Question about Whirlpool GZ25FSRXYY
How do you remove top freezer tray? - Whirlpool GZ25FSRXYY
    Master:
  • 359 Answers
If you open the freezer all the way, do the rails that the tray is sliding on have clips that you can push in to extend it out even further allowing you to remove the tray?
This information can be found in the manual for your refrigerator.
Posted on Oct 16, 2013
  • Lloyd Benoit
    Lloyd Benoit Oct 16, 2013
    Yes, but it only allows the removal of bottom tray, not the top
Trying to replace water inlet valve on sub zero 700tci freezer. I don't have enough access to remove the valve for replacement
The valve has a screw on top that you can remove, but it's very difficult to reach without first removing the lower tray that contains the compressor and condenser. if you remove the screw on the left and the screw on the right that are in at about a 45 degree angle, the whole tray will slide out. Be very careful though, as doing this is stretching the Freon lines and they may kink or they may kink when pushing the tray back in. once you slide it out a little ways, there is a screw at the top of the valve, and you may have to pull the wire off the valve to pull it out far enough to remove the quick release coupler on the water line going up to the icemaker. Be sure to turn off the water to the unit or the house water first!
Jan 20, 2014 | Sub-Zero 700TC Bottom Freezer Refrigerator
Pan tray
The pan is located inside the removable grille at the bottom of your freezer
Jul 01, 2013 | Roper RT21AKXKQ Top Freezer Refrigerator
Have an 8yr old Kenmore top freezer. Water is dripping from top of refrigerator section,from back right side of a vent. Have made sure food is not blocking circulation in freezer. Help!
Your freezer has a drain tube located behind the: freezer ice tray back rear plastic cover; It leads to the defrost tray at the bottom of the refrigerator. remove the back rear plastic cover, the drain will be located at the right side of the coils.
flush the tube out using a funnel and, a pan of hot water. empty the floor defrost tray as you do this.
Mar 30, 2010 | Refrigerators
How to place back the freezer trays for E522B refrigerator
Make sure to return the correct tray/bin in the right runners. All three freezer trays have different designs on each side, which means that the top tray must be returned to the top tray and cannot be interchanged with the second tray. What happened in my case is, I was trying to put the 2nd tray to the first tray that's why I had difficulty replacing it back and would not fit.
Mar 22, 2009 | Fisher and Paykel E522BRXFD Stainless...
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Water leaking
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 12, 2009 | Roper RT21SKXLQ Top Freezer Refrigerator
STANDING WATER ON TOP SHELF
Jan 12, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water dripping from top of fridge then freezing under crisper's
Jan 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Smell
Your whole freezer bottom is probably removeable. you mat have to remove the doors and the separator bar in front to get this out. Then you will be able to access the spill.
Dec 31, 2008 | Hotpoint HTH16BBSR Top Freezer...
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool GZ25FSRXYY Logo
52 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
