationary all the color, hue, sharpness, brightness, exc. can be...
If after the Flash Focus™ feature has been performed, the colors on the FLASH FOCUS screen do no line up (converge), press the FLASH FOCUS button on the television to begin the cycle again. If the colors on the FLASH FOCUS screen continues to appear misaligned, service will be required .
NOTE: It is recommended to perform the Flash Focus™ feature about thirty minutes after the television has been turned on and keep the room as dark as possible.
Sep 22, 2009 | Sony KP-57HW40 57" Rear Projection...
I have a sony kp-61v90 projector tv and the colors are making the red stick out, feels like a 3d, any help?i kalld a tv repair which charged me $50 and said to repair $350 which is pretty crazy....help
i'm assuming that your complaint is the red is predominant over the other colors- if it is a rear projection set, there are three tubes [r,b,g], and each one has its own flyback with a focus and 'g2' control on it. try backing down the red g2, and if the picture is too dark, turn down the color control [so you should have a black and white pic], then adjust the g2 controls until you have a satisfactory black and white pic- after that, when you turn the color back up, you should have a good pic. sometimes. adjusting the g2 can affect the focus, and there is a focus control on the flyback. there are also optical focus [moveable lenses] on each tube, but they are primarilly for initial setup of the set, and should never have to be adjusted, unless the tube has been replaced. fyi- i happen to have a complete set of sony rear projection tubes [r,b,g] complete with lenses and neck coils i am currently trying to sell, but it doesn't sound like you need tubes at this time, but it's something to keep in mind, because these tubes are becoming extremely rare and hard to find, and cost upwards of close to a thousand dollars a piece, i'm selling the complete set for four hundred dollars. good luck!
Sep 05, 2009 | Sony KP-61V90 61" Rear Projection...
Pic focus & convergence
Before you replace the ICs, try resoldering the connections on them. Also check the area for other poor solder connections. Resolder any that appear tobe grainy or have rings. Update this with your results and report if the symptoms change.
Thanks,
Dan
Jul 14, 2008 | Televison & Video
Focus error
You need to replace both convergence ICs part number STK392-110 you can get replacements with free instalation instructions with pics at this link.
http://servicemanuals.vstore.ca/
May 04, 2008 | Toshiba 57H81 57" Rear Projection...
Pic quality
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
Using Latest Software:
Finally, make sure you are using the latest release of Logitech camera software. You can download the latest release from the Logitech Downloads + Parts page.
Feb 26, 2008 | Logitech Webcam
Blury Pictures
My Logitech Quickcam for notebooks Deluxe webcam was blurry.
I spent 3 hours surfing the net looking for the answer, only to find a load of vague and technical responses about OS's and other ****. I fiddled about with the focus ring around the lens on my cam, which wouldn't move, so i figured i had an inferior version that had some sort of in-built auto-focus.
Eventually i lost my rag with the poor quality of information i was finding on this issue.
I went downstairs, got my pliers out of my tool bag, and wrenched the lens ring.
It moved.
Camera focused.
Job done.
Voila, no techy **** required.
Feb 16, 2008 | Logitech Webcam
Focus
hi
sir, no focus means this is internal optical movement problem,repareble, and setup date changing this is also internalbattery backup poor replace ur internal battery
Sep 05, 2007 | Samsung Digimax A400 Digital Camera
Ricoh Caplio R7 Digital Camera Logo
37 people viewed this question
Top Ricoh Cameras Experts
Fred Block
Fred Block
Greg Cann
Greg Cann
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
