Question about Indesit Dryers
Water leaking from bottom of tumble dryer - model no IDC85
SAMKARIA
SOURCE: tumble dryer
This is the problem of your dryer's circut board. call the person from whom you have buy this and if dryer has gaurenttie period then replace if you want to get relief in future. ANKAJ
Posted on Nov 29, 2007
swami nathan
  • 208 Answers
SOURCE: the tumble dryer bip and
I want to first make sure that your dryer is serviced up. so i want you to do these steps.
Most of the problems will be resolved doing these......
As clothes are tumble dried, they drop fibres. Most of this fluff is trapped by the lint filter and this needs to be checked and cleaned regularly. Lint also builds up in the vent pipe and around the electric motor in the rear of the dryer.
1.clean lint filter
Wait until the dryer cools, open the door and lift out the lint filter.
Gently brush off lint using your fingers.
On many models, the filter may also be washed. Check your manual for instructions.
If the filter is damaged in any way, you should replace it.
2.Vacuum area where lint filter sits:
The area where the lint filter sits should be vacuumed .
Remove the lint filter, and use a narrow vacuum nozzle to remove dust and lint from the fitting.
3.Clean inside the tumble dryer:
1. Make sure the dryer is cool, switch it off and unplug it.
2. Unscrew the retaining screws on the back panel, and lift it off. Vacuum the blower area.
3. Also vacuum around the vent pipe connection.
4. Replace the back panel and refit all the screws.
4.Check tumble dryer vent hose:
8d2299a.jpgWait for the dryer to cool. Unplug the vent hose and inspect its entire length for snags in the pipe.
Make sure the vent is not obstructed on the outside wall, and fit a flap or screen to keep out small animals.
If your vent pipe is punctured or damaged, you should replace it.
To avoid dryer problems,
Make sure the dryer is level and does not rock, and consult the manufacturer's instructions for the maximum weight of clothing to dry at one time. Also, make sure clothes have been spun-dry before putting them into the dryer.
This is just initial help,
Post your comments about how things turned up, Ill be giving suggestions based on your reply........
Thanx for using fixya,
Cheers.
Posted on Sep 27, 2008
  • 135 Answers
SOURCE: water leaking from back of m/c
You may have accidentally disconnected the pipe which takes water from pump to bottle.
Please post back if any assistance needed to access pump.
Thankyou for using Fixya.
Posted on Jan 23, 2009
SOURCE: Water leak on Zanussi tc7102 dryer
I had a similar problem. There is a 'o' ring on the plastic part that keeps coming out. This 'o' ring is not big enough, you need to replace it with a thicker one, preferably one made from a harder material.
Posted on Mar 01, 2009
  • 3 Answers
SOURCE: My is70c tumble dryer is
This model is a condenser dryer, at the bottom of the machine if you open up the flap you will see the condenser on the left hand side, the manufacturer recommends that you clean this unit once every month and also empty the reservoir and clean the fluff filter after every use. While this may seem like a lot of hard work there is a very good reason for this. I suspect that your problem is due to a build up of fluff and or gunge in the condenser and bottom of the machine. Remove the condenser and give it a good clean of all fluff, you can run water through it either in the sink or bath as the best way to do this it is very fiddley using just your hands. Next check to see if there is a build up of water in the back the machine where the condenser usually sits, you will have to lie on your stomach and reach into the back of the machine (OBVIOUSLY ENSURE THAT YOU HAVE UNPLUGGED FROM THE MAINS SUPPLY BEFORE YOU DO THIS!) along the floor of the machine you will feel a channel cut into the plastic which runs into the sump at the back of the machine, if you have not cleaned the machine properly this is probably blocked and is the culprit. With this blocked the water is unable to travel to the pump that takes the water from the condenser into the resevoir at the top of the machine, and therefore it stays in the machine and can get thrown about onto the electrics and could cause the machine to cut out and trip your electrics! If this is not blocked check the black rubber pipe leading from the pump to the reservoir is not blocked, failing that perhaps the pump (in the plastic case at the back of the machine) is faulty and will need to be replaced.
Posted on May 28, 2009
How do I change the thermostat on an Indesit IDC85
heater units have 2 or 3 starts ,check they work ..on some hotpoint dryers there is a stat on the front top right just under the timer as wire burns out then no heat ..WARNING TAKE OUT THE PLUG
Sep 16, 2015 | Indesit IDC85S Silver Electric Dryer 8kg,...
Hi my miele condenser tumble dryer t294c has started leaking water from inside machine and leaking onto floor has anyone any sugestions of the problem I'm getting thanks
you should remove the cabinet then pour water in and jumper the door switch and run and check where and which hoses are leaking if any? check ur water pump for damage and leaks
Feb 28, 2015 | Miele Dryers
Indesit idc85 not collecting water in container.
well it could be one of two things its blocked up which means you need to clean all tubes out or the pump is faultyif you take the top of dryer and pore water into drum and turn you should be able to see if water comes up tube if not check your pump
Oct 14, 2014 | Dryers
Indesit IDC85
belt fits againt the spring............
cheers
Apr 11, 2014 | Indesit Dryers
Hooverlightflashing
A tumble drier should only be used to dry clothes that have been through a hydro extractor (spin drier) first. They are not designed to put wet washing in. Dripping wet washing must first be wrung out or else the excess water will run out the bottom. If it is a washer/extractor, look for leaking pipes or door gasket.
Nov 25, 2013 | Dryers
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Water leaking from back of m/c
Jan 23, 2009 | Zanussi TC7114W Electric Dryer
Leaking condenser tumble dryer
i have the same problem i need help sick of putting towels down infront of it
Dec 28, 2007 | Washing Machines
Dryers Logo
1,957 people viewed this question
Top Indesit Dryers Experts
Tim Whalen
Gerard Curran
paul
paul
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
